pqScalarValueListPropertyWidget provides a table widget to which users are add values e.g.
#include <pqScalarValueListPropertyWidget.h>
| | called to set the active view. More...
| template<class T > |
for IsoValues for the Contour filter.
Definition at line 47 of file pqScalarValueListPropertyWidget.h.
◆ pqScalarValueListPropertyWidget()
| pqScalarValueListPropertyWidget::pqScalarValueListPropertyWidget |
vtkSMProperty * |
property, |
vtkSMProxy * |
proxy, |
QWidget * |
parent = 0 |
◆ ~pqScalarValueListPropertyWidget()
| pqScalarValueListPropertyWidget::~pqScalarValueListPropertyWidget |
◆ setScalars()
| void pqScalarValueListPropertyWidget::setScalars |
const QVariantList & |
scalars | ) |
◆ scalars()
| QVariantList pqScalarValueListPropertyWidget::scalars |
const |
◆ setRangeDomain() [1/2]
Sets range domain that will be used to initialize the scalar range.
◆ setRangeDomain() [2/2]
◆ setShowLabels()
| void pqScalarValueListPropertyWidget::setShowLabels |
bool |
◆ setLabels()
| void pqScalarValueListPropertyWidget::setLabels |
std::vector< const char *> & |
◆ scalarsChanged
| void pqScalarValueListPropertyWidget::scalarsChanged |
signal |
◆ scalars
readwrite |
