| void | ShallowCopy (vtkProp *prop) override |
| | Shallow copy from another vtkPVGridAxes3DActor. More...
| virtual void | SetDataPosition (double, double, double) |
| virtual void | SetDataPosition (double [3]) |
| virtual double * | GetDataPosition () |
| virtual void | GetDataPosition (double &, double &, double &) |
| virtual void | GetDataPosition (double [3]) |
| virtual void | SetUseModelTransform (bool) |
| virtual bool | GetUseModelTransform () |
| virtual void | UseModelTransformOn () |
| virtual void | UseModelTransformOff () |
| virtual void | SetModelBounds (double, double, double, double, double, double) |
| virtual void | SetModelBounds (double [6]) |
| virtual double * | GetModelBounds () |
| virtual void | GetModelBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetModelBounds (double [6]) |
| void | SetModelTransformMatrix (double *matrix) |
| double * | GetBounds () override |
| | Overridden to ensure that the transform information is passed on the superclass. More...
| virtual void | SetDataScale (double, double, double) |
| | Specify transformation used by the data. More...
| virtual void | SetDataScale (double [3]) |
| virtual double * | GetDataScale () |
| virtual void | GetDataScale (double &, double &, double &) |
| virtual void | GetDataScale (double [3]) |
| virtual void | SetDataBoundsScaleFactor (double) |
| | Specify the scale factor used to proportionally scale each axis. More...
| virtual double | GetDataBoundsScaleFactor () |
| virtual void | SetTransformedBounds (double, double, double, double, double, double) |
| | Another way for specifying grid bounds except here the bounds are considered to be pre-transformed. More...
| virtual void | SetTransformedBounds (double [6]) |
| virtual double * | GetTransformedBounds () |
| virtual void | GetTransformedBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetTransformedBounds (double [6]) |
| virtual void | SetUseCustomTransformedBounds (bool) |
| | If set to true, CustomTransformedBounds are used instead of TransformedBounds. More...
| virtual bool | GetUseCustomTransformedBounds () |
| virtual void | SetCustomTransformedBounds (double, double, double, double, double, double) |
| | Same as TransformedBounds, except used only when UseCustomTransformedBounds is set. More...
| virtual void | SetCustomTransformedBounds (double [6]) |
| virtual double * | GetCustomTransformedBounds () |
| virtual void | GetCustomTransformedBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetCustomTransformedBounds (double [6]) |
| void | GetActors (vtkPropCollection *) override |
| | For some exporters and other other operations we must be able to collect all the actors or volumes. More...
| void | UpdateGeometry (vtkViewport *vp) |
| | Updates the billboard geometry without performing any rendering, to assist GetActors(). More...
| void | SetUseCustomLabels (int axis, bool val) |
| | Set whether the specified axis should use custom labels instead of automatically determined ones. More...
| void | SetXUseCustomLabels (bool val) |
| void | SetYUseCustomLabels (bool val) |
| void | SetZUseCustomLabels (bool val) |
| void | SetNumberOfLabels (int axis, vtkIdType val) |
| void | SetNumberOfXLabels (vtkIdType val) |
| void | SetNumberOfYLabels (vtkIdType val) |
| void | SetNumberOfZLabels (vtkIdType val) |
| void | SetLabel (int axis, vtkIdType index, double value) |
| void | SetXLabel (vtkIdType index, double value) |
| void | SetYLabel (vtkIdType index, double value) |
| void | SetZLabel (vtkIdType index, double value) |
| virtual void | GetRenderedBounds (double bounds[6]) |
| | Get an bounding box that is expected to contain all rendered elements, since GetBounds() returns the bounding box the grid axes describes. More...
| int | RenderOpaqueGeometry (vtkViewport *) override |
| int | RenderTranslucentPolygonalGeometry (vtkViewport *viewport) override |
| int | RenderOverlay (vtkViewport *viewport) override |
| int | HasTranslucentPolygonalGeometry () override |
| void | ReleaseGraphicsResources (vtkWindow *) override |
| virtual void | SetGridBounds (double, double, double, double, double, double) |
| | Set the bounding box defining the grid space. More...
| virtual void | SetGridBounds (double [6]) |
| virtual double * | GetGridBounds () |
| virtual void | GetGridBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetGridBounds (double [6]) |
| virtual void | SetFaceMask (unsigned int mask) |
| | Set the mask to select faces. More...
| virtual unsigned int | GetFaceMask () |
| virtual void | SetLabelMask (unsigned int mask) |
| | Set the axis to label. More...
| unsigned int | GetLabelMask () |
| virtual void | SetLabelUniqueEdgesOnly (bool) |
| | Set to true to only label edges shared with 1 face. More...
| virtual bool | GetLabelUniqueEdgesOnly () |
| void | SetGenerateGrid (bool val) |
| | Turn off to not generate polydata for the plane's grid. More...
| bool | GetGenerateGrid () |
| virtual void | GenerateGridOn () |
| virtual void | GenerateGridOff () |
| void | SetGenerateEdges (bool val) |
| | Turn off to not generate the polydata for the plane's edges. More...
| bool | GetGenerateEdges () |
| virtual void | GenerateEdgesOn () |
| virtual void | GenerateEdgesOff () |
| void | SetGenerateTicks (bool val) |
| | Turn off to not generate the markers for the tick positions. More...
| bool | GetGenerateTicks () |
| virtual void | GenerateTicksOn () |
| virtual void | GenerateTicksOff () |
| void | SetProperty (vtkProperty *) |
| | Get/Set the property used to control the appearance of the rendered grid. More...
| vtkProperty * | GetProperty () |
| void | SetTitleTextProperty (int axis, vtkTextProperty *) |
| | Get/Set the vtkTextProperty for the title for each the axes. More...
| void | SetXTitleTextProperty (vtkTextProperty *prop) |
| void | SetYTitleTextProperty (vtkTextProperty *prop) |
| void | SetZTitleTextProperty (vtkTextProperty *prop) |
| vtkTextProperty * | GetTitleTextProperty (int axis) |
| void | SetTitle (int axis, const std::string &title) |
| | Get/Set the text to use for titles for the axis. More...
| void | SetXTitle (const std::string &title) |
| void | SetYTitle (const std::string &title) |
| void | SetZTitle (const std::string &title) |
| const std::string & | GetTitle (int axis) |
| void | SetLabelTextProperty (int axis, vtkTextProperty *) |
| | Get/Set the vtkTextProperty that governs how the axis labels are displayed. More...
| void | SetXLabelTextProperty (vtkTextProperty *prop) |
| void | SetYLabelTextProperty (vtkTextProperty *prop) |
| void | SetZLabelTextProperty (vtkTextProperty *prop) |
| vtkTextProperty * | GetLabelTextProperty (int axis) |
| void | SetNotation (int axis, int notation) |
| | Get/set the numerical notation, standard, scientific or mixed (0, 1, 2). More...
| void | SetXNotation (int notation) |
| void | SetYNotation (int notation) |
| void | SetZNotation (int notation) |
| int | GetNotation (int axis) |
| void | SetPrecision (int axis, int val) |
| | Get/set the numerical precision to use, default is 2. More...
| void | SetXPrecision (int val) |
| void | SetYPrecision (int val) |
| void | SetZPrecision (int val) |
| int | GetPrecision (int axis) |
| virtual void | SetForceOpaque (bool) |
| | If true, the actor will always be rendered during the opaque pass. More...
| virtual bool | GetForceOpaque () |
| virtual void | ForceOpaqueOn () |
| virtual void | ForceOpaqueOff () |
| vtkProp3D * | NewInstance () const |
| virtual void | SetPosition (double pos[3]) |
| virtual double * | GetPosition () |
| virtual void | GetPosition (double data[3]) |
| void | AddPosition (double deltaPosition[3]) |
| void | AddPosition (double deltaX, double deltaY, double deltaZ) |
| double * | GetCenter () |
| double * | GetXRange () |
| double * | GetYRange () |
| double * | GetZRange () |
| double | GetLength () |
| void | RotateX (double) |
| void | RotateY (double) |
| void | RotateZ (double) |
| void | RotateWXYZ (double w, double x, double y, double z) |
| void | SetOrientation (double x, double y, double z) |
| void | SetOrientation (double orientation[3]) |
| double * | GetOrientationWXYZ () |
| void | AddOrientation (double x, double y, double z) |
| void | AddOrientation (double orentation[3]) |
| void | PokeMatrix (vtkMatrix4x4 *matrix) |
| void | InitPathTraversal () |
| vtkMTimeType | GetMTime () |
| vtkMTimeType | GetUserTransformMatrixMTime () |
| virtual void | ComputeMatrix () |
| virtual void | SetPosition (double x, double y, double z) |
| virtual void | SetOrigin (double x, double y, double z) |
| virtual void | SetOrigin (const double pos[3]) |
| virtual double * | GetOrigin () |
| virtual void | GetOrigin (double data[3]) |
| virtual void | SetScale (double x, double y, double z) |
| virtual void | SetScale (double scale[3]) |
| virtual double * | GetScale () |
| virtual void | GetScale (double data[3]) |
| void | SetScale (double s) |
| void | SetUserTransform (vtkLinearTransform *transform) |
| virtual vtkLinearTransform * | GetUserTransform () |
| void | SetUserMatrix (vtkMatrix4x4 *matrix) |
| vtkMatrix4x4 * | GetUserMatrix () |
| virtual void | GetMatrix (vtkMatrix4x4 *m) |
| virtual void | GetMatrix (double m[16]) |
| void | GetBounds (double bounds[6]) |
| double * | GetOrientation () |
| void | GetOrientation (double orentation[3]) |
| vtkMatrix4x4 * | GetMatrix () |
| virtual int | GetIsIdentity () |
| vtkProp * | NewInstance () const |
| virtual void | Pick () |
| virtual bool | HasKeys (vtkInformation *requiredKeys) |
| virtual void | BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path) |
| virtual void | GetActors2D (vtkPropCollection *) |
| virtual void | GetVolumes (vtkPropCollection *) |
| virtual void | SetVisibility (int) |
| virtual int | GetVisibility () |
| virtual void | VisibilityOn () |
| virtual void | VisibilityOff () |
| virtual void | SetPickable (int) |
| virtual int | GetPickable () |
| virtual void | PickableOn () |
| virtual void | PickableOff () |
| virtual void | SetDragable (int) |
| virtual int | GetDragable () |
| virtual void | DragableOn () |
| virtual void | DragableOff () |
| virtual vtkMTimeType | GetRedrawMTime () |
| virtual void | SetUseBounds (bool) |
| virtual bool | GetUseBounds () |
| virtual void | UseBoundsOn () |
| virtual void | UseBoundsOff () |
| virtual vtkAssemblyPath * | GetNextPath () |
| virtual int | GetNumberOfPaths () |
| virtual void | PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix)) |
| virtual vtkInformation * | GetPropertyKeys () |
| virtual void | SetPropertyKeys (vtkInformation *keys) |
| virtual int | RenderVolumetricGeometry (vtkViewport *) |
| virtual bool | RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual double | GetEstimatedRenderTime (vtkViewport *) |
| virtual double | GetEstimatedRenderTime () |
| virtual void | SetEstimatedRenderTime (double t) |
| virtual void | RestoreEstimatedRenderTime () |
| virtual void | AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp)) |
| virtual void | SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v)) |
| virtual double | GetAllocatedRenderTime () |
| void | SetRenderTimeMultiplier (double t) |
| virtual double | GetRenderTimeMultiplier () |
| virtual bool | GetSupportsSelection () |
| virtual int | GetNumberOfConsumers () |
| void | AddConsumer (vtkObject *c) |
| void | RemoveConsumer (vtkObject *c) |
| vtkObject * | GetConsumer (int i) |
| int | IsConsumer (vtkObject *c) |
