vtkSMPlotMatrixViewProxy Class Reference
Proxy class for plot matrix view. More...
#include <vtkSMPlotMatrixViewProxy.h>
Inheritance diagram for vtkSMPlotMatrixViewProxy:
Collaboration diagram for vtkSMPlotMatrixViewProxy:
typedef vtkSMContextViewProxy Superclass
- Public Types inherited from vtkSMContextViewProxy
typedef vtkSMViewProxy Superclass
- Public Types inherited from vtkSMViewProxy
enum  { PrepareContextForRendering = vtkCommand::UserEvent + 1 }
typedef vtkSMProxy Superclass
vtkAbstractContextItem * GetContextItem () override
 Provides access to the vtk plot matrix. More...
- Public Member Functions inherited from vtkSMContextViewProxy
vtkContextView * GetContextView ()
 Provides access to the vtk chart view. More...
vtkRenderWindow * GetRenderWindow () override
 Return the render window from which offscreen rendering and interactor can be accessed. More...
void SetupInteractor (vtkRenderWindowInteractor *iren) override
 A client process need to set the interactor to enable interactivity. More...
vtkRenderWindowInteractor * GetInteractor () override
 Returns the interactor. More...
virtual void ResetDisplay ()
 Resets the zoom level to 100%. More...
bool CanDisplayData (vtkSMSourceProxy *producer, int outputPort) override
 Overridden to report to applications that producers producing non-table datasets are only viewable if they have the "Plottable" hint. More...
const char * GetRepresentationType (vtkSMSourceProxy *producer, int outputPort) override
 Overridden to create ChartTextRepresentation for text sources. More...
vtkSelection * GetCurrentSelection ()
- Public Member Functions inherited from vtkSMViewProxy
virtual void StillRender ()
 Renders the view using full resolution. More...
virtual void InteractiveRender ()
 Renders the view using lower resolution is possible. More...
virtual void Update ()
 Called vtkPVView::Update on the server-side. More...
virtual vtkSMRepresentationProxy * CreateDefaultRepresentation (vtkSMProxy *, int)
 Create a default representation for the given source proxy. More...
virtual vtkSMRepresentationProxy * FindRepresentation (vtkSMSourceProxy *producer, int outputPort)
 Finds the representation proxy showing the data produced by the provided producer, if any. More...
vtkView * GetClientSideView ()
 Returns the client-side vtkView, if any. More...
int WriteImage (const char *filename, const char *writerName, int magnification=1)
 Saves a screenshot of the view to disk. More...
int WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY)
virtual bool HasDirtyRepresentation ()
 Return true any internal representation is dirty. More...
virtual bool MakeRenderWindowInteractor (bool quiet=false)
 Creates a default render window interactor for the vtkRenderWindow and sets it up on the local process if the local process supports interaction. More...
virtual void SetEnable (bool)
 Enable/Disable a view. More...
virtual bool GetEnable ()
virtual void EnableOn ()
virtual void EnableOff ()
vtkImageData * CaptureWindow (int magnification)
 Captures a image from this view. More...
vtkImageData * CaptureWindow (int magnificationX, int magnificationY)
 Returns true if the subsequent call to Update() will result in an actual update. More...
virtual bool HideOtherRepresentationsIfNeeded (vtkSMProxy *repr)
 Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
virtual void RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility)
 Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMPlotMatrixViewProxy * New ()
static vtkSMPlotMatrixViewProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMContextViewProxy
static vtkSMContextViewProxy * New ()
static vtkSMContextViewProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMViewProxy
static vtkSMViewProxy * New ()
static vtkSMViewProxy * SafeDownCast (vtkObject *o)
static vtkSMViewProxy * FindView (vtkSMProxy *repr, const char *reggroup="views")
 Helper method to locate a view to which the representation has been added. More...
static void SetTransparentBackground (bool val)
 Sets whether screenshots have a transparent background. More...
static bool GetTransparentBackground ()
static bool HideOtherRepresentationsIfNeeded (vtkSMViewProxy *self, vtkSMProxy *repr)
static void RepresentationVisibilityChanged (vtkSMViewProxy *self, vtkSMProxy *repr, bool new_visibility)
static vtkSMProxy * New ()
static vtkSMObject * New ()
void ActivePlotChanged ()
void PostRender (bool) override
 vtkSMPlotMatrixViewProxy ()
 ~vtkSMPlotMatrixViewProxy () override
void SendAnimationPath ()
void AnimationTickEvent ()
- Protected Member Functions inherited from vtkSMContextViewProxy
 vtkSMContextViewProxy ()
 ~vtkSMContextViewProxy () override
void OnInteractionEvent ()
 Used to update the axis range properties on each interaction event. More...
void OnForwardInteractionEvent (vtkObject *, unsigned long, void *)
 Forwards vtkCommand::StartInteractionEvent and vtkCommand::EndInteractionEvent from the vtkRenderWindowInteractor. More...
void OnLeftButtonReleaseEvent ()
 Used to update the legend position on interaction event. More...
void PostRender (bool interactive) override
 Overridden to update ChartAxes ranges on every render. More...
 Overridden to process the "skip_plotable_check" attribute. More...
vtkTypeUInt32 PreRender (bool interactive) override
 Overridden to return a location of vtkPVSession::CLIENT unless in tile-display mode, in which case vtkPVSession::CLIENT | vtkPVSession::RENDER_SERVER is returned. More...
- Protected Member Functions inherited from vtkSMViewProxy
 vtkSMViewProxy ()
 ~vtkSMViewProxy () override
virtual vtkImageData * CaptureWindowInternal (int magnificationX, int magnificationY)
 Capture an image from the view's render window. More...
virtual void RenderForImageCapture ()
 This method is called whenever the view wants to render to during image capture. More...
virtual vtkTypeUInt32 PreRender (bool vtkNotUsed(interactive))
 This method is called before executing code that could cause a render on the underlying vtkPVView. More...
virtual void PostRender (bool vtkNotUsed(interactive))
virtual bool IsContextReadyForRendering ()
 Subclasses should override this method and return false if the rendering context is not ready for rendering at this moment. More...
 Called at the end of CreateVTKObjects(). More...
bool GetLocalProcessSupportsInteraction ()
 Convenience method to call vtkPVView::SafeDownCast(this->GetClientSideObject())->GetLocalProcessSupportsInteraction();. More...
virtual vtkSMDataDeliveryManagerProxy * GetDeliveryManager ()
 Provides access to the delivery manager proxy, if any. More...
virtual void SetDefaultRepresentationName (const char *)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool ActiveChanged
- Protected Attributes inherited from vtkSMContextViewProxy
vtkContextView * ChartView
 The context view that is used for all context derived charts. More...
bool SkipPlotableCheck
 To avoid showing large datasets in context views, that typically rely on delivering all data to the client side (or cloning it), by default make extra checks for data type and hints in CanDisplayData(). More...
bool XYChartViewBase4Axes
 Flag automatically set when Bottom and Right custom axes related property are present in this proxy. More...
- Protected Attributes inherited from vtkSMViewProxy
char * DefaultRepresentationName
bool Enable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Definition at line 17 of file vtkSMPlotMatrixViewProxy.h.
Definition at line 21 of file vtkSMPlotMatrixViewProxy.h.
◆ vtkSMPlotMatrixViewProxy()
vtkSMPlotMatrixViewProxy::vtkSMPlotMatrixViewProxy ( )
◆ ~vtkSMPlotMatrixViewProxy()
vtkSMPlotMatrixViewProxy::~vtkSMPlotMatrixViewProxy ( )
static vtkSMPlotMatrixViewProxy* vtkSMPlotMatrixViewProxy::New ( )
virtual const char* vtkSMPlotMatrixViewProxy::GetClassName ( )
Reimplemented from vtkSMContextViewProxy.
static int vtkSMPlotMatrixViewProxy::IsTypeOf ( const char *  type)
virtual int vtkSMPlotMatrixViewProxy::IsA ( const char *  type)
static vtkSMPlotMatrixViewProxy* vtkSMPlotMatrixViewProxy::SafeDownCast ( vtkObject *  o)
void vtkSMPlotMatrixViewProxy::PrintSelf ( ostream &  os,
◆ GetContextItem()
vtkAbstractContextItem* vtkSMPlotMatrixViewProxy::GetContextItem ( )
◆ CreateVTKObjects()
void vtkSMPlotMatrixViewProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
◆ ActivePlotChanged()
void vtkSMPlotMatrixViewProxy::ActivePlotChanged ( )
◆ PostRender()
void vtkSMPlotMatrixViewProxy::PostRender ( bool  )
◆ SendAnimationPath()
void vtkSMPlotMatrixViewProxy::SendAnimationPath ( )
◆ AnimationTickEvent()
void vtkSMPlotMatrixViewProxy::AnimationTickEvent ( )
◆ ActiveChanged
bool vtkSMPlotMatrixViewProxy::ActiveChanged
Definition at line 35 of file vtkSMPlotMatrixViewProxy.h.
