vtkSMParaViewPipelineController Class Reference
Controller that encapsulates control logic for typical ParaView applications. More...
#include <vtkSMParaViewPipelineController.h>
Inheritance diagram for vtkSMParaViewPipelineController:
Collaboration diagram for vtkSMParaViewPipelineController:
virtual bool InitializeSession (vtkSMSession *session)
 Call this method to setup a branch new session with state considered essential for ParaView session. More...
virtual vtkSMProxy * FindTimeKeeper (vtkSMSession *session)
 Returns the TimeKeeper proxy associated with the session. More...
virtual vtkSMProxy * FindMaterialLibrary (vtkSMSession *session)
 Returns the MaterialLibrary proxy associated with the session. More...
virtual bool PreInitializeProxy (vtkSMProxy *proxy)
 Pre-initializes a proxy i.e. More...
virtual bool PostInitializeProxy (vtkSMProxy *proxy)
 Final step in proxy initialization. More...
bool InitializeProxy (vtkSMProxy *proxy)
 Convenience method to call PreInitializeProxy and PostInitializeProxy. More...
virtual bool FinalizeProxy (vtkSMProxy *proxy)
 Cleans up any helper proxies registered for the proxy in PreInitializeProxy/PostInitializeProxy. More...
virtual bool RegisterPipelineProxy (vtkSMProxy *proxy, const char *proxyname)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register a pipeline proxy with the proxy manager. More...
virtual bool RegisterPipelineProxy (vtkSMProxy *proxy)
virtual bool UnRegisterPipelineProxy (vtkSMProxy *proxy)
 Unregisters a pipeline proxy. More...
virtual bool RegisterViewProxy (vtkSMProxy *proxy)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register a view proxy with the proxy manager. More...
virtual bool RegisterViewProxy (vtkSMProxy *proxy, const char *proxyname)
virtual bool UnRegisterViewProxy (vtkSMProxy *proxy, bool unregister_representations=true)
 Inverse of RegisterViewProxy. More...
virtual bool UnRegisterRepresentationProxy (vtkSMProxy *proxy)
 Unregisters a representation proxy. More...
virtual bool RegisterColorTransferFunctionProxy (vtkSMProxy *proxy, const char *proxyname)
 Registration method for color transfer function proxies to be used after PreInitializeProxy() and PostInitializeProxy() calls. More...
virtual bool RegisterColorTransferFunctionProxy (vtkSMProxy *proxy)
virtual bool RegisterOpacityTransferFunction (vtkSMProxy *proxy, const char *proxyname)
 Registration method for opacity transfer function proxies. More...
virtual bool RegisterOpacityTransferFunction (vtkSMProxy *proxy)
virtual bool RegisterTransferFunction2D (vtkSMProxy *proxy, const char *proxyname)
 Registration method for 2D transfer function proxies. More...
virtual bool RegisterTransferFunction2D (vtkSMProxy *proxy)
virtual bool RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view, const char *proxyname)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register a light proxy with the proxy manager. More...
virtual bool RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view)
virtual bool RegisterTextureProxy (vtkSMProxy *proxy, const char *filename)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register a texture proxy with the proxy manager. More...
virtual bool RegisterExtractorProxy (vtkSMProxy *proxy, const char *proxyname)
 Registers an extractor. More...
virtual bool RegisterExtractorProxy (vtkSMProxy *proxy)
virtual vtkSMProxy * FindAnimationScene (vtkSMSession *session)
 Returns the animation scene, if any. More...
virtual vtkSMProxy * GetAnimationScene (vtkSMSession *session)
 Returns the animation scene for the session. More...
virtual vtkSMProxy * FindTimeAnimationTrack (vtkSMProxy *scene)
 Return the animation track for time, if any. More...
virtual vtkSMProxy * GetTimeAnimationTrack (vtkSMProxy *scene)
 Return the animation track for time. More...
virtual bool RegisterAnimationProxy (vtkSMProxy *proxy)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register an animation proxy with the proxy manager. More...
virtual bool UnRegisterAnimationProxy (vtkSMProxy *proxy)
 Inverse of RegisterAnimationProxy. More...
virtual void UpdateSettingsProxies (vtkSMSession *session)
 Initializes and registers proxies in the "settings" group that haven't been already. More...
virtual bool UnRegisterProxy (vtkSMProxy *proxy)
 A catch-all method do cleanup and unregister any proxies that were registered using Register..Proxy() APIs on this class. More...
virtual bool RegisterRepresentationProxy (vtkSMProxy *proxy)
 Registration method for representations to be used after PreInitializeProxy() and PostInitializeProxy(). More...
virtual bool RegisterRepresentationProxy (vtkSMProxy *proxy, const char *proxyname)
static vtkSMParaViewPipelineController * New ()
static vtkSMParaViewPipelineController * SafeDownCast (vtkObject *o)
static std::string GetHelperProxyGroupName (vtkSMProxy *)
 For a given proxy returns the name of the group used for helper proxies. More...
static vtkSMObject * New ()
 vtkSMParaViewPipelineController ()
 ~vtkSMParaViewPipelineController () override
vtkSMProxy * FindProxy (vtkSMSessionProxyManager *pxm, const char *reggroup, const char *xmlgroup, const char *xmltype)
 Find proxy of the group type (xmlgroup, xmltype) registered under a particular group (reggroup). More...
virtual bool SetupGlobalPropertiesLinks (vtkSMProxy *proxy)
 Setup global properties links based on hints for properties in the XML. More...
virtual bool CreateAnimationHelpers (vtkSMProxy *proxy)
 To help animation representation properties such as visibility, opacity, we create animation helpers. More...
virtual bool UnRegisterDependencies (vtkSMProxy *proxy)
 Unregisters know proxy dependencies that must be removed when the proxy is to be deleted e.g animation cues, representations, etc. More...
vtkMTimeType GetInitializationTime (vtkSMProxy *)
 Returns the initialization timestamp for the proxy, if available. More...
void ProcessInitializationHelperRegistration (vtkSMProxy *)
 If the proxy has initialization helpers, let those classes also handle registration tasks, if any. More...
 PARAVIEW_DEPRECATED_IN_5_12_0 ("Material setup is now handled by the RenderView proxy on raytracing back-end update") virtual void DoMaterialSetup(vtkSMProxy *proxy)
 An entry point to load a catalog of OSPRay rendering materials. More...
virtual bool CreateProxiesForProxyListDomains (vtkSMProxy *proxy)
 Creates new proxies for proxies referred in vtkSMProxyListDomain for any of the properties for the given proxy. More...
virtual void RegisterProxiesForProxyListDomains (vtkSMProxy *proxy)
void ProcessInitializationHelper (vtkSMProxy *, vtkMTimeType initializationTimeStamp)
 Proxies can specify custom initialization using XML hints. More...
 vtkSMObject ()
 ~vtkSMObject () override
ParaView's ServerManager, together with it's proxies and properties provides a mechanism to create visualization and data processing pipelines. However, for a complex application like ParaView, there is considerable control logic to manage these proxies, set them up, etc. for common operations supported by the application. vtkSMParaViewPipelineController provides us a mechanism to encapsulate just control logic with ability to customize and extend for custom applications, similar to ParaView.
vtkSMParaViewPipelineController has no state of itself. When needed, one should simply create an instance of vtkSMParaViewPipelineController and release it once done.
vtkSMParaViewPipelineController uses the vtkObjectFactory mechanism. Custom application developers can provide subclasses and override the behaviour (see vtkSMParaViewPipelineControllerWithRender).
For an example of using vtkSMParaViewPipelineController in your application, see Remoting/Views/Testing/Cxx/TestParaViewPipelineController.cxx.
Definition at line 41 of file vtkSMParaViewPipelineController.h.
Definition at line 45 of file vtkSMParaViewPipelineController.h.
◆ vtkSMParaViewPipelineController()
vtkSMParaViewPipelineController::vtkSMParaViewPipelineController ( )
◆ ~vtkSMParaViewPipelineController()
vtkSMParaViewPipelineController::~vtkSMParaViewPipelineController ( )
static vtkSMParaViewPipelineController* vtkSMParaViewPipelineController::New ( )
virtual const char* vtkSMParaViewPipelineController::GetClassName ( )
Reimplemented in vtkSMParaViewPipelineControllerWithRendering.
static int vtkSMParaViewPipelineController::IsTypeOf ( const char *  type)
virtual int vtkSMParaViewPipelineController::IsA ( const char *  type)
static vtkSMParaViewPipelineController* vtkSMParaViewPipelineController::SafeDownCast ( vtkObject *  o)
void vtkSMParaViewPipelineController::PrintSelf ( ostream &  os,
◆ InitializeSession()
virtual bool vtkSMParaViewPipelineController::InitializeSession ( vtkSMSession *  session)
Returns true on success.
◆ FindTimeKeeper()
virtual vtkSMProxy* vtkSMParaViewPipelineController::FindTimeKeeper ( vtkSMSession *  session)
◆ FindMaterialLibrary()
virtual vtkSMProxy* vtkSMParaViewPipelineController::FindMaterialLibrary ( vtkSMSession *  session)
◆ PreInitializeProxy()
virtual bool vtkSMParaViewPipelineController::PreInitializeProxy ( vtkSMProxy *  proxy)
prepares the proxy for initialization. One should call this before changing any properties on the proxy. We load the property values from XML defaults as well as user-preferences here.
◆ PostInitializeProxy()
virtual bool vtkSMParaViewPipelineController::PostInitializeProxy ( vtkSMProxy *  proxy)
When this method is called, all essential properties on the proxy (such as inputs for filters, or filename on readers) are assumed to be set up so that domains can be updated. This method setups up property values for those properties that weren't modified since the PreInitializeProxy() using the domains, if possible. This enables the application to select data-specific default values. NOTE: This method does not register the proxy with the proxy manager. It may, however register any helper proxies created for this proxy.
◆ InitializeProxy()
bool vtkSMParaViewPipelineController::InitializeProxy ( vtkSMProxy *  proxy)
inline
Definition at line 87 of file vtkSMParaViewPipelineController.h.
◆ FinalizeProxy()
virtual bool vtkSMParaViewPipelineController::FinalizeProxy ( vtkSMProxy *  proxy)
Similar to PreInitializeProxy/PostInitializeProxy methods, this doesn't affect the proxy manager registration state for the proxy itself.
◆ RegisterPipelineProxy() [1/2]
virtual bool vtkSMParaViewPipelineController::RegisterPipelineProxy ( vtkSMProxy *  proxy,
const char *  proxyname
This method does additional updates required for pipeline proxies such as registering the proxy with the TimeKeeper, creating additional helper proxies for enabling representation animations, and updating the active-source. This method will register the proxy in an appropriate group so that the application becomes aware of it. One can optionally pass in the registration name to use. Otherwise, this code will come up with a unique name. Caveat: while pipeline proxies are generally registered under the "sources" group, there's one exception: sources that produce vtkSelection. ParaView treats them specially and registers them under "selection_sources".
◆ RegisterPipelineProxy() [2/2]
virtual bool vtkSMParaViewPipelineController::RegisterPipelineProxy ( vtkSMProxy *  proxy)
inlinevirtual
Definition at line 117 of file vtkSMParaViewPipelineController.h.
◆ UnRegisterPipelineProxy()
virtual bool vtkSMParaViewPipelineController::UnRegisterPipelineProxy ( vtkSMProxy *  proxy)
This is the inverse of RegisterPipelineProxy() and hence unsets the active source if the active source if this proxy, unregisters the proxy with the TimeKeeper etc. Users can use either this method or the catch-all vtkSMParaViewPipelineController::UnRegisterProxy() method which determines the type of the proxy and then calls the appropriate method.
◆ RegisterViewProxy() [1/2]
virtual bool vtkSMParaViewPipelineController::RegisterViewProxy ( vtkSMProxy *  proxy)
inlinevirtual
This will also perform any additional setups as needed e.g. registering the view with the animation scene and the timer keeper.
Definition at line 141 of file vtkSMParaViewPipelineController.h.
◆ RegisterViewProxy() [2/2]
virtual bool vtkSMParaViewPipelineController::RegisterViewProxy ( vtkSMProxy *  proxy,
◆ UnRegisterViewProxy()
virtual bool vtkSMParaViewPipelineController::UnRegisterViewProxy ( vtkSMProxy *  proxy,
bool  unregister_representations = true
Users can use either this method or the catch-all vtkSMParaViewPipelineController::UnRegisterProxy() method which determines the type of the proxy and then calls the appropriate method. If the optional argument, unregister_representations, is false (default is true), then this method will skip the unregistering of representations. Default behaviour is to unregister all representations too.
◆ RegisterRepresentationProxy() [1/2]
virtual bool vtkSMParaViewPipelineController::RegisterRepresentationProxy ( vtkSMProxy *  proxy)
inlinevirtual
Register the proxy under the appropriate group.
Definition at line 164 of file vtkSMParaViewPipelineController.h.
◆ RegisterRepresentationProxy() [2/2]
virtual bool vtkSMParaViewPipelineController::RegisterRepresentationProxy ( vtkSMProxy *  proxy,
◆ UnRegisterRepresentationProxy()
virtual bool vtkSMParaViewPipelineController::UnRegisterRepresentationProxy ( vtkSMProxy *  proxy)
◆ RegisterColorTransferFunctionProxy() [1/2]
virtual bool vtkSMParaViewPipelineController::RegisterColorTransferFunctionProxy ( vtkSMProxy *  proxy,
◆ RegisterColorTransferFunctionProxy() [2/2]
virtual bool vtkSMParaViewPipelineController::RegisterColorTransferFunctionProxy ( vtkSMProxy *  proxy)
inlinevirtual
Definition at line 187 of file vtkSMParaViewPipelineController.h.
◆ RegisterOpacityTransferFunction() [1/2]
virtual bool vtkSMParaViewPipelineController::RegisterOpacityTransferFunction ( vtkSMProxy *  proxy,
◆ RegisterOpacityTransferFunction() [2/2]
virtual bool vtkSMParaViewPipelineController::RegisterOpacityTransferFunction ( vtkSMProxy *  proxy)
inlinevirtual
Definition at line 196 of file vtkSMParaViewPipelineController.h.
◆ RegisterTransferFunction2D() [1/2]
virtual bool vtkSMParaViewPipelineController::RegisterTransferFunction2D ( vtkSMProxy *  proxy,
◆ RegisterTransferFunction2D() [2/2]
virtual bool vtkSMParaViewPipelineController::RegisterTransferFunction2D ( vtkSMProxy *  proxy)
inlinevirtual
Definition at line 205 of file vtkSMParaViewPipelineController.h.
◆ RegisterLightProxy() [1/2]
virtual bool vtkSMParaViewPipelineController::RegisterLightProxy ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
This will also perform needed python tracing.
◆ RegisterLightProxy() [2/2]
vtkSMProxy *  view
inlinevirtual
Definition at line 216 of file vtkSMParaViewPipelineController.h.
◆ RegisterTextureProxy()
virtual bool vtkSMParaViewPipelineController::RegisterTextureProxy ( vtkSMProxy *  proxy,
const char *  filename
◆ RegisterExtractorProxy() [1/2]
virtual bool vtkSMParaViewPipelineController::RegisterExtractorProxy ( vtkSMProxy *  proxy,
◆ RegisterExtractorProxy() [2/2]
virtual bool vtkSMParaViewPipelineController::RegisterExtractorProxy ( vtkSMProxy *  proxy)
inlinevirtual
Definition at line 235 of file vtkSMParaViewPipelineController.h.
◆ FindAnimationScene()
virtual vtkSMProxy* vtkSMParaViewPipelineController::FindAnimationScene ( vtkSMSession *  session)
Returns nullptr if none exists.
◆ GetAnimationScene()
virtual vtkSMProxy* vtkSMParaViewPipelineController::GetAnimationScene ( vtkSMSession *  session)
If none exists, a new one will be created. This may returns nullptr if animation scene proxy is not available in the session.
◆ FindTimeAnimationTrack()
virtual vtkSMProxy* vtkSMParaViewPipelineController::FindTimeAnimationTrack ( vtkSMProxy *  scene)
◆ GetTimeAnimationTrack()
virtual vtkSMProxy* vtkSMParaViewPipelineController::GetTimeAnimationTrack ( vtkSMProxy *  scene)
If none exists, a new one will be created. Returns nullptr if the proxy is not available in the session.
◆ RegisterAnimationProxy()
virtual bool vtkSMParaViewPipelineController::RegisterAnimationProxy ( vtkSMProxy *  proxy)
◆ UnRegisterAnimationProxy()
virtual bool vtkSMParaViewPipelineController::UnRegisterAnimationProxy ( vtkSMProxy *  proxy)
Also unregisters cues if proxy is scene, keyframes if proxy is a cue, etc. Users can use either this method or the catch-all vtkSMParaViewPipelineController::UnRegisterProxy() method which determines the type of the proxy and then calls the appropriate method.
◆ UpdateSettingsProxies()
virtual void vtkSMParaViewPipelineController::UpdateSettingsProxies ( vtkSMSession *  session)
This may be called whenever a new settings proxy definition becomes available, say, after loading a plugin.
◆ UnRegisterProxy()
virtual bool vtkSMParaViewPipelineController::UnRegisterProxy ( vtkSMProxy *  proxy)
It determines what known types the "proxy" is, i.e. is it a view, or pipeline, or representation etc., and then calls the appropriate UnRegister...Proxy() method.
◆ GetHelperProxyGroupName()
static std::string vtkSMParaViewPipelineController::GetHelperProxyGroupName ( vtkSMProxy *  )
◆ FindProxy()
vtkSMProxy* vtkSMParaViewPipelineController::FindProxy ( vtkSMSessionProxyManager *  pxm,
const char *  reggroup,
const char *  xmlgroup,
const char *  xmltype
Returns the first proxy found, if any.
◆ CreateProxiesForProxyListDomains()
virtual bool vtkSMParaViewPipelineController::CreateProxiesForProxyListDomains ( vtkSMProxy *  proxy)
protectedvirtual
◆ RegisterProxiesForProxyListDomains()
virtual void vtkSMParaViewPipelineController::RegisterProxiesForProxyListDomains ( vtkSMProxy *  proxy)
protectedvirtual
◆ SetupGlobalPropertiesLinks()
virtual bool vtkSMParaViewPipelineController::SetupGlobalPropertiesLinks ( vtkSMProxy *  proxy)
protectedvirtual
◆ CreateAnimationHelpers()
virtual bool vtkSMParaViewPipelineController::CreateAnimationHelpers ( vtkSMProxy *  proxy)
protectedvirtual
◆ UnRegisterDependencies()
virtual bool vtkSMParaViewPipelineController::UnRegisterDependencies ( vtkSMProxy *  proxy)
protectedvirtual
◆ GetInitializationTime()
vtkMTimeType vtkSMParaViewPipelineController::GetInitializationTime ( vtkSMProxy *  )
Useful for subclasses to determine which properties were modified since initialization.
◆ ProcessInitializationHelper()
void vtkSMParaViewPipelineController::ProcessInitializationHelper ( vtkSMProxy *  ,
This method calls those initialization helpers, if any.
◆ ProcessInitializationHelperRegistration()
void vtkSMParaViewPipelineController::ProcessInitializationHelperRegistration ( vtkSMProxy *  )
This is called in RegisterProxy.
◆ PARAVIEW_DEPRECATED_IN_5_12_0()
vtkSMParaViewPipelineController::PARAVIEW_DEPRECATED_IN_5_12_0 ( "Material setup is now handled by the RenderView proxy on raytracing back-end update"  )
