vtkSMAMRLevelsDomain Class Reference
int range domain based on the levels in AMR data. More...
#include <vtkSMAMRLevelsDomain.h>
Inheritance diagram for vtkSMAMRLevelsDomain:
Collaboration diagram for vtkSMAMRLevelsDomain:
typedef vtkSMIntRangeDomain Superclass
- Public Types inherited from vtkSMIntRangeDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *) override
 Update the domain using the "unchecked" values (if available) for all required properties. More...
- Public Member Functions inherited from vtkSMIntRangeDomain
virtual int GetMinimum (unsigned int idx, int &exists)
 Return a min. More...
virtual int GetMaximum (unsigned int idx, int &exists)
 Return a max. More...
virtual int GetMinimumExists (unsigned int idx)
 Returns if minimum/maximum bound is set for the domain. More...
virtual int GetMaximumExists (unsigned int idx)
virtual int GetMinimum (unsigned int idx)
 Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
virtual int GetMaximum (unsigned int idx)
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMAMRLevelsDomain * New ()
static vtkSMAMRLevelsDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMIntRangeDomain
static vtkSMIntRangeDomain * New ()
static vtkSMIntRangeDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMAMRLevelsDomain ()
 ~vtkSMAMRLevelsDomain () override
vtkPVDataInformation * GetInputInformation ()
- Protected Member Functions inherited from vtkSMIntRangeDomain
 vtkSMIntRangeDomain ()
 ~vtkSMIntRangeDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
virtual int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem)
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMAMRLevelsDomain is a subclass of vtkSMIntRangeDomain. It relies on one required property: "Input". "Input" is vtkSMInputProperty which provides the information about the data.
Supported Required-Property functions:
Definition at line 24 of file vtkSMAMRLevelsDomain.h.
Definition at line 28 of file vtkSMAMRLevelsDomain.h.
◆ vtkSMAMRLevelsDomain()
vtkSMAMRLevelsDomain::vtkSMAMRLevelsDomain ( )
◆ ~vtkSMAMRLevelsDomain()
vtkSMAMRLevelsDomain::~vtkSMAMRLevelsDomain ( )
static vtkSMAMRLevelsDomain* vtkSMAMRLevelsDomain::New ( )
virtual const char* vtkSMAMRLevelsDomain::GetClassName ( )
Reimplemented from vtkSMIntRangeDomain.
static int vtkSMAMRLevelsDomain::IsTypeOf ( const char *  type)
virtual int vtkSMAMRLevelsDomain::IsA ( const char *  type)
static vtkSMAMRLevelsDomain* vtkSMAMRLevelsDomain::SafeDownCast ( vtkObject *  o)
void vtkSMAMRLevelsDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMAMRLevelsDomain::Update ( vtkSMProperty *  )
◆ GetInputInformation()
vtkPVDataInformation* vtkSMAMRLevelsDomain::GetInputInformation ( )
