| void | RegisterProgressEvent (vtkObject *object, int id) |
| | Listen to progress events from the object. More...
| void | PrepareProgress () |
| | This method resets all the progress counters and prepares progress reporting. More...
| void | AddHandlers () |
| | This method add wrong tag event handlers and rmi call back for progress related mathods. More...
| bool | GetEnableProgress () |
| | Get whether or not progress is currently enable and if this progress handler is ready to receive progress events. More...
| void | CleanupPendingProgress () |
| | This method collects all outstanding progress messages. More...
| void | LocalCleanupPendingProgress () |
| | Local cleanup of progress flags. More...
| void | SetSession (vtkPVSession *conn) |
| | Get/Set the session. More...
| virtual vtkPVSession * | GetSession () |
| virtual void | SetProgressInterval (double) |
| | Get/Set the progress interval in seconds. More...
| virtual double | GetProgressInterval () |
| virtual char * | GetLastProgressText () |
| | These are only valid in handler for the vtkCommand::ProgressEvent. More...
| virtual int | GetLastProgress () |
progress handler.
vtkPVProgressHandler handles the progress messages. It handles progress in all configurations single process, client-server. It must be noted that when running in parallel, progress updates are fetched from the root node. Due to performance reasons, we no longer collect progress events (or messages) from satellites, only root-node events are reported back to the client. While this may not faithfully report the progress, this avoid nasty MPI issues that can be painful to debug and diagnose.
Progress events are currently not supported in multi-clients mode.
- Events:
- vtkCommand::StartEvent
- fired to indicate beginning of progress handling
calldata: vtkPVProgressHandler* vtkCommand::ProgressEvent
- fired to indicate a progress event.
calldata: vtkPVProgressHandler* vtkCommand::EndEvent
- fired to indicate end of progress handling
Starting ParaView 5.5, vtkCommand::MessageEvent is no longer fired.
Definition at line 52 of file vtkPVProgressHandler.h.
