vtkSMDiscreteDoubleDomain Class Reference
set of double More...
#include <vtkSMDiscreteDoubleDomain.h>
Inheritance diagram for vtkSMDiscreteDoubleDomain:
Collaboration diagram for vtkSMDiscreteDoubleDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
std::vector< double > GetValues ()
 Returns the vector of values. More...
bool GetValuesExists ()
 Returns if Values is non empty. More...
void Update (vtkSMProperty *property) override
 Updates this from the property. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMDiscreteDoubleDomain * New ()
static vtkSMDiscreteDoubleDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMDiscreteDoubleDomain ()
 ~vtkSMDiscreteDoubleDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
 Reads the "values" property, with a maximum of 256 values. More...
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
std::vector< double > Values
 A vector of allowed values for the domain. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
set of double
vtkSMDiscreteDoubleDomain represents a set of double values. It supports a maximum of 256 values.
Values are specified in xml as follow:
<DiscreteDoubleDomain values='val1 val2 ... valX' />
Definition at line 26 of file vtkSMDiscreteDoubleDomain.h.
Definition at line 30 of file vtkSMDiscreteDoubleDomain.h.
◆ vtkSMDiscreteDoubleDomain()
vtkSMDiscreteDoubleDomain::vtkSMDiscreteDoubleDomain ( )
◆ ~vtkSMDiscreteDoubleDomain()
vtkSMDiscreteDoubleDomain::~vtkSMDiscreteDoubleDomain ( )
static vtkSMDiscreteDoubleDomain* vtkSMDiscreteDoubleDomain::New ( )
virtual const char* vtkSMDiscreteDoubleDomain::GetClassName ( )
static int vtkSMDiscreteDoubleDomain::IsTypeOf ( const char *  type)
virtual int vtkSMDiscreteDoubleDomain::IsA ( const char *  type)
static vtkSMDiscreteDoubleDomain* vtkSMDiscreteDoubleDomain::SafeDownCast ( vtkObject *  o)
void vtkSMDiscreteDoubleDomain::PrintSelf ( ostream &  os,
◆ IsInDomain()
int vtkSMDiscreteDoubleDomain::IsInDomain ( vtkSMProperty *  property)
override
The property has to be a vtkSMDoubleVectorProperty. If the vector value is in the domain, it returns 1. It returns 0 otherwise.
◆ GetValues()
std::vector<double> vtkSMDiscreteDoubleDomain::GetValues ( )
◆ GetValuesExists()
bool vtkSMDiscreteDoubleDomain::GetValuesExists ( )
◆ Update()
void vtkSMDiscreteDoubleDomain::Update ( vtkSMProperty *  property)
◆ ReadXMLAttributes()
int vtkSMDiscreteDoubleDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ Values
std::vector<double> vtkSMDiscreteDoubleDomain::Values
Definition at line 68 of file vtkSMDiscreteDoubleDomain.h.
