| void | SetSymmetric (int) |
| | If Symmetric is on, the the axis continue to negative values. More...
| void | SetComputeNormals (int) |
| | Option for computing normals. More...
| vtkOpenGLActor * | NewInstance () const |
| void | Render (vtkRenderer *ren, vtkMapper *mapper) |
| void | GetKeyMatrices (vtkMatrix4x4 *&WCVCMatrix, vtkMatrix3x3 *&normalMatrix) |
| vtkActor * | NewInstance () const |
| virtual void | GetActors (vtkPropCollection *) |
| virtual int | HasTranslucentPolygonalGeometry () |
| void | ShallowCopy (vtkProp *prop) |
| void | ReleaseGraphicsResources (vtkWindow *) |
| virtual vtkProperty * | MakeProperty () |
| virtual void | SetMapper (vtkMapper *) |
| virtual void | ApplyProperties () |
| vtkMTimeType | GetMTime () |
| virtual vtkMTimeType | GetRedrawMTime () |
| virtual bool | GetSupportsSelection () |
| virtual int | RenderOpaqueGeometry (vtkViewport *viewport) |
| virtual int | RenderTranslucentPolygonalGeometry (vtkViewport *viewport) |
| void | SetProperty (vtkProperty *lut) |
| vtkProperty * | GetProperty () |
| void | SetBackfaceProperty (vtkProperty *lut) |
| virtual vtkProperty * | GetBackfaceProperty () |
| virtual void | SetTexture (vtkTexture *) |
| virtual vtkTexture * | GetTexture () |
| virtual vtkMapper * | GetMapper () |
| void | GetBounds (double bounds[6]) |
| double * | GetBounds () |
| virtual bool | GetForceOpaque () |
| virtual void | SetForceOpaque (bool) |
| virtual void | ForceOpaqueOn () |
| virtual void | ForceOpaqueOff () |
| virtual bool | GetForceTranslucent () |
| virtual void | SetForceTranslucent (bool) |
| virtual void | ForceTranslucentOn () |
| virtual void | ForceTranslucentOff () |
| vtkProp3D * | NewInstance () const |
| virtual void | SetPosition (double pos[3]) |
| virtual double * | GetPosition () |
| virtual void | GetPosition (double data[3]) |
| void | AddPosition (double deltaPosition[3]) |
| void | AddPosition (double deltaX, double deltaY, double deltaZ) |
| double * | GetCenter () |
| double * | GetXRange () |
| double * | GetYRange () |
| double * | GetZRange () |
| double | GetLength () |
| void | RotateX (double) |
| void | RotateY (double) |
| void | RotateZ (double) |
| void | RotateWXYZ (double w, double x, double y, double z) |
| void | SetOrientation (double x, double y, double z) |
| void | SetOrientation (double orientation[3]) |
| double * | GetOrientationWXYZ () |
| void | AddOrientation (double x, double y, double z) |
| void | AddOrientation (double orentation[3]) |
| void | PokeMatrix (vtkMatrix4x4 *matrix) |
| void | InitPathTraversal () |
| vtkMTimeType | GetUserTransformMatrixMTime () |
| virtual void | ComputeMatrix () |
| virtual void | SetPosition (double x, double y, double z) |
| virtual void | SetOrigin (double x, double y, double z) |
| virtual void | SetOrigin (const double pos[3]) |
| virtual double * | GetOrigin () |
| virtual void | GetOrigin (double data[3]) |
| virtual void | SetScale (double x, double y, double z) |
| virtual void | SetScale (double scale[3]) |
| virtual double * | GetScale () |
| virtual void | GetScale (double data[3]) |
| void | SetScale (double s) |
| void | SetUserTransform (vtkLinearTransform *transform) |
| virtual vtkLinearTransform * | GetUserTransform () |
| void | SetUserMatrix (vtkMatrix4x4 *matrix) |
| vtkMatrix4x4 * | GetUserMatrix () |
| virtual void | GetMatrix (vtkMatrix4x4 *m) |
| virtual void | GetMatrix (double m[16]) |
| double * | GetOrientation () |
| void | GetOrientation (double orentation[3]) |
| vtkMatrix4x4 * | GetMatrix () |
| virtual int | GetIsIdentity () |
| vtkProp * | NewInstance () const |
| virtual void | Pick () |
| virtual bool | HasKeys (vtkInformation *requiredKeys) |
| virtual void | BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path) |
| virtual void | GetActors2D (vtkPropCollection *) |
| virtual void | GetVolumes (vtkPropCollection *) |
| virtual void | SetVisibility (int) |
| virtual int | GetVisibility () |
| virtual void | VisibilityOn () |
| virtual void | VisibilityOff () |
| virtual void | SetPickable (int) |
| virtual int | GetPickable () |
| virtual void | PickableOn () |
| virtual void | PickableOff () |
| virtual void | SetDragable (int) |
| virtual int | GetDragable () |
| virtual void | DragableOn () |
| virtual void | DragableOff () |
| virtual void | SetUseBounds (bool) |
| virtual bool | GetUseBounds () |
| virtual void | UseBoundsOn () |
| virtual void | UseBoundsOff () |
| virtual vtkAssemblyPath * | GetNextPath () |
| virtual int | GetNumberOfPaths () |
| virtual void | PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix)) |
| virtual vtkInformation * | GetPropertyKeys () |
| virtual void | SetPropertyKeys (vtkInformation *keys) |
| virtual int | RenderVolumetricGeometry (vtkViewport *) |
| virtual int | RenderOverlay (vtkViewport *) |
| virtual bool | RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual double | GetEstimatedRenderTime (vtkViewport *) |
| virtual double | GetEstimatedRenderTime () |
| virtual void | SetEstimatedRenderTime (double t) |
| virtual void | RestoreEstimatedRenderTime () |
| virtual void | AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp)) |
| virtual void | SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v)) |
| virtual double | GetAllocatedRenderTime () |
| void | SetRenderTimeMultiplier (double t) |
| virtual double | GetRenderTimeMultiplier () |
| virtual int | GetNumberOfConsumers () |
| void | AddConsumer (vtkObject *c) |
| void | RemoveConsumer (vtkObject *c) |
| vtkObject * | GetConsumer (int i) |
| int | IsConsumer (vtkObject *c) |
vtkPVCenterAxesActor is an actor for the center-axes used in ParaView.
It merely uses vtkAxes as the poly data source.
Definition at line 31 of file vtkPVCenterAxesActor.h.
