| | pqSplinePropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, ModeTypes mode=SPLINE, QWidget *parent=0) |
| | ~pqSplinePropertyWidget () override |
| QList< QVariant > | points () const |
| | Get/Set the points that form the spline. More...
| void | setPoints (const QList< QVariant > &points) |
| int | currentRow () const |
| void | setCurrentRow (int idx) |
| | pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=0) |
| | ~pqInteractivePropertyWidget () override |
| void | reset () override |
| | Overridden to call this->render() to ensure that the widget is redrawn. More...
| vtkSMNewWidgetRepresentationProxy * | widgetProxy () const |
| | Returns the proxy for the interactive widget. More...
| void | setView (pqView *view) override |
| | Overridden to show the widget proxy in the new view. More...
| bool | isWidgetVisible () const |
| | Returns the interactive widget's visibility. More...
| vtkSMProxy * | dataSource () const |
| | Returns the data source. More...
| void | select () override |
| | In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
| void | deselect () override |
| vtkBoundingBox | dataBounds () const |
| | Returns bounds from the dataSource, if possible. More...
| vtkSMPropertyGroup * | propertyGroup () const |
| | Returns the vtkSMPropertyGroup pass to the constructor. More...
| void | hideEvent (QHideEvent *) override |
| | Overriden in order to hide the VTK widget. More...
| void | showEvent (QShowEvent *) override |
| | Overriden in order to show the VTK widget. More...
| | pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) |
| | ~pqPropertyWidget () override |
| virtual void | apply () |
| pqView * | view () const |
| | Forward calls to vtkSMProperty. More...
| | Determines if the PropertyWidget must be constructed using a single row. More...
| bool | showLabel () const |
| | Provides access to the decorators for this widget. More...
| template<class T > |
| bool | VisibleState = true |
pqSplinePropertyWidget is a custom property widget that uses "SplineWidgetRepresentation" to help users interactively set points that form a spline.
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveSpline" as the "panel_widget" in the XML configuration. The property group can have properties for following functions:
HandlePositions: a repeatable 3-tuple vtkSMDoubleVectorProperty that corresponds to the property used to set the selected spline points.
Closed: (optional) a 1-tuple vtkSMIntVectorProperty that corresponds to the boolean flag indicating if the spline should be closed at end points.
Input: (optional) a vtkSMInputProperty that is used to get data information for bounds when placing/resetting the widget. This widget can also be used for a poly-line instead of a spline. For this mode, use "InteractivePolyLine" as the "panel_widget" in the XML configuration.
Definition at line 56 of file pqSplinePropertyWidget.h.
