| vtkDataAssembly * | GetDataAssembly () |
| | Provides access to the current data assembly. More...
| void | Update (vtkSMProperty *requestingProperty) override |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMDataAssemblyDomain () |
| | ~vtkSMDataAssemblyDomain () |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
a domain that uses vtkDataAssembly
vtkSMDataAssemblyDomain is intended for vtkSMStringVectorProperty that uses vtkDataAssembly to qualify values. For example, the "Paths" property on vtkExtractBlockUsingDataAssembly filter that lets the user select paths to extract uses this domain.
Example usage in a ServerManager XML is as follows:
<SourceProxy ...>
<StringVectorProperty clean_command="ClearNodePaths"
command="AddNodePath"
name="Paths"
number_of_elements_per_command="1"
panel_visibility="default"
repeat_command="1"
animateable="0">
<DataAssemblyDomain name="data_assembly">
<RequiredProperties>
<Property function="Input" name="Input" />
</RequiredProperties>
</DataAssemblyDomain>
<Documentation>
This property lists the paths for blocks to extract.
</Documentation>
</StringVectorProperty>
</SourceProxy>
Definition at line 58 of file vtkSMDataAssemblyDomain.h.
