Public Member Functions | Protected Member Functions | List of all members
vtkSMPropertyHelper Class Reference
helper class to get/set property values. More...
#include <vtkSMPropertyHelper.h>
Inheritance diagram for vtkSMPropertyHelper:
Collaboration diagram for vtkSMPropertyHelper:
void UpdateValueFromServer ()
 Updates the property value by fetching the value from the server. More...
void SetNumberOfElements (unsigned int elems)
 Set the number of elements in the property. More...
unsigned int GetNumberOfElements () const
 Get the number of elements in the property. More...
void RemoveAllValues ()
 Equivalent to SetNumberOfElements(0). More...
vtkVariant GetAsVariant (unsigned int index) const
 Get value as a variant. More...
template<class T >
std::vector< T > GetArray () const
 Templated method to call GetIntArray(), GetDoubleArray(), GetIdTypeArray(). More...
template<class T >
T GetAs (unsigned int index=0) const
 Templated method to call GetAsInt(), GetAsDouble(), GetAsIdType() Note, we only provide implementations for T==double, int, vtkIdType. More...
vtkIdType GetAsIdType (unsigned int index=0) const
std::vector< vtkIdType > GetIdTypeArray () const
void RemoveStatus (const char *key)
 Removes the status value specified for the given key, if any. More...
void SetUseUnchecked (bool val)
 Get/Set whether to use unchecked properties. More...
bool GetUseUnchecked () const
bool Copy (const vtkSMPropertyHelper &source)
 Copy property values from another vtkSMPropertyHelper. More...
vtkSMPropertyHelper & Modified ()
 Set the proxy to modified if necessary before calling Set() Return reference so method chaining can be used. More...
template<>
std::vector< int > GetArray () const
template<>
std::vector< double > GetArray () const
template<>
int GetAs (unsigned int index) const
template<>
double GetAs (unsigned int index) const
 vtkSMPropertyHelper (vtkSMProxy *proxy, const char *name, bool quiet=false)
 If quiet is true, then no errors or warning are raised if the property is missing or of incorrect type. More...
 vtkSMPropertyHelper (vtkSMProperty *property, bool quiet=false)
 ~vtkSMPropertyHelper ()
void Set (int value)
 Set/Get methods with int API. More...
void Set (unsigned int index, int value)
void Set (const int *values, unsigned int count)
void Append (const int *values, unsigned int count)
int GetAsInt (unsigned int index=0) const
unsigned int Get (int *values, unsigned int count=1) const
std::vector< int > GetIntArray () const
void Set (double value)
 Set/Get methods with double API. More...
void Set (unsigned int index, double value)
void Set (const double *values, unsigned int count)
void Append (const double *values, unsigned int count)
double GetAsDouble (unsigned int index=0) const
unsigned int Get (double *values, unsigned int count=1) const
std::vector< double > GetDoubleArray () const
void Set (const char *value)
 Set/Get methods for vtkSMStringVectorProperty. More...
void Set (unsigned int index, const char *value)
const char * GetAsString (unsigned int index=0) const
void Set (vtkSMProxy *value, unsigned int outputport=0)
 Set/Get methods for vtkSMProxyProperty or vtkSMInputProperty. More...
void Set (unsigned int index, vtkSMProxy *value, unsigned int outputport=0)
void Set (vtkSMProxy **value, unsigned int count, unsigned int *outputports=nullptr)
void Add (vtkSMProxy *value, unsigned int outputport=0)
void Remove (vtkSMProxy *value)
vtkSMProxy * GetAsProxy (unsigned int index=0) const
unsigned int GetOutputPort (unsigned int index=0) const
vtkSMOutputPort * GetAsOutputPort (unsigned int index=0) const
void SetStatus (const char *key, int value)
 This API is useful for setting values on vtkSMStringVectorProperty that is used for status where the first value is the name of the array (for example) and the second value is its status. More...
int GetStatus (const char *key, int default_value=0) const
void SetStatus (const char *key, double *values, int num_values)
 This API is useful for setting values on vtkSMStringVectorProperty that is used for status where the first value is the name of the array (for example), the second value is its status and the third value is number of status. More...
bool GetStatus (const char *key, double *values, int num_values) const
void SetStatus (int key, int *values, int num_values)
 This API is useful for setting values on vtkSMIntVectorProperty that is used for status where the first value is the id of the element (for example), the second value is its status and the third value is number of status. More...
bool GetStatus (int key, int *values, int num_values) const
void SetStatus (const char *key, const char *value)
 This API is useful for setting values on vtkSMStringVectorProperty that is used for status where the first value is the name of the array (for example) and the second value is its status (as a string) More...
const char * GetStatus (const char *key, const char *default_value) const
void SetStatus (int key, int value)
 This API is useful for setting values on vtkSMIntVectorProperty that is used for status where the first value is the id of the element (for example) and the second value is its status. More...
int GetStatus (int key, int default_value=0) const
void SetInputArrayToProcess (int fieldAssociation, const char *arrayName)
 For vtkSMStringVectorProperty that is used to setting input array to process on algorithms, this provides a convenient API to get/set the values. More...
int GetInputArrayAssociation () const
const char * GetInputArrayNameToProcess () const
void setUseUnchecked (bool useUnchecked)
vtkSMPropertyHelper is a helper class to get/set property values in a type independent fashion. eg.
vtkSMPropertyHelper(proxy, "Visibility").Set(0);
vtkSMPropertyHelper(proxy, "Input").Set(inputProxy, 0);
double center[3] = {...};
vtkSMPropertyHelper(proxy, "Center").Set(center, 3);
Caveat:
This class is not wrapped, hence not available in any of the wrapped languagues such as python.
Definition at line 52 of file vtkSMPropertyHelper.h.
◆ vtkSMPropertyHelper() [1/2]
vtkSMPropertyHelper::vtkSMPropertyHelper ( vtkSMProxy *  proxy,
const char *  name,
bool  quiet = false
◆ vtkSMPropertyHelper() [2/2]
vtkSMPropertyHelper::vtkSMPropertyHelper ( vtkSMProperty *  property,
bool  quiet = false
◆ ~vtkSMPropertyHelper()
vtkSMPropertyHelper::~vtkSMPropertyHelper ( )
◆ UpdateValueFromServer()
void vtkSMPropertyHelper::UpdateValueFromServer ( )
This only works for properties with InformationOnly attribute set to 1. For all other properties, this has no effect.
◆ SetNumberOfElements()
void vtkSMPropertyHelper::SetNumberOfElements ( unsigned int  elems)
For vtkSMProxyProperty, this is equivalent to SetNumberOfProxies().
◆ GetNumberOfElements()
unsigned int vtkSMPropertyHelper::GetNumberOfElements ( ) const
For vtkSMProxyProperty, this is equivalent to GetNumberOfProxies().
◆ RemoveAllValues()
void vtkSMPropertyHelper::RemoveAllValues ( )
inline
Definition at line 87 of file vtkSMPropertyHelper.h.
◆ GetAsVariant()
vtkVariant vtkSMPropertyHelper::GetAsVariant ( unsigned int  index) const
◆ GetArray() [1/3]
template<class T >
std::vector<T> vtkSMPropertyHelper::GetArray ( ) const
◆ GetAs() [1/3]
template<class T >
T vtkSMPropertyHelper::GetAs ( unsigned int  index = 0) const
◆ Set() [1/11]
void vtkSMPropertyHelper::Set ( int  value)
inline
Calling these method on vtkSMStringVectorProperty or vtkSMProxyProperty will raise errors.
Definition at line 113 of file vtkSMPropertyHelper.h.
◆ Set() [2/11]
void vtkSMPropertyHelper::Set ( unsigned int  index,
int  value
◆ Set() [3/11]
void vtkSMPropertyHelper::Set ( const int *  values,
unsigned int  count
◆ Append() [1/2]
void vtkSMPropertyHelper::Append ( const int *  values,
unsigned int  count
◆ GetAsInt()
int vtkSMPropertyHelper::GetAsInt ( unsigned int  index = 0) const
◆ Get() [1/2]
unsigned int vtkSMPropertyHelper::Get ( int *  values,
unsigned int  count = 1
) const
◆ GetIntArray()
std::vector<int> vtkSMPropertyHelper::GetIntArray ( ) const
◆ Set() [4/11]
void vtkSMPropertyHelper::Set ( double  value)
inline
Definition at line 127 of file vtkSMPropertyHelper.h.
◆ Set() [5/11]
double  value
◆ Set() [6/11]
void vtkSMPropertyHelper::Set ( const double *  values,
unsigned int  count
◆ Append() [2/2]
void vtkSMPropertyHelper::Append ( const double *  values,
unsigned int  count
◆ GetAsDouble()
double vtkSMPropertyHelper::GetAsDouble ( unsigned int  index = 0) const
◆ Get() [2/2]
unsigned int vtkSMPropertyHelper::Get ( double *  values,
) const
◆ GetDoubleArray()
std::vector<double> vtkSMPropertyHelper::GetDoubleArray ( ) const
◆ GetAsIdType()
vtkIdType vtkSMPropertyHelper::GetAsIdType ( unsigned int  index = 0) const
◆ GetIdTypeArray()
std::vector<vtkIdType> vtkSMPropertyHelper::GetIdTypeArray ( ) const
◆ Set() [7/11]
void vtkSMPropertyHelper::Set ( const char *  value)
inline
Calling these methods on any other type of property will raise errors. These overloads can be used for vtkSMIntVectorProperty with an enumeration domain as well, in which case the string-to-int (and vice-versa) translations are done internally.
Definition at line 160 of file vtkSMPropertyHelper.h.
◆ Set() [8/11]
const char *  value
◆ GetAsString()
const char* vtkSMPropertyHelper::GetAsString ( unsigned int  index = 0) const
◆ Set() [9/11]
void vtkSMPropertyHelper::Set ( vtkSMProxy *  value,
unsigned int  outputport = 0
inline
Calling these methods on any other type of property will raise errors. The option outputport(s) argument is used only for vtkSMInputProperty.
Definition at line 171 of file vtkSMPropertyHelper.h.
◆ Set() [10/11]
vtkSMProxy *  value,
◆ Set() [11/11]
void vtkSMPropertyHelper::Set ( vtkSMProxy **  value,
unsigned int  count,
unsigned int *  outputports = nullptr
◆ Add()
void vtkSMPropertyHelper::Add ( vtkSMProxy *  value,
◆ Remove()
void vtkSMPropertyHelper::Remove ( vtkSMProxy *  value)
◆ GetAsProxy()
vtkSMProxy* vtkSMPropertyHelper::GetAsProxy ( unsigned int  index = 0) const
◆ GetOutputPort()
unsigned int vtkSMPropertyHelper::GetOutputPort ( unsigned int  index = 0) const
◆ GetAsOutputPort()
vtkSMOutputPort* vtkSMPropertyHelper::GetAsOutputPort ( unsigned int  index = 0) const
◆ SetStatus() [1/5]
void vtkSMPropertyHelper::SetStatus ( const char *  key,
int  value
◆ GetStatus() [1/5]
int vtkSMPropertyHelper::GetStatus ( const char *  key,
int  default_value = 0
) const
◆ SetStatus() [2/5]
double *  values,
int  num_values
◆ GetStatus() [2/5]
bool vtkSMPropertyHelper::GetStatus ( const char *  key,
double *  values,
int  num_values
) const
◆ SetStatus() [3/5]
void vtkSMPropertyHelper::SetStatus ( int  key,
int *  values,
int  num_values
◆ GetStatus() [3/5]
bool vtkSMPropertyHelper::GetStatus ( int  key,
int *  values,
int  num_values
) const
◆ SetStatus() [4/5]
const char *  value
◆ GetStatus() [4/5]
const char* vtkSMPropertyHelper::GetStatus ( const char *  key,
const char *  default_value
) const
◆ RemoveStatus()
void vtkSMPropertyHelper::RemoveStatus ( const char *  key)
Applicable only to vtkSMStringVectorProperty objects, and this function assumes that the presence of a key in the property indicates that it is enabled.
◆ SetStatus() [5/5]
int  value
◆ GetStatus() [5/5]
int vtkSMPropertyHelper::GetStatus ( int  key,
) const
◆ SetInputArrayToProcess()
void vtkSMPropertyHelper::SetInputArrayToProcess ( int  fieldAssociation,
const char *  arrayName
◆ GetInputArrayAssociation()
int vtkSMPropertyHelper::GetInputArrayAssociation ( ) const
◆ GetInputArrayNameToProcess()
const char* vtkSMPropertyHelper::GetInputArrayNameToProcess ( ) const
◆ SetUseUnchecked()
void vtkSMPropertyHelper::SetUseUnchecked ( bool  val)
inline
Definition at line 252 of file vtkSMPropertyHelper.h.
◆ GetUseUnchecked()
bool vtkSMPropertyHelper::GetUseUnchecked ( ) const
inline
Definition at line 253 of file vtkSMPropertyHelper.h.
◆ Copy()
bool vtkSMPropertyHelper::Copy ( const vtkSMPropertyHelper &  source)
This only works for compatible properties and currently only supported for numeric vtkSMVectorProperty subclasses.
◆ Modified()
vtkSMPropertyHelper& vtkSMPropertyHelper::Modified ( )
◆ setUseUnchecked()
void vtkSMPropertyHelper::setUseUnchecked ( bool  useUnchecked)
inlineprotected
Definition at line 269 of file vtkSMPropertyHelper.h.
◆ GetArray() [2/3]
template<>
std::vector<int> vtkSMPropertyHelper::GetArray ( void  ) const
inline
Definition at line 321 of file vtkSMPropertyHelper.h.
◆ GetArray() [3/3]
template<>
std::vector<double> vtkSMPropertyHelper::GetArray ( void  ) const
inline
Definition at line 327 of file vtkSMPropertyHelper.h.
◆ GetAs() [2/3]
template<>
int vtkSMPropertyHelper::GetAs ( unsigned int  index) const
inline
Definition at line 341 of file vtkSMPropertyHelper.h.
◆ GetAs() [3/3]
template<>
double vtkSMPropertyHelper::GetAs ( unsigned int  index) const
inline
Definition at line 347 of file vtkSMPropertyHelper.h.
◆ Property
vtkSMProperty* vtkSMPropertyHelper::Property
Definition at line 309 of file vtkSMPropertyHelper.h.
◆ VectorProperty
vtkSMVectorProperty* vtkSMPropertyHelper::VectorProperty
Definition at line 310 of file vtkSMPropertyHelper.h.
◆ IntVectorProperty
vtkSMIntVectorProperty* vtkSMPropertyHelper::IntVectorProperty
Definition at line 311 of file vtkSMPropertyHelper.h.
◆ DoubleVectorProperty
vtkSMDoubleVectorProperty* vtkSMPropertyHelper::DoubleVectorProperty
Definition at line 312 of file vtkSMPropertyHelper.h.
◆ IdTypeVectorProperty
vtkSMIdTypeVectorProperty* vtkSMPropertyHelper::IdTypeVectorProperty
Definition at line 313 of file vtkSMPropertyHelper.h.
◆ StringVectorProperty
vtkSMStringVectorProperty* vtkSMPropertyHelper::StringVectorProperty
Definition at line 314 of file vtkSMPropertyHelper.h.
◆ ProxyProperty
vtkSMProxyProperty* vtkSMPropertyHelper::ProxyProperty
Definition at line 315 of file vtkSMPropertyHelper.h.
◆ InputProperty
vtkSMInputProperty* vtkSMPropertyHelper::InputProperty
Definition at line 316 of file vtkSMPropertyHelper.h.
