| void | Update () override |
| void | SetNumberOfXSlices (unsigned int count) |
| void | SetXSlices (const double *values) |
| void | SetNumberOfYSlices (unsigned int count) |
| void | SetYSlices (const double *values) |
| void | SetNumberOfZSlices (unsigned int count) |
| void | SetZSlices (const double *values) |
| const std::vector< double > & | GetSlices (int axis) const |
| const std::vector< double > & | GetXSlices () const |
| const std::vector< double > & | GetYSlices () const |
| const std::vector< double > & | GetZSlices () const |
| void | GetDataBounds (double bounds[6]) const |
| const char * | GetXAxisLabel () const |
| const char * | GetYAxisLabel () const |
| const char * | GetZAxisLabel () const |
| const vtkClientServerStream & | GetAxisLabels () const |
| void | SetModelTransformationMatrix (vtkMatrix4x4 *) |
| virtual vtkRenderer * | GetRenderer (int rendererType=DEFAULT_RENDERER) |
| | Returns the renderer given an int identifying its type. More...
| vtkRenderWindowInteractor * | GetInteractor () |
| | Returns the interactor. More...
| virtual void | SetupInteractor (vtkRenderWindowInteractor *) |
| | Set the interactor. More...
| void | StillRender () override |
| | Triggers a high-resolution render. More...
| void | InteractiveRender () override |
| | Triggers a interactive render. More...
| void | ConfigureCompressor (const char *configuration) |
| | Passes the compressor configuration to the client-server synchronizer, if any. More...
| virtual void | ResetCameraClippingRange () |
| | Resets the clipping range. More...
| void | InvalidateCachedSelection () |
| | Invalidates cached selection. More...
| void | SetMaxClipBounds (double bds[6]) |
| | Used by Cinema to enforce a consistent depth scaling. More...
| virtual void | SetGridAxes3DActor (vtkPVGridAxes3DActor *) |
| | Set the vtkPVGridAxes3DActor to use for the view. More...
| virtual void | SetOrientationAxesInteractivity (bool) |
| virtual void | SetOrientationAxesVisibility (bool) |
| void | SetOrientationAxesLabelColor (double r, double g, double b) |
| void | SetOrientationAxesOutlineColor (double r, double g, double b) |
| virtual void | SetCenterAxesVisibility (bool) |
| virtual void | SetCenterOfRotation (double x, double y, double z) |
| virtual void | SetRotationFactor (double factor) |
| void | SetKeyLightWarmth (double val) |
| void | SetKeyLightIntensity (double val) |
| void | SetKeyLightElevation (double val) |
| void | SetKeyLightAzimuth (double val) |
| void | SetFillLightWarmth (double val) |
| void | SetKeyToFillRatio (double val) |
| void | SetFillLightElevation (double val) |
| void | SetFillLightAzimuth (double val) |
| void | SetBackLightWarmth (double val) |
| void | SetKeyToBackRatio (double val) |
| void | SetBackLightElevation (double val) |
| void | SetBackLightAzimuth (double val) |
| void | SetHeadLightWarmth (double val) |
| void | SetKeyToHeadRatio (double val) |
| void | SetMaintainLuminance (int val) |
| virtual void | SetUseHiddenLineRemoval (bool) |
| virtual void | SetUseDepthPeeling (int val) |
| virtual void | SetUseDepthPeelingForVolumes (bool val) |
| virtual void | SetMaximumNumberOfPeels (int val) |
| virtual void | SetBackground (double r, double g, double b) |
| virtual void | SetBackground2 (double r, double g, double b) |
| virtual void | SetBackgroundTexture (vtkTexture *val) |
| virtual void | SetGradientBackground (int val) |
| virtual void | SetTexturedBackground (int val) |
| virtual void | SetSkyboxBackground (int val) |
| virtual void | SetUseEnvironmentLighting (bool val) |
| virtual void | SetEnvironmentalBG (double r, double g, double b) |
| virtual void | SetEnvironmentalBG2 (double r, double g, double b) |
| virtual void | SetEnvironmentalBGTexture (vtkTexture *val) |
| virtual void | SetGradientEnvironmentalBG (int val) |
| virtual void | SetTexturedEnvironmentalBG (int val) |
| virtual void | SetBackgroundMode (int val) |
| void | AddLight (vtkLight *) |
| void | RemoveLight (vtkLight *) |
| void | SetStereoCapableWindow (int val) |
| void | SetStereoRender (int val) |
| virtual void | SetStereoType (int) |
| virtual void | SetServerStereoType (int) |
| void | SetMultiSamples (int val) |
| void | SetAlphaBitPlanes (int val) |
| void | SetStencilCapable (int val) |
| void | SetParallelProjection (int mode) |
| virtual void | SetCamera2DManipulators (const int manipulators[9]) |
| virtual void | SetCamera3DManipulators (const int manipulators[9]) |
| void | SetCameraManipulators (vtkPVInteractorStyle *style, const int manipulators[9]) |
| virtual void | SetCamera2DMouseWheelMotionFactor (double factor) |
| virtual void | SetCamera3DMouseWheelMotionFactor (double factor) |
| | Overridden to synchronize information among processes whenever data changes. More...
| virtual void | UpdateLOD () |
| | Asks representations to update their LOD geometries. More...
| int | GetDataDistributionMode (bool low_res) |
| | Returns the data distribution mode to use. More...
| void | Deliver (int use_lod, unsigned int size, unsigned int *representation_ids) override |
| | Called on all processes to request data-delivery for the list of representations. More...
| bool | GetUseOrderedCompositing () |
| | Returns true when ordered compositing is needed on the current group of processes. More...
| bool | GetRenderEmptyImages () |
| | Returns true when the compositor should not use the empty images optimization. More...
| void | CopyViewUpdateOptions (vtkPVRenderView *otherView) |
| | Copy internal fields that are used for rendering decision such as remote/local rendering, composite and so on. More...
| bool | GetOSPRayContinueStreaming () |
| | Has OSPRay reached the max frames? More...
| void | SetOSPRayRendererType (std::string) |
| | Set the OSPRay renderer to use. More...
| virtual void | SetMaterialLibrary (vtkPVMaterialLibrary *) |
| | For OSPRay, set the library of materials. More...
| void | SetViewTime (double value) override |
| | Get/Set the time this view is showing. More...
| virtual vtkRenderViewBase * | GetRenderView () |
| void | ScaleRendererViewports (const double viewport[4]) override |
| | Overridden to scale the OrientationWidget appropriately. More...
| void | SynchronizeMaximumIds (vtkIdType *maxPointId, vtkIdType *maxCellId) |
| | This is used by vtkPVHardwareSelector to synchronize element ids between all ranks involved in selection. More...
| virtual void | SetInteractionMode (int mode) |
| | Get/Set the interaction mode. More...
| virtual int | GetInteractionMode () |
| void | SetSize (int, int) override |
| | Overridden to call InvalidateCachedSelection() whenever the render window parameters change. More...
| void | SetPosition (int, int) override |
| virtual vtkRenderer * | GetNonCompositedRenderer () |
| | Gets the non-composited renderer for this view. More...
| vtkCamera * | GetActiveCamera () |
| | Get/Set the active camera. More...
| virtual void | SetActiveCamera (vtkCamera *) |
| virtual vtkPVInteractorStyle * | GetInteractorStyle () |
| | Returns the interactor style. More...
| void | ResetCamera () |
| | Resets the active camera using collective prop-bounds. More...
| void | ResetCamera (double bounds[6]) |
| virtual void | SetSuppressRendering (bool) |
| | SuppressRendering can be used to suppress the render within a StillRender or InteractiveRender. More...
| virtual bool | GetSuppressRendering () |
| virtual void | SuppressRenderingOn () |
| virtual void | SuppressRenderingOff () |
| virtual void | SetStillRenderImageReductionFactor (int) |
| | Get/Set the reduction-factor to use when for StillRender(). More...
| virtual int | GetStillRenderImageReductionFactor () |
| virtual void | SetInteractiveRenderImageReductionFactor (int) |
| | Get/Set the reduction-factor to use when for InteractiveRender(). More...
| virtual int | GetInteractiveRenderImageReductionFactor () |
| virtual void | SetRemoteRenderingThreshold (double) |
| | Get/Set the data-size in megabytes above which remote-rendering should be used, if possible. More...
| virtual double | GetRemoteRenderingThreshold () |
| virtual void | SetLODRenderingThreshold (double) |
| | Get/Set the data-size in megabytes above which LOD rendering should be used, if possible. More...
| virtual double | GetLODRenderingThreshold () |
| virtual void | SetLODResolution (double) |
| | Get/Set the LOD resolution. More...
| virtual double | GetLODResolution () |
| virtual void | SetUseOutlineForLODRendering (bool) |
| | When set to true, instead of using simplified geometry for LOD rendering, uses outline, if possible. More...
| virtual bool | GetUseOutlineForLODRendering () |
| void | SetUseLightKit (bool enable) |
| | Enable/Disable light kit. More...
| virtual bool | GetUseLightKit () |
| virtual void | UseLightKitOn () |
| virtual void | UseLightKitOff () |
| void | StreamingUpdate (const double view_planes[24]) |
| void | DeliverStreamedPieces (unsigned int size, unsigned int *representation_ids) |
| void | SelectCells (int region[4], const char *array=nullptr) |
| | Make a selection. More...
| void | SelectCells (int region0, int region1, int region2, int region3, const char *array=nullptr) |
| void | SelectPoints (int region[4], const char *array=nullptr) |
| void | SelectPoints (int region0, int region1, int region2, int region3, const char *array=nullptr) |
| void | Select (int field_association, int region[4], const char *array=nullptr) |
| void | SelectPolygonPoints (int *polygon2DArray, vtkIdType arrayLen) |
| | Make a selection with a polygon. More...
| void | SelectPolygonCells (int *polygon2DArray, vtkIdType arrayLen) |
| void | SelectPolygon (int field_association, int *polygon2DArray, vtkIdType arrayLen) |
| virtual vtkSelection * | GetLastSelection () |
| | Provides access to the last selection. More...
| virtual void | SetUseInteractiveRenderingForScreenshots (bool) |
| | Set or get whether capture should be done as StillRender or InteractiveRender when capturing screenshots. More...
| virtual void | UseInteractiveRenderingForScreenshotsOn () |
| virtual void | UseInteractiveRenderingForScreenshotsOff () |
| virtual bool | GetUseInteractiveRenderingForScreenshots () |
| virtual bool | GetRemoteRenderingAvailable () |
| | Returns if remote-rendering is possible on the current group of processes. More...
| void | RemoteRenderingAvailableOff () |
| void | NVPipeAvailableOn () |
| | Determine if NVPipe is an available compressor option. More...
| void | NVPipeAvailableOff () |
| virtual bool | GetUsedLODForLastRender () |
| | Returns true if the most recent render used LOD. More...
| void | SetLockBounds (bool nv) |
| | Used by Cinema to enforce a consistent viewpoint and depth scaling. More...
| virtual bool | GetLockBounds () |
| int | RegisterPropForHardwareSelection (vtkPVDataRepresentation *repr, vtkProp *prop) |
| | Representations that support hardware (render-buffer based) selection, should register the prop that they use for selection rendering. More...
| void | UnRegisterPropForHardwareSelection (vtkPVDataRepresentation *repr, vtkProp *prop) |
| void | SetShowAnnotation (bool val) |
| | Enable/disable showing of annotation for developers. More...
| virtual void | SetUpdateAnnotation (bool) |
| void | SetAnnotationColor (double r, double g, double b) |
| | Set color of annotation text for developers. More...
| virtual bool | GetUseLODForInteractiveRender () |
| | Returns whether the view will use LOD rendering for the next InteractiveRender() call based on the geometry sizes determined by the most recent call to Update(). More...
| virtual bool | GetUseDistributedRenderingForRender () |
| | Returns whether the view will use distributed rendering for the next full-resolution render. More...
| virtual bool | GetUseDistributedRenderingForLODRender () |
| | Returns whether the view will use distributed rendering for the next low-resolution render. More...
| virtual vtkTypeUInt32 | GetStillRenderProcesses () |
| | Returns the processes (vtkPVSession::ServerFlags) that are to be involved in the next StillRender() call based on the decisions made during the most recent Update(). More...
| virtual vtkTypeUInt32 | GetInteractiveRenderProcesses () |
| | Returns the processes (vtkPVSession::ServerFlags) that are to be involved in the next InteractiveRender() call based on the decisions made during the most recent Update() and UpdateLOD(). More...
| virtual void | SetUseFXAA (bool) |
| | Enable/disable FXAA antialiasing. More...
| virtual bool | GetUseFXAA () |
| void | SetFXAARelativeContrastThreshold (double val) |
| | FXAA tunable parameters. More...
| void | SetFXAAHardContrastThreshold (double val) |
| void | SetFXAASubpixelBlendLimit (double val) |
| void | SetFXAASubpixelContrastThreshold (double val) |
| void | SetFXAAUseHighQualityEndpoints (bool val) |
| void | SetFXAAEndpointSearchIterations (int val) |
| void | SetUseToneMapping (bool v) |
| | Tone Mapping options. More...
| virtual bool | GetUseToneMapping () |
| void | SetToneMappingType (int) |
| void | SetExposure (double) |
| void | SetContrast (double) |
| void | SetShoulder (double) |
| void | SetMidIn (double) |
| void | SetMidOut (double) |
| void | SetHdrMax (double) |
| void | SetUseACES (bool) |
| void | SetGenericFilmicPresets (int t) |
| virtual void | SetUseSSAO (bool) |
| | SSAO options. More...
| virtual bool | GetUseSSAO () |
| virtual void | SetUseSSAODefaultPresets (bool) |
| virtual void | SetRadius (double) |
| virtual void | SetKernelSize (int) |
| virtual void | SetBias (double) |
| virtual void | SetBlur (bool) |
| void | AddPropToRenderer (vtkProp *prop) |
| | Add props directly to the view. More...
| void | RemovePropFromRenderer (vtkProp *prop) |
| void | SetDrawCells (bool choice) |
| | Tells view that it should draw a particular array component to the screen such that the pixels can be read back and decoded to obtain the values. More...
| void | SetArrayNameToDraw (const char *name) |
| void | SetArrayNumberToDraw (int fieldAttributeType) |
| void | SetArrayComponentToDraw (int comp) |
| void | SetScalarRange (double min, double max) |
| void | BeginValueCapture () |
| void | EndValueCapture () |
| void | SetValueRenderingModeCommand (int mode) |
| | Current rendering mode of vtkValuePass (float or invertible RGB). More...
| int | GetValueRenderingModeCommand () |
| void | CaptureValuesFloat () |
| | Access to vtkValuePass::FLOATING_POINT mode rendered image. More...
| vtkFloatArray * | GetCapturedValuesFloat () |
| void | StartCaptureLuminance () |
| | Tells views that it should draw the lighting contributions to the framebuffer. More...
| void | StopCaptureLuminance () |
| void | CaptureZBuffer () |
| | Access to the Z buffer. More...
| vtkFloatArray * | GetCapturedZBuffer () |
| void | SetEnableOSPRay (bool) |
| | Switches between rasterization and ray tracing. More...
| bool | GetEnableOSPRay () |
| void | SetShadows (bool) |
| | Controls whether OSPRay sends casts shadow rays or not. More...
| bool | GetShadows () |
| void | SetAmbientOcclusionSamples (int) |
| | Sets the number of occlusion query rays that OSPRay sends at each intersection. More...
| int | GetAmbientOcclusionSamples () |
| void | SetRouletteDepth (int) |
| | Sets the depth of monte carlo samples on the path tracer. More...
| int | GetRouletteDepth () |
| void | SetVolumeAnisotropy (double) |
| | Set the path tracers volume anisotropy. More...
| double | GetVolumeAnisotropy () |
| void | SetSamplesPerPixel (int) |
| | Set the number of primary rays that OSPRay shoots per pixel. More...
| int | GetSamplesPerPixel () |
| void | SetMaxFrames (int) |
| | Set the number of render passes OSPRay takes to accumulate subsampled color results. More...
| int | GetMaxFrames () |
| void | SetDenoise (bool) |
| | Controls whether to use image denoising to improve appearance. More...
| bool | GetDenoise () |
| void | SetLightScale (double) |
| | Dimish or Amplify all lights in the scene. More...
| double | GetLightScale () |
| void | SetBackgroundNorth (double x, double y, double z) |
| | Control of background orientation for OSPRay. More...
| void | SetBackgroundEast (double x, double y, double z) |
| void | SetTimeCacheSize (int) |
| | Set the size of OSPRay's temporal cache. More...
| int | GetTimeCacheSize () |
| bool | IsForceDataDistributionModeSet () const |
| | This is an temporary/experimental option and may be removed without notice. More...
| int | GetForceDataDistributionMode () const |
| virtual void | SetPPI (int) |
| | Description: Set the screen PPI. More...
| virtual int | GetPPI () |
| | Overridden to not call Update() directly on the input representations, instead use ProcessViewRequest() for all vtkPVDataRepresentations. More...
| bool | InTileDisplayMode () |
| | Returns true if the application is currently in tile display mode. More...
| bool | InCaveDisplayMode () |
| | Returns true if the application is currently in cave/immersive display mode. More...
| bool | GetLocalProcessSupportsInteraction () |
| | Returns true if the local process can support interaction. More...
| vtkRenderWindow * | GetRenderWindow () |
| | If this view needs a render window (not all views may use one), this method can be used to get the render window associated with this view on the current process. More...
| vtkMTimeType | GetUpdateTimeStamp () |
| | Provides access to the time when Update() was last called. More...
| virtual bool | IsCached (vtkPVDataRepresentation *) |
| | Called in vtkPVDataRepresentation::ProcessViewRequest to check if the representation already has cached data. More...
| virtual void | ClearCache (vtkPVDataRepresentation *) |
| | Called by vtkPVDataRepresentation whenever vtkPVDataRepresentation::MarkModified is called. More...
| virtual int * | GetPosition () |
| | Set the position on this view in the multiview configuration. More...
| virtual void | GetPosition (int &, int &) |
| virtual void | GetPosition (int [2]) |
| virtual int * | GetSize () |
| | Set the size of this view in the multiview configuration. More...
| virtual void | GetSize (int &, int &) |
| virtual void | GetSize (int [2]) |
| virtual double | GetViewTime () |
| virtual void | SetCacheKey (double) |
| | Get/Set the cache key. More...
| virtual double | GetCacheKey () |
| virtual void | SetUseCache (bool) |
| | Get/Set whether caching is enabled. More...
| virtual bool | GetUseCache () |
| virtual void | PrepareForScreenshot () |
| | These methods are used to setup the view for capturing screen shots. More...
| virtual void | CleanupAfterScreenshot () |
| void | SetTileScale (int x, int y) |
| | When saving screenshots with tiling, these methods get called. More...
| void | SetTileViewport (double x0, double y0, double x1, double y1) |
| void | SetDeliveryManager (vtkPVDataDeliveryManager *) |
| | Provides access to data delivery & cache manager for this view. More...
| virtual vtkPVDataDeliveryManager * | GetDeliveryManager () |
| vtkView * | NewInstance () const |
| void | AddRepresentation (vtkDataRepresentation *rep) |
| void | SetRepresentation (vtkDataRepresentation *rep) |
| vtkDataRepresentation * | AddRepresentationFromInputConnection (vtkAlgorithmOutput *conn) |
| vtkDataRepresentation * | SetRepresentationFromInputConnection (vtkAlgorithmOutput *conn) |
| vtkDataRepresentation * | AddRepresentationFromInput (vtkDataObject *input) |
| vtkDataRepresentation * | SetRepresentationFromInput (vtkDataObject *input) |
| void | RemoveRepresentation (vtkDataRepresentation *rep) |
| void | RemoveRepresentation (vtkAlgorithmOutput *rep) |
| void | RemoveAllRepresentations () |
| int | GetNumberOfRepresentations () |
| vtkDataRepresentation * | GetRepresentation (int index=0) |
| bool | IsRepresentationPresent (vtkDataRepresentation *rep) |
| vtkCommand * | GetObserver () |
| void | RegisterProgress (vtkObject *algorithm, const char *message=NULL) |
| void | UnRegisterProgress (vtkObject *algorithm) |
| static vtkPVMultiSliceView * | New () |
| static vtkPVMultiSliceView * | SafeDownCast (vtkObject *o) |
| static void | SetAxisTitle (vtkInformation *info, int axis, const char *title) |
| static void | SetDataBounds (vtkInformation *info, const double bounds[6]) |
| static vtkPVRenderView * | New () |
| static vtkPVRenderView * | SafeDownCast (vtkObject *o) |
| static vtkInformationIntegerKey * | USE_LOD () |
| | USE_LOD indicates if LOD is being used for the current render/update. More...
| static vtkInformationDoubleKey * | LOD_RESOLUTION () |
| | Indicates the LOD resolution in REQUEST_UPDATE_LOD() pass. More...
| static vtkInformationIntegerKey * | USE_OUTLINE_FOR_LOD () |
| | Indicates the LOD must use outline if possible in REQUEST_UPDATE_LOD() pass. More...
| static vtkInformationIntegerKey * | RENDER_EMPTY_IMAGES () |
| | Representation can publish this key in their REQUEST_INFORMATION() pass to indicate that the representation needs to disable IceT's empty image optimization. More...
| static vtkInformationIntegerKey * | NEED_ORDERED_COMPOSITING () |
| | Representation can publish this key in their REQUEST_INFORMATION() pass to indicate that the representation needs ordered compositing. More...
| static vtkInformationDoubleVectorKey * | VIEW_PLANES () |
| | Key used to pass meta-data about the view frustum in REQUEST_STREAMING_UPDATE() pass. More...
| static vtkInformationRequestKey * | REQUEST_STREAMING_UPDATE () |
| | Streaming pass request. More...
| static vtkInformationRequestKey * | REQUEST_PROCESS_STREAMED_PIECE () |
| | Pass to relay the streamed "piece" to the representations. More...
| static void | SetDeliverToAllProcesses (vtkInformation *info, vtkPVDataRepresentation *repr, bool clone) |
| | Requests the view to deliver the pieces produced by the repr to all processes after a gather to the root node to merge the datasets generated by each process. More...
| static void | SetDeliverToClientAndRenderingProcesses (vtkInformation *info, vtkPVDataRepresentation *repr, bool deliver_to_client, bool gather_before_delivery, int port=0) |
| | Requests the view to deliver the data to the client always. More...
| static vtkAlgorithmOutput * | GetPieceProducer (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| | Convenience methods used by representations to pass represented data. More...
| static vtkAlgorithmOutput * | GetPieceProducerLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetRedistributionMode (vtkInformation *info, vtkPVDataRepresentation *repr, int mode, int port=0) |
| static void | SetRedistributionModeToSplitBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetRedistributionModeToDuplicateBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetRedistributionModeToUniquelyAssignBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetGeometryBounds (vtkInformation *info, vtkPVDataRepresentation *repr, const double bounds[6], vtkMatrix4x4 *transform=nullptr, int port=0) |
| static void | SetStreamable (vtkInformation *info, vtkPVDataRepresentation *repr, bool streamable) |
| static void | SetNextStreamedPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *piece) |
| static vtkDataObject * | GetCurrentStreamedPiece (vtkInformation *info, vtkPVDataRepresentation *repr) |
| static void | MarkAsRedistributable (vtkInformation *info, vtkPVDataRepresentation *repr, bool value=true, int port=0) |
| | As of ParaView 5.9, these methods are replaced by SetOrderedCompositingConfiguration which provides a new mechanisms for indicating to the view how this representation participates in data-redistribution needed when ordered-compositing is being used. More...
| static void | SetOrderedCompositingInformation (vtkInformation *info, vtkPVDataRepresentation *repr, vtkExtentTranslator *translator, const int whole_extents[6], const double origin[3], const double spacing[3]) |
| static void | SetOrderedCompositingInformation (vtkInformation *info, const double bounds[6]) |
| static void | SetRequiresDistributedRendering (vtkInformation *info, vtkPVDataRepresentation *repr, bool value, bool for_lod=false) |
| | Some representation only work when remote rendering or local rendering. More...
| static void | SetRequiresDistributedRenderingLOD (vtkInformation *info, vtkPVDataRepresentation *repr, bool value) |
| static vtkPVCameraCollection * | GetDiscreteCameras (vtkInformation *info, vtkPVDataRepresentation *repr) |
| | DiscreteCameras are a collection of cameras when specified, forces the view to only interact to a camera in the collection. More...
| static void | SetDiscreteCameras (vtkInformation *info, vtkPVDataRepresentation *repr, vtkPVCameraCollection *style) |
| static void | SetOrderedCompositingConfiguration (vtkInformation *info, vtkPVDataRepresentation *repr, int config, const double *bounds=nullptr, int port=0) |
| | OrderedCompositingConfiguration lets representations indicate to the view how the representation participates in data-redistribution necessary when ordered-compositing is being used. More...
| static void | SetForceDataDistributionMode (vtkInformation *info, int flag) |
| static vtkPVView * | SafeDownCast (vtkObject *o) |
| static void | SetEnableStreaming (bool) |
| static bool | GetEnableStreaming () |
| static vtkInformationObjectBaseKey * | VIEW () |
| | Key used to pass the vtkPVView pointer to the representation during any of the view passes such as REQUEST_UPDATE(), REQUEST_UPDATE_LOD(), REQUEST_RENDER(), etc. More...
| static vtkInformationRequestKey * | REQUEST_UPDATE () |
| | This is a Update-Data pass. More...
| static vtkInformationRequestKey * | REQUEST_UPDATE_LOD () |
| | This is a Update-LOD-Data pass. More...
| static vtkInformationRequestKey * | REQUEST_RENDER () |
| | This is a render pass. More...
| static void | SetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0) |
| static vtkDataObject * | GetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static vtkDataObject * | GetDeliveredPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0) |
| static vtkDataObject * | GetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static vtkDataObject * | GetDeliveredPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetUseGenericOpenGLRenderWindow (bool val) |
| | Use this to indicate that the process should use vtkGenericOpenGLRenderWindow rather than vtkRenderWindow when creating an new render window. More...
| static bool | GetUseGenericOpenGLRenderWindow () |
| static vtkView * | New () |
| static vtkView * | SafeDownCast (vtkObjectBase *o) |
