custom property widget using vtkBoxWidget2 and vtkBoxRepresentation. More...
#include <pqBoxPropertyWidget.h>
| pqBoxPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=0, bool hideReferenceBounds=false) | |
| ~pqBoxPropertyWidget () override | |
Public Member Functions inherited from pqInteractivePropertyWidget | |
| pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=0) | |
| ~pqInteractivePropertyWidget () override | |
| void | reset () override |
| Overridden to call this->render() to ensure that the widget is redrawn. More... | |
| vtkSMNewWidgetRepresentationProxy * | widgetProxy () const |
| Returns the proxy for the interactive widget. More... | |
| void | setView (pqView *view) override |
| Overridden to show the widget proxy in the new view. More... | |
| bool | isWidgetVisible () const |
| Returns the interactive widget's visibility. More... | |
| vtkSMProxy * | dataSource () const |
| Returns the data source. More... | |
| void | select () override |
| In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More... | |
| void | deselect () override |
| vtkBoundingBox | dataBounds () const |
| Returns bounds from the dataSource, if possible. More... | |
| vtkSMPropertyGroup * | propertyGroup () const |
| Returns the vtkSMPropertyGroup pass to the constructor. More... | |
| void | hideEvent (QHideEvent *) override |
| Overriden in order to hide the VTK widget. More... | |
| void | showEvent (QShowEvent *) override |
| Overriden in order to show the VTK widget. More... | |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| virtual void | apply () |
| pqView * | view () const |
| bool | showLabel () const |
Protected Slots | |
| void | placeWidget () override |
| Places the interactive widget using current data source information. More... | |
Protected Slots inherited from pqInteractivePropertyWidget | |
| virtual void | placeWidget ()=0 |
| void | render () |
| Safe call render on the view. More... | |
Public Slots inherited from pqInteractivePropertyWidget | |
| void | setWidgetVisible (bool val) |
| Toggle the interactive widget's visibility. More... | |
| void | setDataSource (vtkSMProxy *dataSource) |
| DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More... | |
Signals inherited from pqInteractivePropertyWidget | |
| void | widgetVisibilityToggled (bool) |
| Fired whenever setWidgetVisible() changes the widget's visibility. More... | |
| void | widgetVisibilityUpdated (bool) |
| Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More... | |
| void | startInteraction () |
| Signals fired when the interactive widget proxy fires the corresponding events. More... | |
| void | interaction () |
| void | endInteraction () |
| void | dummySignal () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
Protected Attributes inherited from pqInteractivePropertyWidget | |
| bool | VisibleState = true |
Properties inherited from pqInteractivePropertyWidget | |
| pqSMProxy | dataSource |
pqBoxPropertyWidget is a custom property widget that uses "BoxWidgetRepresentation" to help users interactively set the origin, orientation and scale for an oriented bounding box.
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveBox" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions (all of which are optional):
UseReferenceBounds and ReferenceBounds must be used together i.e. both are required for this to work.
The constructor accepts a boolean "hideReferenceBounds" to toggle the visibility of reference bounds items. This is useful when reference bounds are fixed by an external entity that doesn't want the user to modify it.
Note while all of the above are optional, it really doesn't make much sense to use this widget if any of them are not specified.
Definition at line 72 of file pqBoxPropertyWidget.h.
| pqBoxPropertyWidget::pqBoxPropertyWidget | ( | vtkSMProxy * | proxy, |
| vtkSMPropertyGroup * | smgroup, | ||
| QWidget * | parent = 0, |
| bool | hideReferenceBounds = false |
overrideprotectedslot |
