pqCylinderPropertyWidget is a custom property widget that uses "ImplicitCylinderWidgetRepresentation" to help users interactively set the center, radius and axis for a cylinder. More...
#include <pqCylinderPropertyWidget.h>
Public Slots | |
| void | useXAxis () |
| Set the cylinder axis to be along the X axis. More... | |
| void | useYAxis () |
| Set the cylinder axis to be along the Y axis. More... | |
| void | useZAxis () |
| Set the cylinder axis to be along the Z axis. More... | |
| void | resetCameraToAxis () |
| Reset the camera to be down the cylinder axis. More... | |
| void | useCameraAxis () |
| Set the cylinder axis to be along the camera view direction. More... | |
Public Slots inherited from pqInteractivePropertyWidget | |
| void | setWidgetVisible (bool val) |
| Toggle the interactive widget's visibility. More... | |
| void | setDataSource (vtkSMProxy *dataSource) |
| DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More... | |
| pqCylinderPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=0) | |
| ~pqCylinderPropertyWidget () override | |
Public Member Functions inherited from pqInteractivePropertyWidget | |
| pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=0) | |
| ~pqInteractivePropertyWidget () override | |
| void | reset () override |
| Overridden to call this->render() to ensure that the widget is redrawn. More... | |
| vtkSMNewWidgetRepresentationProxy * | widgetProxy () const |
| Returns the proxy for the interactive widget. More... | |
| void | setView (pqView *view) override |
| Overridden to show the widget proxy in the new view. More... | |
| bool | isWidgetVisible () const |
| Returns the interactive widget's visibility. More... | |
| vtkSMProxy * | dataSource () const |
| Returns the data source. More... | |
| void | select () override |
| In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More... | |
| void | deselect () override |
| vtkBoundingBox | dataBounds () const |
| Returns bounds from the dataSource, if possible. More... | |
| vtkSMPropertyGroup * | propertyGroup () const |
| Returns the vtkSMPropertyGroup pass to the constructor. More... | |
| void | hideEvent (QHideEvent *) override |
| Overriden in order to hide the VTK widget. More... | |
| void | showEvent (QShowEvent *) override |
| Overriden in order to show the VTK widget. More... | |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| pqView * | view () const |
| bool | showLabel () const |
Protected Slots | |
| void | placeWidget () override |
| Places the interactive widget using current data source information. More... | |
| void | resetBounds () |
Protected Slots inherited from pqInteractivePropertyWidget | |
| virtual void | placeWidget ()=0 |
| void | render () |
| Safe call render on the view. More... | |
Signals inherited from pqInteractivePropertyWidget | |
| void | widgetVisibilityToggled (bool) |
| Fired whenever setWidgetVisible() changes the widget's visibility. More... | |
| void | widgetVisibilityUpdated (bool) |
| Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More... | |
| void | startInteraction () |
| Signals fired when the interactive widget proxy fires the corresponding events. More... | |
| void | interaction () |
| void | endInteraction () |
| void | dummySignal () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Protected Attributes inherited from pqInteractivePropertyWidget | |
| bool | VisibleState = true |
Properties inherited from pqInteractivePropertyWidget | |
| pqSMProxy | dataSource |
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveCylinder" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions:
Center : a 3-tuple vtkSMDoubleVectorProperty that will be linked to the center of the cylinder Axis : a 3-tuple vtkSMDoubleVectorProperty that will be linked to the axis for the cylinder Radius: a 1-tuple vtkSMDoubleVectorProperty that will be linked to the radius for the cylinder Input: (optional) a vtkSMInputProperty that is used to get data information for bounds when placing/resetting the widget. Definition at line 55 of file pqCylinderPropertyWidget.h.
| pqCylinderPropertyWidget::pqCylinderPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMPropertyGroup * | smgroup, | ||
| QWidget * | parent = 0 |
inlineslot |
Definition at line 68 of file pqCylinderPropertyWidget.h.
inlineslot |
Definition at line 73 of file pqCylinderPropertyWidget.h.
inlineslot |
Definition at line 78 of file pqCylinderPropertyWidget.h.
slot |
slot |
overrideprotectedslot |
protectedslot |
