pqGlyphScaleFactorPropertyWidget is used for the "Scale Factor" property on the Glyph filter.
#include <pqGlyphScaleFactorPropertyWidget.h>
| | called to set the active view. More...
| void | clearHighlight () |
| | internal signal used to clear highlights from pqHighlightablePushButton. More...
| void | highlightResetButton () |
| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
It customizes the resetButtonClicked() logic since the Glyph filter's scale factor setup is custom.
Definition at line 43 of file pqGlyphScaleFactorPropertyWidget.h.
◆ pqGlyphScaleFactorPropertyWidget()
| pqGlyphScaleFactorPropertyWidget::pqGlyphScaleFactorPropertyWidget |
vtkSMProxy * |
proxy, |
vtkSMProperty * |
property, |
QWidget * |
parent = 0 |
◆ ~pqGlyphScaleFactorPropertyWidget()
| pqGlyphScaleFactorPropertyWidget::~pqGlyphScaleFactorPropertyWidget |
◆ resetButtonClicked
| void pqGlyphScaleFactorPropertyWidget::resetButtonClicked |
overrideprotectedslot |
update the property's value using the domain.
