vtkPVMultiSliceView.h
3  Program: ParaView
4  Module: vtkPVMultiSliceView.h
5
6  Copyright (c) Kitware, Inc.
7  All rights reserved.
8  See Copyright.txt or http://www.paraview.org/HTML/Copyright.html for details.
9
10  This software is distributed WITHOUT ANY WARRANTY; without even
11  the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
12  PURPOSE. See the above copyright notice for more information.
13
14 =========================================================================*/
22 #ifndef vtkPVMultiSliceView_h
23 #define vtkPVMultiSliceView_h
24
25 #include "vtkNew.h" // needed for vtkNew
26 #include "vtkPVRenderView.h"
27 #include "vtkRemotingViewsModule.h" //needed for exports
28 #include <vector> // needed for std::vector
31 class vtkMatrix4x4;
32
33 class VTKREMOTINGVIEWS_EXPORT vtkPVMultiSliceView : public vtkPVRenderView
34 {
35 public:
36  static vtkPVMultiSliceView* New();
38  void PrintSelf(ostream& os, vtkIndent indent) override;
40  void Update() override;
41
42  void SetNumberOfXSlices(unsigned int count) { this->SetNumberOfSlices(0, count); }
43  void SetXSlices(const double* values) { this->SetSlices(0, values); }
44  void SetNumberOfYSlices(unsigned int count) { this->SetNumberOfSlices(1, count); }
45  void SetYSlices(const double* values) { this->SetSlices(1, values); }
46  void SetNumberOfZSlices(unsigned int count) { this->SetNumberOfSlices(2, count); }
47  void SetZSlices(const double* values) { this->SetSlices(2, values); }
48
49  const std::vector<double>& GetSlices(int axis) const;
50  const std::vector<double>& GetXSlices() const { return this->GetSlices(0); }
51  const std::vector<double>& GetYSlices() const { return this->GetSlices(1); }
52  const std::vector<double>& GetZSlices() const { return this->GetSlices(2); }
53
54  void GetDataBounds(double bounds[6]) const;
55
56  // These return NULL when no overrides were specified.
57  const char* GetXAxisLabel() const { return this->GetAxisLabel(0); }
58  const char* GetYAxisLabel() const { return this->GetAxisLabel(1); }
59  const char* GetZAxisLabel() const { return this->GetAxisLabel(2); }
60
61  const vtkClientServerStream& GetAxisLabels() const;
62
63  // Convenience methods used by representations to pass information to the view
64  // in vtkPVView::REQUEST_UPDATE() pass. SetAxisTitle can be used to tell the
65  // view if the representation's data has information about titles to use for
66  // each of the axis. SetDataBounds can be used to tell the view the raw data
67  // bounds which are to be use when showing the slice-sliders.
68  static void SetAxisTitle(vtkInformation* info, int axis, const char* title);
69  static void SetDataBounds(vtkInformation* info, const double bounds[6]);
70
71  void SetModelTransformationMatrix(vtkMatrix4x4*);
72
73 protected:
75  ~vtkPVMultiSliceView() override;
76
77  void AboutToRenderOnLocalProcess(bool interactive) override;
78
79  void SetNumberOfSlices(int type, unsigned int count);
80  void SetSlices(int type, const double* values);
81  const char* GetAxisLabel(int axis) const;
83
85
86 private:
88  void operator=(const vtkPVMultiSliceView&) = delete;
89
90  class vtkSliceInternal;
91  vtkSliceInternal* Internal;
92 };
93
94 #endif
void SetXSlices(const double *values)
type
virtual void AboutToRenderOnLocalProcess(bool interactive)
Called just before the local process renders.
void SetZSlices(const double *values)
const char * GetZAxisLabel() const
const std::vector< double > & GetYSlices() const
info
Overridden to synchronize information among processes whenever data changes.
Store messages for the interpreter.
const std::vector< double > & GetXSlices() const
vtkTimeStamp ModelTransformationMatrixUpdateTime
vtkPVMultiSliceView extends vtkPVRenderView but add meta-data information used by SliceRepresentation...
const char * GetYAxisLabel() const
vtkNew< vtkMatrix4x4 > ModelTransformationMatrix
static vtkPVRenderView * New()
void SetYSlices(const double *values)
const char * GetXAxisLabel() const
const std::vector< double > & GetZSlices() const
Render View for ParaView.
title
