vtkSMTimeKeeperProxy Class Reference
#include <vtkSMTimeKeeperProxy.h>
Inheritance diagram for vtkSMTimeKeeperProxy:
Collaboration diagram for vtkSMTimeKeeperProxy:
typedef vtkSMProxy Superclass
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMTimeKeeperProxy * New ()
static vtkSMTimeKeeperProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMTimeKeeperProxy ()
 ~vtkSMTimeKeeperProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static bool AddTimeSource (vtkSMProxy *timeKeeper, vtkSMProxy *proxy, bool suppress_input)
 Track timesteps provided by a source. More...
virtual bool AddTimeSource (vtkSMProxy *proxy, bool suppress_input)
static bool RemoveTimeSource (vtkSMProxy *timeKeeper, vtkSMProxy *proxy, bool unsuppress_input)
 Remove a particular time source. More...
virtual bool RemoveTimeSource (vtkSMProxy *proxy, bool unsuppress_input)
static bool IsTimeSourceTracked (vtkSMProxy *timeKeeper, vtkSMProxy *proxy)
 Returns true if the proxy has been added to time sources and not suppressed. More...
virtual bool IsTimeSourceTracked (vtkSMProxy *proxy)
static bool SetSuppressTimeSource (vtkSMProxy *timeKeeper, vtkSMProxy *proxy, bool suppress)
 Set whether to suppress a time source that has been added to the time keeper. More...
virtual bool SetSuppressTimeSource (vtkSMProxy *proxy, bool suppress)
static double GetLowerBoundTimeStep (vtkSMProxy *timeKeeper, double value)
 Returns a time value after snapping to a lower-bound in the current timesteps. More...
virtual double GetLowerBoundTimeStep (double value)
static int GetLowerBoundTimeStepIndex (vtkSMProxy *timeKeeper, double value)
 Returns the index for the lower bound of the time specified in current timestep values, if possible. More...
virtual int GetLowerBoundTimeStepIndex (double value)
static void UpdateTimeInformation (vtkSMProxy *timeKeeper)
 Iterates over all sources providing time and calls vtkSMSourceProxy::UpdatePipelineInformation on them. More...
virtual void UpdateTimeInformation ()
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
We simply pass the TimestepValues and TimeRange properties to the client-side vtkSMTimeKeeper instance so that it can keep those up-to-date.
Definition at line 16 of file vtkSMTimeKeeperProxy.h.
Definition at line 20 of file vtkSMTimeKeeperProxy.h.
◆ vtkSMTimeKeeperProxy()
vtkSMTimeKeeperProxy::vtkSMTimeKeeperProxy ( )
◆ ~vtkSMTimeKeeperProxy()
vtkSMTimeKeeperProxy::~vtkSMTimeKeeperProxy ( )
static vtkSMTimeKeeperProxy* vtkSMTimeKeeperProxy::New ( )
virtual const char* vtkSMTimeKeeperProxy::GetClassName ( )
static int vtkSMTimeKeeperProxy::IsTypeOf ( const char *  type)
virtual int vtkSMTimeKeeperProxy::IsA ( const char *  type)
static vtkSMTimeKeeperProxy* vtkSMTimeKeeperProxy::SafeDownCast ( vtkObject *  o)
void vtkSMTimeKeeperProxy::PrintSelf ( ostream &  os,
◆ AddTimeSource() [1/2]
virtual bool vtkSMTimeKeeperProxy::AddTimeSource ( vtkSMProxy *  proxy,
bool  suppress_input
If suppress_input is true, before adding the proxy, if the proxy has producers those will be removed from the time sources i.e. we'll ignore timesteps from the input.
◆ AddTimeSource() [2/2]
static bool vtkSMTimeKeeperProxy::AddTimeSource ( vtkSMProxy *  timeKeeper,
vtkSMProxy *  proxy,
bool  suppress_input
inlinestatic
Definition at line 30 of file vtkSMTimeKeeperProxy.h.
◆ RemoveTimeSource() [1/2]
virtual bool vtkSMTimeKeeperProxy::RemoveTimeSource ( vtkSMProxy *  proxy,
◆ RemoveTimeSource() [2/2]
static bool vtkSMTimeKeeperProxy::RemoveTimeSource ( vtkSMProxy *  timeKeeper,
vtkSMProxy *  proxy,
inlinestatic
Definition at line 42 of file vtkSMTimeKeeperProxy.h.
◆ IsTimeSourceTracked() [1/2]
virtual bool vtkSMTimeKeeperProxy::IsTimeSourceTracked ( vtkSMProxy *  proxy)
◆ IsTimeSourceTracked() [2/2]
static bool vtkSMTimeKeeperProxy::IsTimeSourceTracked ( vtkSMProxy *  timeKeeper,
vtkSMProxy *  proxy
inlinestatic
Definition at line 55 of file vtkSMTimeKeeperProxy.h.
◆ SetSuppressTimeSource() [1/2]
virtual bool vtkSMTimeKeeperProxy::SetSuppressTimeSource ( vtkSMProxy *  proxy,
bool  suppress
Suppressing a source results in its time being ignored by the time keeper.
◆ SetSuppressTimeSource() [2/2]
static bool vtkSMTimeKeeperProxy::SetSuppressTimeSource ( vtkSMProxy *  timeKeeper,
vtkSMProxy *  proxy,
bool  suppress
inlinestatic
Definition at line 69 of file vtkSMTimeKeeperProxy.h.
◆ GetLowerBoundTimeStep() [1/2]
virtual double vtkSMTimeKeeperProxy::GetLowerBoundTimeStep ( double  value)
◆ GetLowerBoundTimeStep() [2/2]
static double vtkSMTimeKeeperProxy::GetLowerBoundTimeStep ( vtkSMProxy *  timeKeeper,
double  value
inlinestatic
Definition at line 82 of file vtkSMTimeKeeperProxy.h.
◆ GetLowerBoundTimeStepIndex() [1/2]
virtual int vtkSMTimeKeeperProxy::GetLowerBoundTimeStepIndex ( double  value)
If there are no timestep values, returns 0.
◆ GetLowerBoundTimeStepIndex() [2/2]
static int vtkSMTimeKeeperProxy::GetLowerBoundTimeStepIndex ( vtkSMProxy *  timeKeeper,
double  value
inlinestatic
Definition at line 95 of file vtkSMTimeKeeperProxy.h.
◆ UpdateTimeInformation() [1/2]
virtual void vtkSMTimeKeeperProxy::UpdateTimeInformation ( )
That ensures that timekeeper is using the latest time information available to it.
◆ UpdateTimeInformation() [2/2]
static void vtkSMTimeKeeperProxy::UpdateTimeInformation ( vtkSMProxy *  timeKeeper)
inlinestatic
Definition at line 109 of file vtkSMTimeKeeperProxy.h.
◆ CreateVTKObjects()
void vtkSMTimeKeeperProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
