Public Member Functions | List of all members
vtkSMUncheckedPropertyHelper Class Reference
#include <vtkSMUncheckedPropertyHelper.h>
Inheritance diagram for vtkSMUncheckedPropertyHelper:
Collaboration diagram for vtkSMUncheckedPropertyHelper:
 vtkSMUncheckedPropertyHelper (vtkSMProxy *proxy, const char *name, bool quiet=false)
 vtkSMUncheckedPropertyHelper (vtkSMProperty *property, bool quiet=false)
- Public Member Functions inherited from vtkSMPropertyHelper
void UpdateValueFromServer ()
 Updates the property value by fetching the value from the server. More...
void SetNumberOfElements (unsigned int elems)
 Set the number of elements in the property. More...
unsigned int GetNumberOfElements () const
 Get the number of elements in the property. More...
void RemoveAllValues ()
 Equivalent to SetNumberOfElements(0). More...
vtkVariant GetAsVariant (unsigned int index) const
 Get value as a variant. More...
template<class T >
std::vector< T > GetArray () const
 Templated method to call GetIntArray(), GetDoubleArray(), GetIdTypeArray(). More...
template<class T >
T GetAs (unsigned int index=0) const
 Templated method to call GetAsInt(), GetAsDouble(), GetAsIdType() Note, we only provide implementations for T==double, int, vtkIdType. More...
vtkIdType GetAsIdType (unsigned int index=0) const
std::vector< vtkIdType > GetIdTypeArray () const
void RemoveStatus (const char *key)
 Removes the status value specified for the given key, if any. More...
void SetUseUnchecked (bool val)
 Get/Set whether to use unchecked properties. More...
bool GetUseUnchecked () const
bool Copy (const vtkSMPropertyHelper &source)
 Copy property values from another vtkSMPropertyHelper. More...
vtkSMPropertyHelper & Modified ()
 Set the proxy to modified if necessary before calling Set() Return reference so method chaining can be used. More...
template<>
std::vector< int > GetArray () const
template<>
std::vector< double > GetArray () const
template<>
int GetAs (unsigned int index) const
template<>
double GetAs (unsigned int index) const
 vtkSMPropertyHelper (vtkSMProxy *proxy, const char *name, bool quiet=false)
 If quiet is true, then no errors or warning are raised if the property is missing or of incorrect type. More...
 vtkSMPropertyHelper (vtkSMProperty *property, bool quiet=false)
 ~vtkSMPropertyHelper ()
void Set (int value)
 Set/Get methods with int API. More...
void Set (unsigned int index, int value)
void Set (const int *values, unsigned int count)
void Append (const int *values, unsigned int count)
int GetAsInt (unsigned int index=0) const
unsigned int Get (int *values, unsigned int count=1) const
std::vector< int > GetIntArray () const
void Set (double value)
 Set/Get methods with double API. More...
void Set (unsigned int index, double value)
void Set (const double *values, unsigned int count)
void Append (const double *values, unsigned int count)
double GetAsDouble (unsigned int index=0) const
unsigned int Get (double *values, unsigned int count=1) const
std::vector< double > GetDoubleArray () const
void Set (const char *value)
 Set/Get methods for vtkSMStringVectorProperty. More...
void Set (unsigned int index, const char *value)
const char * GetAsString (unsigned int index=0) const
void Set (vtkSMProxy *value, unsigned int outputport=0)
 Set/Get methods for vtkSMProxyProperty or vtkSMInputProperty. More...
void Set (unsigned int index, vtkSMProxy *value, unsigned int outputport=0)
void Set (vtkSMProxy **value, unsigned int count, unsigned int *outputports=nullptr)
void Add (vtkSMProxy *value, unsigned int outputport=0)
void Remove (vtkSMProxy *value)
vtkSMProxy * GetAsProxy (unsigned int index=0) const
unsigned int GetOutputPort (unsigned int index=0) const
vtkSMOutputPort * GetAsOutputPort (unsigned int index=0) const
void SetStatus (const char *key, int value)
 This API is useful for setting values on vtkSMStringVectorProperty that is used for status where the first value is the name of the array (for example) and the second value is its status. More...
int GetStatus (const char *key, int default_value=0) const
void SetStatus (const char *key, double *values, int num_values)
 This API is useful for setting values on vtkSMStringVectorProperty that is used for status where the first value is the name of the array (for example), the second value is its status and the third value is number of status. More...
bool GetStatus (const char *key, double *values, int num_values) const
void SetStatus (int key, int *values, int num_values)
 This API is useful for setting values on vtkSMIntVectorProperty that is used for status where the first value is the id of the element (for example), the second value is its status and the third value is number of status. More...
bool GetStatus (int key, int *values, int num_values) const
void SetStatus (const char *key, const char *value)
 This API is useful for setting values on vtkSMStringVectorProperty that is used for status where the first value is the name of the array (for example) and the second value is its status (as a string) More...
const char * GetStatus (const char *key, const char *default_value) const
void SetStatus (int key, int value)
 This API is useful for setting values on vtkSMIntVectorProperty that is used for status where the first value is the id of the element (for example) and the second value is its status. More...
int GetStatus (int key, int default_value=0) const
void SetInputArrayToProcess (int fieldAssociation, const char *arrayName)
 For vtkSMStringVectorProperty that is used to setting input array to process on algorithms, this provides a convenient API to get/set the values. More...
int GetInputArrayAssociation () const
const char * GetInputArrayNameToProcess () const
- Protected Member Functions inherited from vtkSMPropertyHelper
void setUseUnchecked (bool useUnchecked)
Definition at line 10 of file vtkSMUncheckedPropertyHelper.h.
◆ vtkSMUncheckedPropertyHelper() [1/2]
vtkSMUncheckedPropertyHelper::vtkSMUncheckedPropertyHelper ( vtkSMProxy *  proxy,
const char *  name,
bool  quiet = false
◆ vtkSMUncheckedPropertyHelper() [2/2]
vtkSMUncheckedPropertyHelper::vtkSMUncheckedPropertyHelper ( vtkSMProperty *  property,
bool  quiet = false
