vtkSMDataTypeDomain Class Reference
restricts the input proxies to one or more data types More...
#include <vtkSMDataTypeDomain.h>
Inheritance diagram for vtkSMDataTypeDomain:
Collaboration diagram for vtkSMDataTypeDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (vtkSMSourceProxy *proxy, int outputport=0)
 Returns true if all parts of the source proxy are in the domain. More...
std::string GetDomainDescription () const
 An experimental API to provide a user-friendly text describing this domain. More...
int ParseXMLAttributes (vtkPVXMLElement *element)
 Parse XML attributes and store in the appropriate ivars Used by ReadXMLAttributes but can be used independently. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMDataTypeDomain * New ()
static vtkSMDataTypeDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMDataTypeDomain ()
 ~vtkSMDataTypeDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMDataTypeDomain restricts the input proxies to one or more data types. These data types are specified in the XML with the <DataType> element. VTK class names are used. It is possible to specify a superclass (i.e. vtkDataSet) for a more general domain. Works with vtkSMSourceProxy only. Valid XML elements are:
* * <DataType value=""> where value is the classname for the data type
* for example: vtkDataSet, vtkImageData,...
Optional XML attributes for composite datasets only:
See also
vtkSMDomain vtkSMSourceProxy
Definition at line 51 of file vtkSMDataTypeDomain.h.
Definition at line 55 of file vtkSMDataTypeDomain.h.
◆ vtkSMDataTypeDomain()
vtkSMDataTypeDomain::vtkSMDataTypeDomain ( )
◆ ~vtkSMDataTypeDomain()
vtkSMDataTypeDomain::~vtkSMDataTypeDomain ( )
static vtkSMDataTypeDomain* vtkSMDataTypeDomain::New ( )
virtual const char* vtkSMDataTypeDomain::GetClassName ( )
static int vtkSMDataTypeDomain::IsTypeOf ( const char *  type)
virtual int vtkSMDataTypeDomain::IsA ( const char *  type)
static vtkSMDataTypeDomain* vtkSMDataTypeDomain::SafeDownCast ( vtkObject *  o)
void vtkSMDataTypeDomain::PrintSelf ( ostream &  os,
◆ IsInDomain() [1/2]
int vtkSMDataTypeDomain::IsInDomain ( vtkSMProperty *  property)
override
The property has to be a vtkSMProxyProperty which points to a vtkSMSourceProxy. If all data types of the input's parts are in the domain, it returns. It returns 0 otherwise.
◆ IsInDomain() [2/2]
int vtkSMDataTypeDomain::IsInDomain ( vtkSMSourceProxy *  proxy,
int  outputport = 0
◆ GetDomainDescription()
std::string vtkSMDataTypeDomain::GetDomainDescription ( ) const
◆ ParseXMLAttributes()
int vtkSMDataTypeDomain::ParseXMLAttributes ( vtkPVXMLElement *  element)
◆ ReadXMLAttributes()
int vtkSMDataTypeDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
overrideprotectedvirtual
value
value
