| bool | MakeDirectory (const std::string &name, vtkTypeUInt32 location) |
| | Make a directory on the specified location. More...
| bool | DeleteDirectory (const std::string &name, vtkTypeUInt32 location) |
| | Delete a directory on the specified location. More...
| bool | RenameDirectory (const std::string &name, const std::string &newname, vtkTypeUInt32 location) |
| | Rename a directory on the specified location. More...
file system utilties
vtkSMFileUtilities can be used to make various file-system related queries and updates by applications. It is intended to be used instead of the ("misc", "Directory") proxy (or vtkSMDirectoryProxy) since this class can better support MPI and symmetric-MPI mode of operation. It does that as follows:
- Any API call that modifies the directory structure only gets called on the root-node, and never on the satellites. This avoids unnecessary overheads encountered by the filesystem to avoid race-conditions on parallel file systems.
- In symmetric-MPI mode, since the server-manager level code is called on all ranks including the satellites, this class ensures that while the filesystem updates are only triggered on the root node, the status is correctly shared among all the satellites. Thus the function call will return correct status on all ranks.
Definition at line 43 of file vtkSMFileUtilities.h.
