| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (vtkSMSourceProxy *proxy, unsigned int outputport=0) |
| | Returns true if input has one or more arrays that match the requirements on the given output port. More...
| std::vector< int > | GetAcceptableNumbersOfComponents () const |
| | Get the AcceptableNumberOfComponents vector Empty or containing a zero means no check. More...
| int | IsArrayAcceptable (vtkPVArrayInformation *arrayInfo) |
| | This method will check if the arrayInfo contain info about an acceptable array, by checking its number of components against this domain acceptable numbers of components. More...
| virtual int | GetAttributeType () |
| | Get the attribute type. More...
| const char * | GetAttributeTypeAsString () |
| virtual void | Update (vtkSMProperty *requestingProperty) |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMInputArrayDomain () |
| | ~vtkSMInputArrayDomain () override |
| virtual void | SetAttributeType (int) |
| void | SetAttributeType (const char *type) |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| bool | IsAttributeTypeAcceptable (int attributeType) |
| | Returns true if based on this->AttributeType, the specified attributeType is acceptable to this domain. More...
| bool | HasAcceptableArray (vtkPVDataSetAttributesInformation *attrInfo) |
| | Returns true if based on this->AutomaticPropertyConversion and this->NumberOfComponents, an acceptable array can be found in the attrInfo. More...
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
domain to ensure that input has required types of arrays.
vtkSMInputArrayDomain is a domain that can be used on a vtkSMInputProperty to check if the pipeline input provides attribute arrays of the required types e.g. if a filter can only work if the input data set has cell data arrays, then one can use this domain.
vtkSMInputArrayDomain also provides a mechanism to check if the attribute arrays have a certain number of components.
When enabled, ParaView supports automatic array conversion i.e. extracting components or converting cell data to point data and vice-versa is done implicitly. In that case, vtkSMInputArrayDomain's behavior also changes as appropriate.
Supported XML attributes:
attribute_type : (optional) value can be 'point', 'cell', 'field', 'vertex', 'edge', 'row', 'none', 'any-except-field', 'any'. If not specified, 'any-except-field' is assumed. This indicates the attribute type for acceptable arrays.
number_of_components : (optional) Indicates the number of components required in arrays that are considered acceptable. 0 (default) indicates any number of components is acceptable. A comma-separated list (e.g., "1" or "1,3,4") of component counts limits acceptable arrays to those with a number of components that appear in the list.
data_type: (optional) when specified must be the class name for data type that this domain is applicable to. This is useful when adding multiple input-array-domains a property with different requirements based on the type (see ("filters", "Contour") filter, for example).
This domain doesn't support any required properties (to help clean old code, we print a warning if any required properties are specified).
- Attention
- Prior to ParaView 5.0, attribute_type="any" meant all attributes excepting field data. For being consistent with general understanding of "any", this has been changed to include field data arrays since 5.0. Use "any-except-field" for cases where the intention is to match any attribute arrays except field data arrays.
Definition at line 79 of file vtkSMInputArrayDomain.h.
