pqLightPropertyWidget is a custom property widget that uses "LightWidgetRepresentation" to help users interactively set a light properties in space. More...
#include <pqLightPropertyWidget.h>
| pqLightPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=0) | |
| ~pqLightPropertyWidget () override | |
Public Member Functions inherited from pqInteractivePropertyWidget | |
| pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=0) | |
| ~pqInteractivePropertyWidget () override | |
| void | reset () override |
| Overridden to call this->render() to ensure that the widget is redrawn. More... | |
| vtkSMNewWidgetRepresentationProxy * | widgetProxy () const |
| Returns the proxy for the interactive widget. More... | |
| void | setView (pqView *view) override |
| Overridden to show the widget proxy in the new view. More... | |
| bool | isWidgetVisible () const |
| Returns the interactive widget's visibility. More... | |
| vtkSMProxy * | dataSource () const |
| Returns the data source. More... | |
| void | select () override |
| In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More... | |
| void | deselect () override |
| vtkBoundingBox | dataBounds () const |
| Returns bounds from the dataSource, if possible. More... | |
| vtkSMPropertyGroup * | propertyGroup () const |
| Returns the vtkSMPropertyGroup pass to the constructor. More... | |
| void | hideEvent (QHideEvent *) override |
| Overriden in order to hide the VTK widget. More... | |
| void | showEvent (QShowEvent *) override |
| Overriden in order to show the VTK widget. More... | |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| pqView * | view () const |
| bool | showLabel () const |
Protected Slots | |
| void | placeWidget () override |
| void | updateVisibilityState () |
| Update the visibility state of the different elements of the property widget. More... | |
Protected Slots inherited from pqInteractivePropertyWidget | |
| virtual void | placeWidget ()=0 |
| Places the interactive widget using current data source information. More... | |
| void | render () |
| Safe call render on the view. More... | |
Public Slots inherited from pqInteractivePropertyWidget | |
| void | setWidgetVisible (bool val) |
| Toggle the interactive widget's visibility. More... | |
| void | setDataSource (vtkSMProxy *dataSource) |
| DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More... | |
Signals inherited from pqInteractivePropertyWidget | |
| void | widgetVisibilityToggled (bool) |
| Fired whenever setWidgetVisible() changes the widget's visibility. More... | |
| void | widgetVisibilityUpdated (bool) |
| Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More... | |
| void | startInteraction () |
| Signals fired when the interactive widget proxy fires the corresponding events. More... | |
| void | interaction () |
| void | endInteraction () |
| void | dummySignal () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Protected Attributes inherited from pqInteractivePropertyWidget | |
| bool | VisibleState = true |
Properties inherited from pqInteractivePropertyWidget | |
| pqSMProxy | dataSource |
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveLight" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions:
Positional: a 1-tuple vtkSMIntVectorProperty with a vtkSMEnumerationDomain that will be use to show the positional cone or not. WorldPosition: a 3-tuple vtkSMDoubleVectorProperty that will be linked to the origin of the interactive light. FocalPoint: a 3-tuple vtkSMDoubleVectorProperty that will be linked to the the focal point of the interactive light. FocalPoint: a 1-tuple vtkSMDoubleVectorProperty with a vtkSMDoubleRangeDomain that will be linked to the cone angle of the interactive light. Definition at line 53 of file pqLightPropertyWidget.h.
| pqLightPropertyWidget::pqLightPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMPropertyGroup * | smgroup, | ||
| QWidget * | parent = 0 |
inlineoverrideprotectedslot |
Definition at line 63 of file pqLightPropertyWidget.h.
protectedslot |
