coordinates rendering between corresponding renderers across multiple processes More...
#include <vtkPVSynchronizedRenderer.h>
| void | Initialize (vtkPVSession *session) |
| Must be called once to initialize the instance. More... | |
| void | SetOrderedCompositingHelper (vtkOrderedCompositingHelper *helper) |
| Used to determine sorting order and use ordered compositing. More... | |
| void | SetRenderer (vtkRenderer *) |
| Set the renderer that is being synchronized. More... | |
| void | SetUseDepthBuffer (bool) |
| Activates or de-activated the use of Depth Buffer in an ImageProcessingPass. More... | |
| void | SetRenderEmptyImages (bool) |
| Enable/Disable empty images optimization. More... | |
| void | SetNVPipeSupport (bool) |
| Enable/Disable NVPipe. More... | |
| virtual void | SetDisableIceT (bool) |
| Set this flag to true before calling Initialize() to disable using vtkIceTSynchronizedRenderers for parallel rendering. More... | |
| virtual bool | GetDisableIceT () |
| virtual void | SetEnabled (bool enabled) |
| Enable/Disable parallel rendering. More... | |
| virtual bool | GetEnabled () |
| virtual void | EnabledOn () |
| virtual void | EnabledOff () |
| void | SetImageReductionFactor (int) |
| Get/Set the image reduction factor. More... | |
| virtual int | GetImageReductionFactor () |
| void | SetDataReplicatedOnAllProcesses (bool) |
| Set to true if data is replicated on all processes. More... | |
| virtual bool | GetDataReplicatedOnAllProcesses () |
| virtual void | DataReplicatedOnAllProcessesOn () |
| virtual void | DataReplicatedOnAllProcessesOff () |
| void | SetImageProcessingPass (vtkImageProcessingPass *) |
| Get/Set an image processing pass to process the rendered images. More... | |
| virtual vtkImageProcessingPass * | GetImageProcessingPass () |
| void | SetRenderPass (vtkRenderPass *) |
| Get/Set geometry rendering pass. More... | |
| virtual vtkRenderPass * | GetRenderPass () |
| void | ConfigureCompressor (const char *configuration) |
| Passes the compressor configuration to the client-server synchronizer, if any. More... | |
| void | SetLossLessCompression (bool) |
| void | SetEnableRayTracing (bool val) |
| State flags to turn on specialized treatment for ray tracing. More... | |
| virtual bool | GetEnableRayTracing () |
| void | SetEnablePathTracing (bool val) |
| virtual bool | GetEnablePathTracing () |
| virtual vtkSynchronizedRenderers * | GetParallelSynchronizer () |
| Not for the faint hearted. More... | |
| virtual vtkSynchronizedRenderers * | GetCSSynchronizer () |
| static vtkPVSynchronizedRenderer * | New () |
| static vtkPVSynchronizedRenderer * | SafeDownCast (vtkObject *o) |
| vtkPVSynchronizedRenderer () | |
| ~vtkPVSynchronizedRenderer () override | |
| virtual void | SetupPasses () |
| Sets up the render passes on the renderer. More... | |
Protected Attributes | |
| vtkSynchronizedRenderers * | CSSynchronizer |
| vtkSynchronizedRenderers * | ParallelSynchronizer |
| vtkImageProcessingPass * | ImageProcessingPass |
| vtkRenderPass * | RenderPass |
| bool | Enabled |
| bool | DisableIceT |
| int | ImageReductionFactor |
| vtkOpenGLRenderer * | Renderer |
| bool | UseDepthBuffer |
| bool | RenderEmptyImages |
| bool | DataReplicatedOnAllProcesses |
| bool | EnableRayTracing |
| bool | EnablePathTracing |
vtkPVSynchronizedRenderer coordinates rendering between renderers that are split across multiple ranks. It internally uses other vtkSynchronizedRenderers subclasses based on the operation mode to do the actual coordination such as vtkCaveSynchronizedRenderers, vtkIceTSynchronizedRenderers, vtkPVClientServerSynchronizedRenderers and vtkCompositedSynchronizedRenderers.
Definition at line 44 of file vtkPVSynchronizedRenderer.h.
Definition at line 48 of file vtkPVSynchronizedRenderer.h.
Default value is setup using vtkPVRenderViewSettings::GetDisableIceT.
| void vtkPVSynchronizedRenderer::Initialize | ( | vtkPVSession * | session | ) |
This will create appropriate internal vtkSynchronizedRenderers subclasses based on the process type and session provided.
| void vtkPVSynchronizedRenderer::SetOrderedCompositingHelper | ( | vtkOrderedCompositingHelper * | helper | ) |
Set to nullptr to not use ordered compositing and instead use depth-buffer based compositing, if applicable.
| void vtkPVSynchronizedRenderer::SetRenderer | ( | vtkRenderer * | ) |
| void vtkPVSynchronizedRenderer::SetImageReductionFactor | ( | int | ) |
This needs to be set on all processes and must match up.
| void vtkPVSynchronizedRenderer::SetDataReplicatedOnAllProcesses | ( | bool | ) |
This will enable IceT to minimize communications since data is available on all process. Off by default.
| void vtkPVSynchronizedRenderer::SetImageProcessingPass | ( | vtkImageProcessingPass * | ) |
| void vtkPVSynchronizedRenderer::SetRenderPass | ( | vtkRenderPass * | ) |
This pass is used to render the geometry. If none specified then default rendering pipeline is used. This is typically the render-pass pipeline after the CameraPass. The CameraPass is setup by ParaView specially since ParaView needs some customizations for multiviews/icet etc.
| void vtkPVSynchronizedRenderer::ConfigureCompressor | ( | const char * | configuration | ) |
This affects the image compression used to relay images back to the client. See vtkPVClientServerSynchronizedRenderers::ConfigureCompressor() for details.
| void vtkPVSynchronizedRenderer::SetLossLessCompression | ( | bool | ) |
| void vtkPVSynchronizedRenderer::SetUseDepthBuffer | ( | bool | ) |
| void vtkPVSynchronizedRenderer::SetRenderEmptyImages | ( | bool | ) |
| void vtkPVSynchronizedRenderer::SetNVPipeSupport | ( | bool | ) |
| void vtkPVSynchronizedRenderer::SetEnableRayTracing | ( | bool | val | ) |
| void vtkPVSynchronizedRenderer::SetEnablePathTracing | ( | bool | val | ) |
This internal vtkSynchronizedRenderers instances are exposed for advanced users that want to do advanced tricks with rendering. These will change without notice. Do not use them unless you know what you are doing. ParallelSynchronizer is the vtkSynchronizedRenderers used to synchronize rendering between processes in an MPI group – typically vtkIceTSynchronizedRenderers when available. CSSynchronizer is the client-server vtkSynchronizedRenderers used in client-server configurations.
protectedvirtual |
This won't get called on processes where vtkIceTSynchronizedRenderers is used. In that case the passes are forwarded to the vtkIceTSynchronizedRenderers instance.
Definition at line 193 of file vtkPVSynchronizedRenderer.h.
Definition at line 194 of file vtkPVSynchronizedRenderer.h.
Definition at line 195 of file vtkPVSynchronizedRenderer.h.
Definition at line 196 of file vtkPVSynchronizedRenderer.h.
Definition at line 198 of file vtkPVSynchronizedRenderer.h.
Definition at line 199 of file vtkPVSynchronizedRenderer.h.
Definition at line 200 of file vtkPVSynchronizedRenderer.h.
Definition at line 201 of file vtkPVSynchronizedRenderer.h.
Definition at line 203 of file vtkPVSynchronizedRenderer.h.
Definition at line 204 of file vtkPVSynchronizedRenderer.h.
Definition at line 205 of file vtkPVSynchronizedRenderer.h.
Definition at line 207 of file vtkPVSynchronizedRenderer.h.
Definition at line 208 of file vtkPVSynchronizedRenderer.h.
