Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkSMComparativeAnimationCueProxy Class Reference
cue used for parameter animation by the comparative view. More...
#include <vtkSMComparativeAnimationCueProxy.h>
Inheritance diagram for vtkSMComparativeAnimationCueProxy:
Collaboration diagram for vtkSMComparativeAnimationCueProxy:
typedef vtkSMProxy Superclass
vtkPVXMLElement * SaveXMLState (vtkPVXMLElement *root) override
vtkPVXMLElement * SaveXMLState (vtkPVXMLElement *root, vtkSMPropertyIterator *iter) override
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
void UpdateXRange (int y, double minx, double maxx)
 Methods simply forwarded to vtkPVComparativeAnimationCue. More...
void UpdateYRange (int x, double miny, double maxy)
void UpdateWholeRange (double mint, double maxt)
void UpdateValue (int x, int y, double value)
void UpdateXRange (int y, double *minx, double *maxx, unsigned int numvalues)
void UpdateYRange (int x, double *minx, double *maxx, unsigned int numvalues)
void UpdateWholeRange (double *mint, double *maxt, unsigned int numValues)
void UpdateWholeRange (double *mint, double *maxt, unsigned int numValues, bool vertical_first)
void UpdateValue (int x, int y, double *value, unsigned int numValues)
double * GetValues (int x, int y, int dx, int dy, unsigned int &numValues)
double GetValue (int x, int y, int dx, int dy)
void UpdateAnimatedValue (int x, int y, int dx, int dy)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMComparativeAnimationCueProxy * New ()
static vtkSMComparativeAnimationCueProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMComparativeAnimationCueProxy ()
 ~vtkSMComparativeAnimationCueProxy () override
vtkPVComparativeAnimationCue * GetComparativeAnimationCue ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
Friends
class vtkSMComparativeAnimationCueUndoElement
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMComparativeAnimationCueProxy is a animation cue used for parameter animation by the vtkSMComparativeViewProxy. It provides a non-conventional API i.e. without using properties to allow the user to setup parameter values over the comparative grid.
Definition at line 22 of file vtkSMComparativeAnimationCueProxy.h.
Definition at line 26 of file vtkSMComparativeAnimationCueProxy.h.
◆ vtkSMComparativeAnimationCueProxy()
vtkSMComparativeAnimationCueProxy::vtkSMComparativeAnimationCueProxy ( )
◆ ~vtkSMComparativeAnimationCueProxy()
vtkSMComparativeAnimationCueProxy::~vtkSMComparativeAnimationCueProxy ( )
static vtkSMComparativeAnimationCueProxy* vtkSMComparativeAnimationCueProxy::New ( )
virtual const char* vtkSMComparativeAnimationCueProxy::GetClassName ( )
static int vtkSMComparativeAnimationCueProxy::IsTypeOf ( const char *  type)
virtual int vtkSMComparativeAnimationCueProxy::IsA ( const char *  type)
static vtkSMComparativeAnimationCueProxy* vtkSMComparativeAnimationCueProxy::SafeDownCast ( vtkObject *  o)
void vtkSMComparativeAnimationCueProxy::PrintSelf ( ostream &  os,
◆ UpdateXRange() [1/2]
void vtkSMComparativeAnimationCueProxy::UpdateXRange ( int  y,
double  minx,
double  maxx
Any of these methods changing the state of the proxy, also call this->MarkModified(this).
◆ UpdateYRange() [1/2]
void vtkSMComparativeAnimationCueProxy::UpdateYRange ( int  x,
double  miny,
double  maxy
◆ UpdateWholeRange() [1/3]
void vtkSMComparativeAnimationCueProxy::UpdateWholeRange ( double  mint,
double  maxt
◆ UpdateValue() [1/2]
void vtkSMComparativeAnimationCueProxy::UpdateValue ( int  x,
int  y,
double  value
◆ UpdateXRange() [2/2]
double *  minx,
double *  maxx,
◆ UpdateYRange() [2/2]
double *  minx,
double *  maxx,
◆ UpdateWholeRange() [2/3]
void vtkSMComparativeAnimationCueProxy::UpdateWholeRange ( double *  mint,
double *  maxt,
◆ UpdateWholeRange() [3/3]
double *  maxt,
bool  vertical_first
◆ UpdateValue() [2/2]
int  y,
double *  value,
◆ GetValues()
double* vtkSMComparativeAnimationCueProxy::GetValues ( int  x,
int  y,
int  dx,
int  dy,
unsigned int &  numValues
◆ GetValue()
double vtkSMComparativeAnimationCueProxy::GetValue ( int  x,
int  y,
int  dx,
int  dy
◆ UpdateAnimatedValue()
void vtkSMComparativeAnimationCueProxy::UpdateAnimatedValue ( int  x,
int  y,
int  dx,
int  dy
◆ SaveXMLState() [1/2]
vtkPVXMLElement* vtkSMComparativeAnimationCueProxy::SaveXMLState ( vtkPVXMLElement *  root)
inlineoverridevirtual
Saves the state of the proxy.
This state can be reloaded to create a new proxy that is identical the present state of this proxy. The resulting proxy's XML hieratchy is returned, in addition if the root argument is not nullptr then it's also inserted as a nested element. This call saves all a proxy's properties, including exposed properties and sub-proxies. More control is provided by the following overload.
Definition at line 57 of file vtkSMComparativeAnimationCueProxy.h.
◆ SaveXMLState() [2/2]
vtkPVXMLElement* vtkSMComparativeAnimationCueProxy::SaveXMLState ( vtkPVXMLElement *  root,
vtkSMPropertyIterator *  iter
The iterator is use to filter the property available on the given proxy.
◆ LoadXMLState()
int vtkSMComparativeAnimationCueProxy::LoadXMLState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  locator
Loads the proxy state from the XML element.
Returns 0 on failure. locator is used to locate other proxies that may be referred to in the state XML (which happens in case of properties of type vtkSMProxyProperty or subclasses). If locator is nullptr, then such properties are left unchanged.
◆ CreateVTKObjects()
void vtkSMComparativeAnimationCueProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
◆ GetComparativeAnimationCue()
vtkPVComparativeAnimationCue* vtkSMComparativeAnimationCueProxy::GetComparativeAnimationCue ( )
◆ vtkSMComparativeAnimationCueUndoElement
Definition at line 88 of file vtkSMComparativeAnimationCueProxy.h.
