| | pqComparativeRenderView (const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=NULL) |
| | ~pqComparativeRenderView () override |
| vtkSMComparativeViewProxy * | getComparativeRenderViewProxy () const |
| | Returns the comparative view proxy. More...
| vtkSMRenderViewProxy * | getRenderViewProxy () const override |
| | Returns the root render view in the comparative view. More...
| | pqRenderView (const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=NULL) |
| | pqRenderView (const QString &tname, const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=NULL) |
| | ~pqRenderView () override |
| void | resetCamera () override |
| | Resets the camera to include all visible data. More...
| virtual void | resetCenterOfRotation () |
| | Resets the center of rotation to the focal point. More...
| virtual void | resetParallelScale () |
| | Resets the parallel scale which is used for a parallel projection. More...
| virtual bool | getOrientationAxesVisibility () const |
| | Get if the orientation axes is visible. More...
| virtual bool | getOrientationAxesInteractivity () const |
| | Get if the orientation axes is interactive. More...
| virtual QColor | getOrientationAxesLabelColor () const |
| | Get orientation axes label color. More...
| virtual QColor | getOrientationAxesOutlineColor () const |
| | Get orientation axes outline color. More...
| virtual bool | getResetCenterWithCamera () const |
| | Get whether resetCamera() resets the center of rotation as well. More...
| virtual bool | getUseMultipleRepresentationSelection () const |
| | Get whether selection will be done on multiple representations. More...
| virtual bool | getCenterAxesVisibility () const |
| | Get center axes visibility. More...
| virtual void | getCenterOfRotation (double center[3]) const |
| | Get the current center of rotation. More...
| bool | supportsUndo () const override |
| | Returns if this view module can support undo/redo. More...
| bool | canUndo () const override |
| | Returns if the view module can undo/redo interaction given the current state of the interaction undo stack. More...
| bool | canRedo () const override |
| | Returns true if redo can be done. More...
| bool | supportsCapture () const override |
| | Returns if this view module can support image capture. More...
| virtual void | linkUndoStack (pqRenderView *other) |
| | For linking of interaction undo stacks. More...
| virtual void | unlinkUndoStack (pqRenderView *other) |
| virtual void | clearUndoStack () |
| | Clears interaction undo stack of this view (and all linked views, if any). More...
| virtual void | resetViewDirection (double look_x, double look_y, double look_z, double up_x, double up_y, double up_z) |
| | Reset camera view direction. More...
| virtual void | setCursor (const QCursor &) |
| | Let internal class handle which internal widget should change its cursor This is usually used for selection and in case of QuadView/SliceView which contains an aggregation of QWidget, we don't necessary want all of them to share the same cursor. More...
| virtual void | selectOnSurface (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT, const char *array=nullptr) |
| | Creates a new surface selection given the rectangle in display coordinates. More...
| virtual void | selectPointsOnSurface (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT, const char *array=nullptr) |
| virtual pqDataRepresentation * | pick (int pos[2]) |
| | Picks the representation at the given position. More...
| virtual pqDataRepresentation * | pickBlock (int pos[2], unsigned int &flatIndex) |
| virtual void | selectFrustum (int rectangle[4]) |
| | Creates a new frustum selection given the rectangle in display coordinates. More...
| virtual void | selectFrustumPoints (int rectangle[4]) |
| virtual void | selectBlock (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
| | Creates a "block" selection given the rectangle in display coordinates. More...
| virtual void | selectPolygonPoints (vtkIntArray *polygon, int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
| | Creates a new surface points selection given the polygon in display coordinates. More...
| virtual void | selectPolygonCells (vtkIntArray *polygon, int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
| | Creates a new surface cells selection given the polygon in display coordinates. More...
| | ~pqRenderViewBase () override |
| void | resetDisplay () override |
| | Called to reset the view's display. More...
| | ~pqView () override |
| vtkSMViewProxy * | getViewProxy () const |
| | Returns the internal render Module proxy associated with this object. More...
| virtual vtkView * | getClientSideView () const |
| | Return the client-side vtkView encapsulated by this view (if any), or return NULL. More...
| QWidget * | widget () |
| | Return a widget associated with this view. More...
| QString | getViewType () const |
| | Returns the type of this view module. More...
| virtual QSize | getSize () |
| | Returns the current size of the rendering context. More...
| bool | hasRepresentation (pqRepresentation *repr) const |
| | This method checks if the representation is shown in this view. More...
| int | getNumberOfRepresentations () const |
| | Returns the number representations in the view. More...
| int | getNumberOfVisibleRepresentations () const |
| int | getNumberOfVisibleDataRepresentations () const |
| pqRepresentation * | getRepresentation (int index) const |
| | Returns the representation for the specified index where (index < getNumberOfRepresentations()). More...
| QList< pqRepresentation * > | getRepresentations () const |
| | Returns a list of representations in this view. More...
| bool | canDisplay (pqOutputPort *opPort) const |
| | This method returns is any pqPipelineSource can be displayed in this view. More...
| virtual void | emitSelectionSignals (bool frustum) |
| | Called when a selection is made, passing in the mode as the sole argument. More...
| | pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=NULL) |
| | ~pqProxy () override |
| | Get the server on which this proxy exists. More...
| | This is a convenience method. More...
| | Get the name with which this proxy is registered on the server manager. More...
| | Get the vtkSMProxy this object stands for. More...
| | Gets whether or not the source has been modified. More...
| | Sets whether or not the source has been modified. More...
| | Returns the hints for this proxy, if any. More...
| | Returns a list of all helper proxies. More...
| | Returns a list of all the helper proxies added with a given key. More...
| | Returns the keys for helper proxies. More...
| | Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
| | Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
| | Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
| | Return whether or not the user has modified the GUI name of the source. More...
| | pqServerManagerModelItem (QObject *parent=NULL) |
| | ~pqServerManagerModelItem () override |
| QWidget * | createWidget () override |
| | Creates a new instance of the QWidget subclass to be used to show this view. More...
| virtual void | fakeUndoRedo (bool redo, bool self) |
| | Updates undo stack without actually performing the undo/redo actions. More...
| virtual void | fakeInteraction (bool start) |
| | Updates undo stack of all linked views to record a programmatic change in camera as a interaction. More...
| void | initialize () override |
| | Overridden to initialize the interaction undo/redo stack. More...
| | pqRenderViewBase (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=NULL) |
| bool | eventFilter (QObject *caller, QEvent *e) override |
| | Overridden to popup the context menu, if some actions have been added using addMenuAction. More...
| | Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
| | pqView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=NULL) |
| | Constructor: type :- view type. More...
| | Make this pqProxy take on a new identity. More...
| | All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
| enum | SelectionModifier { PV_SELECTION_DEFAULT = 0,
PV_SELECTION_ADDITION,
PV_SELECTION_SUBTRACTION,
PV_SELECTION_TOGGLE
| enum | ModifiedState { UNINITIALIZED,
MODIFIED,
UNMODIFIED
| | The modification state of this proxy. More...
| virtual void | setOrientationAxesVisibility (bool visible) |
| virtual void | setOrientationAxesInteractivity (bool interactive) |
| virtual void | setOrientationAxesLabelColor (const QColor &) |
| virtual void | setOrientationAxesOutlineColor (const QColor &) |
| virtual void | setCenterOfRotation (double x, double y, double z) |
| virtual void | setCenterOfRotation (double xyz[3]) |
| virtual void | setParallelScale (double scale) |
| virtual void | setCenterAxesVisibility (bool visible) |
| virtual void | setResetCenterWithCamera (bool b) |
| | Get/Set whether resetCamera() resets the center of rotation as well. More...
| virtual void | setUseMultipleRepresentationSelection (bool b) |
| | Set whether selection will be done on multiple representations. More...
| virtual void | linkToOtherView () |
| | start the link to other view process More...
| virtual void | undo () override |
| | Called to undo interaction. More...
| virtual void | redo () override |
| | Called to redo interaction. More...
| virtual void | resetCenterOfRotationIfNeeded () |
| | Resets center of rotation if this->ResetCenterWithCamera is true. More...
| virtual void | updateInteractionMode (pqOutputPort *opPort) |
| | Try to provide the best view orientation and interaction mode. More...
| virtual void | render () |
| | Request a StillRender on idle. More...
| virtual void | forceRender () |
| | Forces an immediate render. More...
| void | cancelPendingRenders () |
| | Cancels any pending renders. More...
| virtual void | undo () |
| virtual void | redo () |
| void | updateInteractionMode (int mode) |
| void | updateDataEvent () |
| | Fired when the vtkSMViewProxy fires the vtkCommand::UpdateDataEvent The view proxy fires this event at the end of vtkSMViewProxy::Update() when the update executes, not just when the method is called. More...
| void | representationAdded (pqRepresentation *) |
| | Fired after a representation has been added to this view. More...
| void | representationRemoved (pqRepresentation *) |
| | Fired after a representation has been removed from this view. More...
| void | beginRender () |
| | Fired when the render module fires a vtkCommand::StartEvent signalling the beginning of rendering. More...
| void | endRender () |
| | Fired when the render module fires a vtkCommand::EndEvent signalling the end of rendering. More...
| void | representationVisibilityChanged (pqRepresentation *repr, bool visible) |
| | Fired when any representation visibility changes. More...
| void | canUndoChanged (bool) |
| | Fired when interaction undo stack status changes. More...
| void | canRedoChanged (bool) |
| void | selected (pqOutputPort *opport) |
| | Fired when a selection is made in this view. More...
| void | selectionModeChanged (bool frustum) |
| | Fired when the selection changes. More...
| void | picked (pqOutputPort *opport) |
| | Fired when a port is picked. More...
| void | beginProgress () |
| | Fired before doing any actions that may result in progress events that must be reported by the client. More...
| void | endProgress () |
| | Fired after performing any actions that may result in progress events. More...
| void | progress (const QString &message, int percent_progress) |
| | Fired to notify the current execution progress. More...
| void | multipleSelected (QList< pqOutputPort *> opports) |
| | Fired when UseMultipleRepresentationSelection is set to on and selection on multiple representations is made in this view. More...
| void | nameChanged (pqServerManagerModelItem *) |
| | Fired when the name of the proxy is changed. More...
| void | modifiedStateChanged (pqServerManagerModelItem *) |
| | Fired when the modified status changes for the proxy. More...
| bool | ResetCenterWithCamera |
| bool | UseMultipleRepresentationSelection |
RenderView used for comparative visualization (or film-strip visualization).
Definition at line 42 of file pqComparativeRenderView.h.
