vtkSMFixedTypeDomain Class Reference
restricts the proxy to have the same type as previous proxy More...
#include <vtkSMFixedTypeDomain.h>
Inheritance diagram for vtkSMFixedTypeDomain:
Collaboration diagram for vtkSMFixedTypeDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
virtual int IsInDomain (vtkSMSourceProxy *oldProxy, vtkSMSourceProxy *newProxy)
 Returns true if old and new source proxies have the same output data type, false otherwise. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMFixedTypeDomain * New ()
static vtkSMFixedTypeDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMFixedTypeDomain ()
 ~vtkSMFixedTypeDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
virtual int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem)
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMFixedTypeDomain is used by input properties of filters that can not have different input types after input is set the first time. For example, a sub-class vtkDataSetToDataSetFilter, once connected in a pipeline can not change it's input type, say, from vtkImageData to vtkUnstructuredGrid because it's output can not change.
See also
vtkSMDomain
Definition at line 24 of file vtkSMFixedTypeDomain.h.
Definition at line 28 of file vtkSMFixedTypeDomain.h.
◆ vtkSMFixedTypeDomain()
vtkSMFixedTypeDomain::vtkSMFixedTypeDomain ( )
◆ ~vtkSMFixedTypeDomain()
vtkSMFixedTypeDomain::~vtkSMFixedTypeDomain ( )
static vtkSMFixedTypeDomain* vtkSMFixedTypeDomain::New ( )
virtual const char* vtkSMFixedTypeDomain::GetClassName ( )
static int vtkSMFixedTypeDomain::IsTypeOf ( const char *  type)
virtual int vtkSMFixedTypeDomain::IsA ( const char *  type)
static vtkSMFixedTypeDomain* vtkSMFixedTypeDomain::SafeDownCast ( vtkObject *  o)
void vtkSMFixedTypeDomain::PrintSelf ( ostream &  os,
◆ IsInDomain() [1/2]
int vtkSMFixedTypeDomain::IsInDomain ( vtkSMProperty *  property)
override
The property has to be a vtkSMProxyProperty which points to a vtkSMSourceProxy. If the new (unchecked) source proxy has the same number of parts and data types as the old (checked) one, it returns 1. Returns 0 otherwise.
◆ IsInDomain() [2/2]
virtual int vtkSMFixedTypeDomain::IsInDomain ( vtkSMSourceProxy *  oldProxy,
vtkSMSourceProxy *  newProxy
