vtkSMVectorProperty Class Referenceabstract
abstract superclass for all vector properties More...
#include <vtkSMVectorProperty.h>
Inheritance diagram for vtkSMVectorProperty:
Collaboration diagram for vtkSMVectorProperty:
typedef vtkSMProperty Superclass
- Public Types inherited from vtkSMProperty
virtual unsigned int GetNumberOfElements ()=0
 Returns the size of the vector. More...
virtual void SetNumberOfElements (unsigned int num)=0
 Sets the size of the vector. More...
void Copy (vtkSMProperty *src) override
 Copy all property values. More...
virtual void SetInitialString (const char *)
virtual char * GetInitialString ()
bool ResetToDomainDefaults (bool use_unchecked_values=false) override
 Overridden to add support to load defaults from this->GetInformationProperty(), if one exists. More...
virtual unsigned int GetNumberOfUncheckedElements ()=0
 API for setting unchecked element values. More...
virtual void SetNumberOfUncheckedElements (unsigned int num)=0
void ClearUncheckedElements () override=0
virtual int GetRepeatCommand ()
 If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More...
virtual void SetRepeatCommand (int)
virtual void RepeatCommandOn ()
virtual void RepeatCommandOff ()
virtual int GetNumberOfElementsPerCommand ()
virtual void SetNumberOfElementsPerCommand (int)
virtual int GetUseIndex ()
 If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More...
virtual void SetUseIndex (int)
virtual void UseIndexOn ()
virtual void UseIndexOff ()
virtual void SetCleanCommand (const char *)
 Command that can be used to remove all values. More...
virtual char * GetCleanCommand ()
virtual void SetSetNumberCommand (const char *)
 If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More...
virtual char * GetSetNumberCommand ()
- Public Member Functions inherited from vtkSMProperty
int IsInDomains ()
 Returns true if all values are in all domains, false otherwise. More...
int IsInDomains (vtkSMDomain **domain)
 Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
void UnRegister (vtkObjectBase *obj) override
 Overloaded to break the reference loop caused by the internal domain iterator. More...
vtkSMDomainIterator * NewDomainIterator ()
 Creates, initializes and returns a new domain iterator. More...
vtkSMDomain * GetDomain (const char *name)
 Returns a domain give a name. More...
vtkSMDomain * FindDomain (const char *classname)
 Returns the first domain which is of the specified type. More...
template<class DomainType >
DomainType * FindDomain ()
 Same as FindDomain(classname), except the classname is deduced from the type. More...
unsigned int GetNumberOfDomains ()
 Returns the number of domains this property has. More...
void AddDomain (const char *name, vtkSMDomain *dom)
 Properties can have one or more domains. More...
virtual void AddLinkedProperty (vtkSMProperty *targetProperty)
 Add a link to a property whose value should be synchronized with this property value. More...
virtual void RemoveLinkedProperty (vtkSMProperty *targetProperty)
 Remove a link to a property added with AddLinkedProperty() More...
virtual void RemoveFromSourceLink ()
 Remove a link from the source property. More...
void ResetToDefault ()
 Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
virtual void ResetToXMLDefaults ()
 For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
vtkSMProxy * GetParent ()
 Get the proxy to which this property belongs. More...
virtual bool IsStateIgnored ()
virtual bool IsValueDefault ()
 Returns true if the property's value is different from the default value. More...
bool HasDomainsWithRequiredProperties ()
 Returns true if the property has a domain with required properties. More...
virtual void SetCommand (const char *)
 The command name used to set the value on the server object. More...
virtual char * GetCommand ()
virtual void SetImmediateUpdate (int)
 If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
virtual int GetImmediateUpdate ()
virtual int GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual int GetIgnoreSynchronization ()
 If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
virtual vtkSMProperty * GetInformationProperty ()
 Get the associated information property. More...
virtual void SetAnimateable (int)
 Get/Set if the property is animateable. More...
virtual int GetAnimateable ()
virtual void SetIsInternal (int)
 Get/Set if the property is internal to server manager. More...
virtual int GetIsInternal ()
virtual void SetNoCustomDefault (int)
 Set/Get whether the property should ignore custom default settings. More...
virtual int GetNoCustomDefault ()
virtual void SetPanelVisibility (const char *)
 Set/Get the panel visibility for the property. More...
virtual char * GetPanelVisibility ()
virtual void SetPanelVisibilityDefaultForRepresentation (const char *)
 Set/Get the panel visibility to default if the current representation type matches representation. More...
virtual char * GetPanelVisibilityDefaultForRepresentation ()
virtual void SetPanelWidget (const char *)
 Set/Get the name of the custom panel widget to use for the property. More...
virtual char * GetPanelWidget ()
virtual void SetDisableSubTrace (const char *)
 Set/Get the tracing of sub property of this property. More...
virtual char * GetDisableSubTrace ()
virtual char * GetXMLLabel ()
 The label assigned by the xml parser. More...
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual int GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
 The server manager configuration XML may define <Hints/> element for a property. More...
void Modified () override
 Overridden to support blocking of modified events. More...
static vtkSMVectorProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMProperty
static vtkSMProperty * New ()
static vtkSMProperty * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMVectorProperty ()
 ~vtkSMVectorProperty () override
int ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override
- Protected Member Functions inherited from vtkSMProperty
 vtkSMProperty ()
 ~vtkSMProperty () override
virtual void WriteTo (vtkSMMessage *msg)
 Let the property write its content into the stream. More...
virtual void ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
 Let the property read and set its content from the stream. More...
virtual void UpdateAllInputs ()
 Update all proxies referred by this property (if any). More...
 Internal. More...
void AddDependent (vtkSMDomain *dom)
 Internal. More...
void RemoveAllDependents ()
 Removes all dependents. More...
void UpdateDomains ()
 Calls Update() on all domains contained by the property as well as all dependent domains. More...
virtual void SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1)
 Save the property state in XML. More...
virtual void SaveStateValues (vtkPVXMLElement *propertyElement)
 This method must be overridden by concrete class in order to save the real property data. More...
virtual void SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid)
 Save property domain. More...
virtual int LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader)
 Updates state from an XML element. More...
virtual void SetInformationOnly (int)
virtual void SetIgnoreSynchronization (int)
void SetInformationProperty (vtkSMProperty *ip)
void SetDocumentation (vtkSMDocumentation *)
void SetParent (vtkSMProxy *proxy)
virtual void SetStateIgnored (bool)
virtual void StateIgnoredOn ()
virtual void StateIgnoredOff ()
bool SetBlockModifiedEvents (bool block)
 Block/unblock modified events, returns the current state of the block flag. More...
virtual bool GetPendingModifiedEvents ()
 Returns if any modified evetns are pending. More...
 vtkSMObject ()
 ~vtkSMObject () override
int RepeatCommand
int NumberOfElementsPerCommand
int UseIndex
char * CleanCommand
char * SetNumberCommand
char * InitialString
- Protected Attributes inherited from vtkSMProperty
vtkPVXMLElement * Hints
char * Command
vtkSMPropertyInternals * PInternals
int ImmediateUpdate
int Animateable
int IsInternal
int NoCustomDefault
char * XMLName
char * XMLLabel
char * PanelVisibility
char * PanelVisibilityDefaultForRepresentation
char * PanelWidget
char * DisableSubTrace
vtkSMDomainIterator * DomainIterator
int InformationOnly
int IgnoreSynchronization
vtkSMInformationHelper * InformationHelper
vtkSMProperty * InformationProperty
int Repeatable
vtkWeakPointer< vtkSMProxy > Proxy
bool StateIgnored
vtkSMPropertyLink * Links
vtkSMVectorProperty defines an interface common to all vector properties as well as some common settings. A vector property contains a list of values passed to one or more invocations of a command. How the values are distributed to the different invocations is controlled by several parameters.
Definition at line 20 of file vtkSMVectorProperty.h.
Definition at line 23 of file vtkSMVectorProperty.h.
◆ vtkSMVectorProperty()
vtkSMVectorProperty::vtkSMVectorProperty ( )
◆ ~vtkSMVectorProperty()
vtkSMVectorProperty::~vtkSMVectorProperty ( )
virtual const char* vtkSMVectorProperty::GetClassName ( )
static int vtkSMVectorProperty::IsTypeOf ( const char *  type)
virtual int vtkSMVectorProperty::IsA ( const char *  type)
static vtkSMVectorProperty* vtkSMVectorProperty::SafeDownCast ( vtkObject *  o)
void vtkSMVectorProperty::PrintSelf ( ostream &  os,
Reimplemented from vtkSMProperty.
◆ GetNumberOfElements()
virtual unsigned int vtkSMVectorProperty::GetNumberOfElements ( )
pure virtual
◆ SetNumberOfElements()
virtual void vtkSMVectorProperty::SetNumberOfElements ( unsigned int  num)
pure virtual
◆ GetNumberOfUncheckedElements()
virtual unsigned int vtkSMVectorProperty::GetNumberOfUncheckedElements ( )
pure virtual
Implemented in vtkSMStringVectorProperty, vtkSMIdTypeVectorProperty, vtkSMIntVectorProperty, and vtkSMDoubleVectorProperty.
◆ SetNumberOfUncheckedElements()
virtual void vtkSMVectorProperty::SetNumberOfUncheckedElements ( unsigned int  num)
pure virtual
Implemented in vtkSMIntVectorProperty, vtkSMDoubleVectorProperty, vtkSMIdTypeVectorProperty, and vtkSMStringVectorProperty.
◆ ClearUncheckedElements()
void vtkSMVectorProperty::ClearUncheckedElements ( )
overridepure virtual
Implemented in vtkSMStringVectorProperty, vtkSMIdTypeVectorProperty, vtkSMDoubleVectorProperty, and vtkSMIntVectorProperty.
◆ GetRepeatCommand()
virtual int vtkSMVectorProperty::GetRepeatCommand ( )
For example, if RepeatCommand is true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 1 2 3 4 5 6, the resulting stream will have:
* * Invoke obj SetFoo 1 2
* * Invoke obj SetFoo 3 4
* * Invoke obj SetFoo 5 6
◆ SetRepeatCommand()
virtual void vtkSMVectorProperty::SetRepeatCommand ( int  )
◆ RepeatCommandOn()
virtual void vtkSMVectorProperty::RepeatCommandOn ( )
◆ RepeatCommandOff()
virtual void vtkSMVectorProperty::RepeatCommandOff ( )
◆ GetNumberOfElementsPerCommand()
virtual int vtkSMVectorProperty::GetNumberOfElementsPerCommand ( )
◆ SetNumberOfElementsPerCommand()
virtual void vtkSMVectorProperty::SetNumberOfElementsPerCommand ( int  )
◆ GetUseIndex()
virtual int vtkSMVectorProperty::GetUseIndex ( )
For example, if UseIndex and RepeatCommand are true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 5 6 7 8 9 10, the resulting stream will have:
* * Invoke obj SetFoo 0 5 6
* * Invoke obj SetFoo 1 7 8
* * Invoke obj SetFoo 2 9 10
◆ SetUseIndex()
virtual void vtkSMVectorProperty::SetUseIndex ( int  )
◆ UseIndexOn()
virtual void vtkSMVectorProperty::UseIndexOn ( )
◆ UseIndexOff()
virtual void vtkSMVectorProperty::UseIndexOff ( )
◆ SetCleanCommand()
virtual void vtkSMVectorProperty::SetCleanCommand ( const char *  )
Typically used when RepeatCommand = 1. If set, the clean command is called before the main Command.
◆ GetCleanCommand()
virtual char* vtkSMVectorProperty::GetCleanCommand ( )
◆ Copy()
void vtkSMVectorProperty::Copy ( vtkSMProperty *  src)
◆ SetSetNumberCommand()
virtual void vtkSMVectorProperty::SetSetNumberCommand ( const char *  )
◆ GetSetNumberCommand()
virtual char* vtkSMVectorProperty::GetSetNumberCommand ( )
◆ SetInitialString()
virtual void vtkSMVectorProperty::SetInitialString ( const char *  )
◆ GetInitialString()
virtual char* vtkSMVectorProperty::GetInitialString ( )
◆ ResetToDomainDefaults()
bool vtkSMVectorProperty::ResetToDomainDefaults ( bool  use_unchecked_values = false)
If the superclass (which checks for defaults from all domains) doesn't end up picking a default, as a last resort, we check if the property has a non-empty information_property. If so, we copy its values to this property as the default.
◆ ReadXMLAttributes()
int vtkSMVectorProperty::ReadXMLAttributes ( vtkSMProxy *  parent,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ RepeatCommand
int vtkSMVectorProperty::RepeatCommand
Definition at line 138 of file vtkSMVectorProperty.h.
◆ NumberOfElementsPerCommand
int vtkSMVectorProperty::NumberOfElementsPerCommand
Definition at line 139 of file vtkSMVectorProperty.h.
◆ UseIndex
int vtkSMVectorProperty::UseIndex
Definition at line 140 of file vtkSMVectorProperty.h.
◆ CleanCommand
char* vtkSMVectorProperty::CleanCommand
Definition at line 142 of file vtkSMVectorProperty.h.
◆ SetNumberCommand
char* vtkSMVectorProperty::SetNumberCommand
Definition at line 143 of file vtkSMVectorProperty.h.
◆ InitialString
char* vtkSMVectorProperty::InitialString
Definition at line 144 of file vtkSMVectorProperty.h.
