| void | StillRender () override |
| | Triggers a high-resolution render. More...
| void | InteractiveRender () override |
| | Triggers a interactive render. More...
| void | Update () override |
| | Overridden to identify and locate the active-representation. More...
| virtual vtkIdType | GetNumberOfColumns () |
| | Get the number of columns. More...
| virtual vtkIdType | GetNumberOfRows () |
| | Get the number of rows. More...
| virtual const char * | GetColumnName (vtkIdType index) |
| | Returns the name for the column. More...
| vtkIdType | GetColumnByName (const char *columnName) |
| | Returns the column index for a column given its name. More...
| virtual bool | GetColumnVisibility (vtkIdType index) |
| | Returns the visibility for the column at the given index. More...
| virtual bool | IsRowSelected (vtkIdType row) |
| | Returns true if the row is selected. More...
| virtual bool | IsAvailable (vtkIdType row) |
| | Returns true is the data for the particular row is locally available. More...
| virtual bool | IsDataValid (vtkIdType row, vtkIdType col) |
| | Returns true of the data at the given row and column is valid. More...
| void | SetColumnNameToSort (const char *) |
| | Get/Set the column name to sort by. More...
| void | SetColumnNameToSort () |
| void | SetInvertSortOrder (bool) |
| | Get/Set whether the sort order must be Max to Min rather than Min to Max. More...
| void | SetBlockSize (vtkIdType val) |
| | Set the block size. More...
| virtual bool | Export (vtkCSVExporter *exporter) |
| | Export the contents of this view using the exporter. More...
| void | ClearCache () |
| | Allow user to clear the cache if he needs to. More...
| vtkTable * | FetchBlockCallback (vtkIdType blockindex) |
| virtual void | SetIdentifier (vtkTypeUInt32) |
| | A unique identifier for this vtkSpreadSheetView across all processes. More...
| virtual vtkTypeUInt32 | GetIdentifier () |
| void | SetShowExtractedSelection (bool) |
| | Get/Set if the view shows extracted selection only or the actual data. More...
| virtual void | ShowExtractedSelectionOn () |
| virtual void | ShowExtractedSelectionOff () |
| virtual bool | GetShowExtractedSelection () |
| virtual void | SetGenerateCellConnectivity (bool) |
| | Allow user to enable/disable cell connectivity generation. More...
| virtual bool | GetGenerateCellConnectivity () |
| virtual void | GenerateCellConnectivityOn () |
| virtual void | GenerateCellConnectivityOff () |
| virtual void | SetFieldAssociation (int) |
| | Specify the field association for the data to be shown in the view. More...
| virtual int | GetFieldAssociation () |
| void | HideColumnByName (const char *columnName) |
| | This API enables the users to hide columns that should be shown. More...
| bool | IsColumnHiddenByName (const char *columnName) |
| void | ClearHiddenColumnsByName () |
| void | HideColumnByLabel (const char *columnLabel) |
| bool | IsColumnHiddenByLabel (const std::string &columnLabel) |
| void | ClearHiddenColumnsByLabel () |
| virtual bool | IsColumnInternal (vtkIdType index) |
| | Returns true if the column is internal. More...
| virtual bool | IsColumnInternal (const char *columnName) |
| virtual std::string | GetColumnLabel (vtkIdType index) |
| | Returns the user-friendly label to use for the column in the spreadsheet view. More...
| virtual std::string | GetColumnLabel (const char *columnName) |
| virtual vtkVariant | GetValue (vtkIdType row, vtkIdType col) |
| | Returns the value at given location. More...
| virtual vtkVariant | GetValueByName (vtkIdType row, const char *columnName) |
| virtual void | SetPPI (int) |
| | Description: Set the screen PPI. More...
| virtual int | GetPPI () |
| bool | InTileDisplayMode () |
| | Returns true if the application is currently in tile display mode. More...
| bool | InCaveDisplayMode () |
| | Returns true if the application is currently in cave/immersive display mode. More...
| bool | GetLocalProcessSupportsInteraction () |
| | Returns true if the local process can support interaction. More...
| vtkRenderWindow * | GetRenderWindow () |
| | If this view needs a render window (not all views may use one), this method can be used to get the render window associated with this view on the current process. More...
| virtual void | ScaleRendererViewports (const double viewport[4]) |
| | vtkViewLayout calls this method to update the total viewport available for this view. More...
| vtkMTimeType | GetUpdateTimeStamp () |
| | Provides access to the time when Update() was last called. More...
| virtual void | Deliver (int use_lod, unsigned int size, unsigned int *representation_ids) |
| | Called on all processes to request data-delivery for the list of representations. More...
| virtual bool | IsCached (vtkPVDataRepresentation *) |
| | Called in vtkPVDataRepresentation::ProcessViewRequest to check if the representation already has cached data. More...
| virtual void | ClearCache (vtkPVDataRepresentation *) |
| | Called by vtkPVDataRepresentation whenever vtkPVDataRepresentation::MarkModified is called. More...
| virtual void | SetPosition (int, int) |
| | Set the position on this view in the multiview configuration. More...
| virtual int * | GetPosition () |
| virtual void | GetPosition (int &, int &) |
| virtual void | GetPosition (int [2]) |
| virtual void | SetSize (int, int) |
| | Set the size of this view in the multiview configuration. More...
| virtual int * | GetSize () |
| virtual void | GetSize (int &, int &) |
| virtual void | GetSize (int [2]) |
| virtual void | SetViewTime (double value) |
| | Get/Set the time this view is showing. More...
| virtual double | GetViewTime () |
| virtual void | SetCacheKey (double) |
| | Get/Set the cache key. More...
| virtual double | GetCacheKey () |
| virtual void | SetUseCache (bool) |
| | Get/Set whether caching is enabled. More...
| virtual bool | GetUseCache () |
| virtual void | PrepareForScreenshot () |
| | These methods are used to setup the view for capturing screen shots. More...
| virtual void | CleanupAfterScreenshot () |
| void | SetTileScale (int x, int y) |
| | When saving screenshots with tiling, these methods get called. More...
| void | SetTileViewport (double x0, double y0, double x1, double y1) |
| void | SetDeliveryManager (vtkPVDataDeliveryManager *) |
| | Provides access to data delivery & cache manager for this view. More...
| virtual vtkPVDataDeliveryManager * | GetDeliveryManager () |
| vtkView * | NewInstance () const |
| void | AddRepresentation (vtkDataRepresentation *rep) |
| void | SetRepresentation (vtkDataRepresentation *rep) |
| vtkDataRepresentation * | AddRepresentationFromInputConnection (vtkAlgorithmOutput *conn) |
| vtkDataRepresentation * | SetRepresentationFromInputConnection (vtkAlgorithmOutput *conn) |
| vtkDataRepresentation * | AddRepresentationFromInput (vtkDataObject *input) |
| vtkDataRepresentation * | SetRepresentationFromInput (vtkDataObject *input) |
| void | RemoveRepresentation (vtkDataRepresentation *rep) |
| void | RemoveRepresentation (vtkAlgorithmOutput *rep) |
| void | RemoveAllRepresentations () |
| int | GetNumberOfRepresentations () |
| vtkDataRepresentation * | GetRepresentation (int index=0) |
| bool | IsRepresentationPresent (vtkDataRepresentation *rep) |
| vtkCommand * | GetObserver () |
| void | RegisterProgress (vtkObject *algorithm, const char *message=NULL) |
| void | UnRegisterProgress (vtkObject *algorithm) |
vtkSpreadSheetView is a vtkPVView subclass for a view used to show any data as a spreadsheet.
This view can only show one representation at a time. If more than one representation is added to this view, only the first visible representation will be shown.
Definition at line 40 of file vtkSpreadSheetView.h.
