pqPropertyWidget for properties with vtkDataAssembly More...
#include <pqDataAssemblyPropertyWidget.h>
Signals | |
| void | chosenPathsChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqDataAssemblyPropertyWidget (vtkSMProxy *smproxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
| pqDataAssemblyPropertyWidget (vtkSMProxy *smproxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
| ~pqDataAssemblyPropertyWidget () override | |
| void | setChosenPaths (const QStringList &paths) |
| API for getting/setting selected/chosen path strings. More... | |
| const QStringList & | chosenPaths () const |
| void | setChosenPaths (const QList< QVariant > &paths) |
| QList< QVariant > | chosenPathsAsVariantList () const |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| virtual void | reset () |
| virtual void | select () |
| pqView * | view () const |
| bool | showLabel () const |
Properties | |
| QList< QVariant > | chosenPaths |
| template<class T > | |
pqDataAssemblyPropertyWidget is intended for properties that rely on a vtkDataAssembly i.e. use a vtkSMDataAssemblyDomain. Currently, this only support getting/setting the list of chosen paths based on the vtkDataAssembly. In the future, we will add support for additional properties such as color, opacity etc.
Definition at line 51 of file pqDataAssemblyPropertyWidget.h.
| pqDataAssemblyPropertyWidget::pqDataAssemblyPropertyWidget | ( | vtkSMProxy * | smproxy, |
| vtkSMPropertyGroup * | smgroup, | ||
| vtkSMProperty * | smproperty, | ||
| void pqDataAssemblyPropertyWidget::setChosenPaths | ( | const QStringList & | paths | ) |
| const QStringList& pqDataAssemblyPropertyWidget::chosenPaths | ( | ) | const |
| void pqDataAssemblyPropertyWidget::setChosenPaths | ( | const QList< QVariant > & | paths | ) |
| QList<QVariant> pqDataAssemblyPropertyWidget::chosenPathsAsVariantList | ( | ) | const |
signal |
readwrite |
Definition at line 56 of file pqDataAssemblyPropertyWidget.h.
