vtkSMSession.h
10 #ifndef vtkSMSession_h
11 #define vtkSMSession_h
12
13 #include "vtkNetworkAccessManager.h" // needed for vtkNetworkAccessManager::ConnectionResult.
14 #include "vtkPVSessionBase.h"
15 #include "vtkRemotingServerManagerModule.h" //needed for exports
16
18 class vtkSMProxyLocator;
20 class vtkSMStateLocator;
21
22 class VTKREMOTINGSERVERMANAGER_EXPORT vtkSMSession : public vtkPVSessionBase
23 {
24 public:
25  static vtkSMSession* New();
26  static vtkSMSession* New(vtkPVSessionBase* otherSession);
27  static vtkSMSession* New(vtkPVSessionCore* otherSessionCore);
29  void PrintSelf(ostream& os, vtkIndent indent) override;
30
31  //---------------------------------------------------------------------------
32  // API for collaboration management
33  //---------------------------------------------------------------------------
40  virtual vtkSMCollaborationManager* GetCollaborationManager() { return nullptr; }
41
42  //---------------------------------------------------------------------------
43  // API for client-side components of a session.
44  //---------------------------------------------------------------------------
45
50  virtual const char* GetURI() { return "builtin:"; }
51
53
56  vtkGetObjectMacro(SessionProxyManager, vtkSMSessionProxyManager);
58
66  virtual int GetNumberOfProcesses(vtkTypeUInt32 servers);
67
73  virtual bool IsMPIInitialized(vtkTypeUInt32 servers);
74
75  //---------------------------------------------------------------------------
76  // API for Proxy Finder/ReNew
77  //---------------------------------------------------------------------------
78
79  vtkGetObjectMacro(ProxyLocator, vtkSMProxyLocator);
80
82  {
83  RENDERING_NOT_AVAILABLE = 0x00,
84  RENDERING_UNIFIED = 0x01,
85  RENDERING_SPLIT = 0x02
86  };
87
95  virtual unsigned int GetRenderClientMode();
96
97  //---------------------------------------------------------------------------
98  // Undo/Redo related API.
99  //---------------------------------------------------------------------------
100
102
108  vtkGetObjectMacro(StateLocator, vtkSMStateLocator);
110
111  //---------------------------------------------------------------------------
112  // Superclass Implementations
113  //---------------------------------------------------------------------------
114
118  bool GetIsAlive() override { return true; }
119
127  ServerFlags GetProcessRoles() override;
128
133  void PushState(vtkSMMessage* msg) override;
134
138  void NotifyAllClients(const vtkSMMessage* msg) override { this->ProcessNotification(msg); }
139
143  void NotifyOtherClients(const vtkSMMessage*) override
144  { /* nothing to do. */
145  }
146
147  //---------------------------------------------------------------------------
148  // API for Collaboration management
149  //---------------------------------------------------------------------------
150
151  // Called before application quit or session disconnection
152  virtual void PreDisconnection() {}
153
154  //---------------------------------------------------------------------------
155  // Static methods to create and register sessions easily.
156  //---------------------------------------------------------------------------
157
164  static vtkIdType ConnectToCatalyst();
165
167
173  static vtkIdType ConnectToSelf();
175
177
188  static vtkIdType ConnectToRemote(const char* hostname, int port, int timeout = 60)
189  {
191  return vtkSMSession::ConnectToRemote(hostname, port, timeout, nullptr, result);
192  }
193  static vtkIdType ConnectToRemote(const char* hostname, int port, int timeout, bool (*callback)(),
196
198
208  {
210  }
211  static vtkIdType ReverseConnectToRemoteWithTimeout(int port, int timeout)
212  {
214  return vtkSMSession::ReverseConnectToRemote(port, timeout, nullptr, result);
215  }
216  static vtkIdType ReverseConnectToRemote(
217  int port, int timeout, bool (*callback)(), vtkNetworkAccessManager::ConnectionResult& result);
219
221
233  const char* dshost, int dsport, const char* rshost, int rsport, int timeout = 60)
234  {
236  return vtkSMSession::ConnectToRemote(dshost, dsport, rshost, rsport, timeout, nullptr, result);
237  }
238  static vtkIdType ConnectToRemote(const char* dshost, int dsport, const char* rshost, int rsport,
239  int timeout, bool (*callback)(), vtkNetworkAccessManager::ConnectionResult& result);
241
243
252  static vtkIdType ReverseConnectToRemote(int dsport, int rsport)
253  {
254  return vtkSMSession::ReverseConnectToRemoteWithTimeout(dsport, rsport, 60);
255  }
256  static vtkIdType ReverseConnectToRemoteWithTimeout(int dsport, int rsport, int timeout)
257  {
259  return vtkSMSession::ReverseConnectToRemote(dsport, rsport, timeout, nullptr, result);
260  }
261  static vtkIdType ReverseConnectToRemote(int dsport, int rsport, int timeout, bool (*callback)(),
264
266
272  static void Disconnect(vtkIdType sessionid);
273  static void Disconnect(vtkSMSession* session);
275
276 protected:
277  // Subclasses should set initialize_during_constructor to false so that
278  // this->Initialize() is not called in constructor but only after the session
279  // has been created/setup correctly.
280  vtkSMSession(
281  bool initialize_during_constructor = true, vtkPVSessionCore* preExistingSessionCore = nullptr);
282  ~vtkSMSession() override;
283
288  virtual void ProcessNotification(const vtkSMMessage*);
289
294  virtual void Initialize();
295
301  void UpdateStateHistory(vtkSMMessage* msg);
302
306
307 private:
308  vtkSMSession(const vtkSMSession&) = delete;
309  void operator=(const vtkSMSession&) = delete;
310 };
311
312 #endif
Definition: vtkSMSessionProxyManager.h:135
vtkPVSessionBase.h
Same as ConnectToRemote() except that it waits for a reverse connection for timeout seconds.
Definition: vtkSMSession.h:256
vtkSMSession::GetCollaborationManager
virtual vtkSMCollaborationManager * GetCollaborationManager()
Return the instance of vtkSMCollaborationManager that will be lazy created at the first call.
Definition: vtkSMSession.h:40
vtkSMSession::StateLocator
vtkSMStateLocator * StateLocator
Definition: vtkSMSession.h:304
static vtkIdType ConnectToRemote(const char *hostname, int port, int timeout=60)
These are static helper methods that help create standard ParaView sessions.
Definition: vtkSMSession.h:188
vtkIdType
int vtkIdType
vtkObject::New
static vtkObject * New()
static vtkIdType ConnectToRemote(const char *dshost, int dsport, const char *rshost, int rsport, int timeout=60)
Definition: vtkSMSession.h:232
Definition: vtkSMSession.h:211
vtkPVSessionBase
Definition: vtkPVSessionBase.h:27
vtkSMSession::ProxyLocator
vtkSMProxyLocator * ProxyLocator
Definition: vtkSMSession.h:305
ConnectionResult
Possible result of connection when creating a new connection CONNECTION_SUCCESS: Connection was suces...
Definition: vtkNetworkAccessManager.h:34
vtkSMSession::SessionProxyManager
vtkSMSessionProxyManager * SessionProxyManager
Definition: vtkSMSession.h:303
port
port
vtkPVSessionBase::GetProcessRoles
Returns a ServerFlags indicate the nature of the current processes.
static vtkIdType ReverseConnectToRemote(int port)
Definition: vtkSMSession.h:207
vtkSMSession
Definition: vtkSMSession.h:22
vtkIndent
vtkSMMessage
vtkSMSession::GetURI
virtual const char * GetURI()
Return the URL that define where the session is connected to.
Definition: vtkSMSession.h:50
vtkSMSession::GetIsAlive
Builtin session is always alive.
Definition: vtkSMSession.h:118
vtkPVSessionCore
Definition: vtkPVSessionCore.h:30
Class used to broadcast message from one client to the others.
Definition: vtkSMCollaborationManager.h:36
Definition: vtkSMSession.h:252
vtkSMSession::RenderingMode
RenderingMode
Definition: vtkSMSession.h:81
vtkPVSessionBase::PrintSelf
vtkSMProxyLocator
Definition: vtkSMProxyLocator.h:24
vtkSMStateLocator
Class used to retrieve a given message state based on its GlobalID.
Definition: vtkSMStateLocator.h:23
vtkPVSessionBase::PushState
virtual void PushState(vtkSMMessage *msg)
Push the state message.
vtkSMSession::NotifyAllClients
void NotifyAllClients(const vtkSMMessage *msg) override
Sends the message to all clients.
Definition: vtkSMSession.h:138
vtkSMSession::PreDisconnection
Definition: vtkSMSession.h:152
vtkSMSession::NotifyOtherClients
void NotifyOtherClients(const vtkSMMessage *) override
Sends the message to all but the active client-session.
Definition: vtkSMSession.h:143
