vtkSMSettingsProxy Class Reference
proxy subclass responsible for linking settings proxies and settings classes on the VTK side. More...
#include <vtkSMSettingsProxy.h>
Inheritance diagram for vtkSMSettingsProxy:
Collaboration diagram for vtkSMSettingsProxy:
typedef vtkSMProxy Superclass
 Overridden to link information properties with their corresponding "setter" properties. More...
const char * GetSourcePropertyName (vtkSMProxy *target, const char *targetProperty)
 Returns the name of the sourceProperty, if any, with which the target property is linked. More...
void AddLink (const char *sourceProperty, vtkSMProxy *target, const char *targetProperty, bool unlink_if_modified)
 Add/Remove links. More...
void RemoveLink (const char *sourceProperty, vtkSMProxy *target, const char *targetProperty)
void SaveLinksState (vtkPVXMLElement *root)
 Save/Load the state for links registered with this settings proxy. More...
void LoadLinksState (vtkPVXMLElement *root, vtkSMProxyLocator *locator)
virtual void SetIsSerializable (bool)
 Get/Set whether the settings proxy is serializable. More...
virtual bool GetIsSerializable ()
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMSettingsProxy * New ()
static vtkSMSettingsProxy * SafeDownCast (vtkObject *o)
static void ProcessPropertyLinks (vtkSMProxy *proxy)
 Process property link hints on the given proxy. More...
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMSettingsProxy ()
 ~vtkSMSettingsProxy () override
 Overridden from vtkSMProxy to install an observer on the VTK object. More...
void SetPropertyModifiedFlag (const char *name, int flag) override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Settings proxies are session specific singleton proxies designed to track configuration options. Typically, properties on such settings proxies are linked to other proxies in the session so that changing a setting property will result in changing all linked proxies.
Settings proxies have several unique traits when compared with other properties:
  1. In ReadXMLAttributes, if for a property an information_property attribute is specified i.e. vtkSMProperty::GetInformationProperty is not null, then a link is setup between that information property and the original property so that if the information property is modified, the original property is updated accordingly.
  2. Settings proxies may have an underlying vtkObject class that they instantiate locally. In which case, the proxy observes vtkCommand::ModifiedEvent on that VTK object and calls vtkSMProxy::UpdatePropertyInformation on itself to ensure all information properties are updated if the vtkObject changes.
vtkSMSettingsProxy::ProcessPropertyLinks is called during proxy initialization (vtkSMParaViewPipelineController::PreInitializeProxy) to setup links between the proxy being initialized any of the settings proxies for that session. This is done by processing property hints on the proxy being initialized.
SettingsProxies and state files
By default, settings proxies are not saved in the XML state files by vtkSMSessionProxyManager::SaveXMLState. This is so since settings proxies are often used for application settings to preserve across sessions rather than visualization state. However, there are exceptions. For example, color palettes which are handled using a settings proxy are part of the visualization state and hence should be saved in the XML state. For such settings proxies, one can add the serializable="1" attribute in the proxy definition XML.
<SettingsProxy name="ColorPalette" label="Color Palette" serializable="1">
</SettingsProxy>
All settings proxies with this attribute will be saved in the XML state files.
Definition at line 59 of file vtkSMSettingsProxy.h.
Definition at line 63 of file vtkSMSettingsProxy.h.
◆ vtkSMSettingsProxy()
vtkSMSettingsProxy::vtkSMSettingsProxy ( )
◆ ~vtkSMSettingsProxy()
vtkSMSettingsProxy::~vtkSMSettingsProxy ( )
static vtkSMSettingsProxy* vtkSMSettingsProxy::New ( )
virtual const char* vtkSMSettingsProxy::GetClassName ( )
static int vtkSMSettingsProxy::IsTypeOf ( const char *  type)
virtual int vtkSMSettingsProxy::IsA ( const char *  type)
static vtkSMSettingsProxy* vtkSMSettingsProxy::SafeDownCast ( vtkObject *  o)
void vtkSMSettingsProxy::PrintSelf ( ostream &  os,
◆ ReadXMLAttributes()
int vtkSMSettingsProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
vtkPVXMLElement *  element
◆ ProcessPropertyLinks()
static void vtkSMSettingsProxy::ProcessPropertyLinks ( vtkSMProxy *  proxy)
◆ AddLink()
void vtkSMSettingsProxy::AddLink ( const char *  sourceProperty,
vtkSMProxy *  target,
const char *  targetProperty,
Add/Remove links.
If unlink_if_modified is true, if a linked property on the target proxy is modified independently, then the link is broken to avoid overriding the explicitly selected value.
◆ RemoveLink()
void vtkSMSettingsProxy::RemoveLink ( const char *  sourceProperty,
Add/Remove links.
◆ GetSourcePropertyName()
const char* vtkSMSettingsProxy::GetSourcePropertyName ( vtkSMProxy *  target,
Returns nullptr if no such link has been added.
◆ SaveLinksState()
void vtkSMSettingsProxy::SaveLinksState ( vtkPVXMLElement *  root)
◆ LoadLinksState()
void vtkSMSettingsProxy::LoadLinksState ( vtkPVXMLElement *  root,
vtkSMProxyLocator *  locator
◆ SetIsSerializable()
virtual void vtkSMSettingsProxy::SetIsSerializable ( bool  )
◆ GetIsSerializable()
virtual bool vtkSMSettingsProxy::GetIsSerializable ( )
◆ CreateVTKObjects()
void vtkSMSettingsProxy::CreateVTKObjects ( )
overrideprotectedvirtual
◆ SetPropertyModifiedFlag()
void vtkSMSettingsProxy::SetPropertyModifiedFlag ( const char *  name,
int  flag
Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself.
Here is a brief explanation of how modified flags are used:
  • 1. When a property is modified, the modified flag is set
  • 2. In UpdateVTKObjects(), the proxy visits all properties and calls AppendCommandToStream() on each modified property. It also resets the modified flag.
The reason why the modified flag is stored in the proxy instead of property is in item 2 above. If multiple proxies were sharing the same property, the first one would reset the modified flag in UpdateVTKObjects() and then others would not call AppendCommandToStream() in their turn. Therefore, each proxy has to keep track of all properties it updated. This is done by adding observers to the properties. When a property is modified, it invokes all observers and the observers set the appropriate flags in the proxies. Changes the modified flag of a property. Used by the observers
