Holds class name. More...
#include <vtkPVClassNameInformation.h>
| typedef vtkPVInformation | Superclass |
Public Types inherited from vtkPVInformation | |
| void | CopyFromObject (vtkObject *) override |
| Transfer information about a single object into this object. More... | |
| void | AddInformation (vtkPVInformation *) override |
| Merge another information object. More... | |
| virtual void | SetPortNumber (int) |
| Port number controls which output port the information is gathered from. More... | |
| Get class name of VTK object. More... | |
| void | CopyToStream (vtkClientServerStream *) override |
| Manage a serialized version of the information. More... | |
| void | CopyFromStream (const vtkClientServerStream *) override |
| void | CopyParametersToStream (vtkMultiProcessStream &) override |
| Serialize/Deserialize the parameters that control how/what information is gathered. More... | |
| void | CopyParametersFromStream (vtkMultiProcessStream &) override |
Public Member Functions inherited from vtkPVInformation | |
| virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More... | |
| static vtkPVClassNameInformation * | New () |
| static vtkPVClassNameInformation * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkPVInformation | |
| static vtkPVInformation * | SafeDownCast (vtkObject *o) |
| vtkPVClassNameInformation () | |
| ~vtkPVClassNameInformation () override | |
Protected Member Functions inherited from vtkPVInformation | |
| vtkPVInformation () | |
| ~vtkPVInformation () override | |
| virtual void | SetRootOnly (int) |
| vtkPVInformation (const vtkPVInformation &)=delete | |
| void | operator= (const vtkPVInformation &)=delete |
Protected Attributes | |
| int | PortNumber |
| char * | VTKClassName |
Protected Attributes inherited from vtkPVInformation | |
| int | RootOnly |
Holds class name.
This information object gets the class name of the input VTK object. This is separate from vtkPVDataInformation because it can be determined before Update is called and because it operates on any VTK object.
Definition at line 18 of file vtkPVClassNameInformation.h.
Definition at line 22 of file vtkPVClassNameInformation.h.
Reimplemented from vtkPVInformation.
This is only applicable when the vtkObject from which the information being gathered is a vtkAlgorithm. Set it to -1(default), to return the classname of the vtkAlgorithm itself. This is the only parameter that can be set on the client-side before gathering the information.
Implements vtkPVInformation.
This are different from the ivars that constitute the gathered information itself. For example, PortNumber on vtkPVDataInformation controls what output port the data-information is gathered from.
protectedvirtual |
Definition at line 77 of file vtkPVClassNameInformation.h.
Definition at line 78 of file vtkPVClassNameInformation.h.
