UndoElement for ComparativeAnimationCue. More...
#include <vtkSMComparativeAnimationCueUndoElement.h>
| typedef vtkSMUndoElement | Superclass |
Public Types inherited from vtkSMUndoElement | |
| typedef vtkUndoElement | Superclass |
Public Types inherited from vtkUndoElement | |
| int | Undo () override |
| Undo the operation encapsulated by this element. More... | |
| int | Redo () override |
| Redo the operation encaspsulated by this element. More... | |
| void | SetXMLStates (vtkTypeUInt32 id, vtkPVXMLElement *before, vtkPVXMLElement *after) |
Public Member Functions inherited from vtkSMUndoElement | |
Public Member Functions inherited from vtkUndoElement | |
| virtual bool | Merge (vtkUndoElement *vtkNotUsed(new_element)) |
Called on the older element in the UndoSet to merge with the element being added if both the elements are mergeable. More... | |
| virtual void | SetUndoSetWorkingContext (vtkCollection *workCTX) |
| virtual bool | GetMergeable () |
| Returns if this undo element can be merged with other undo elements. More... | |
| static vtkSMComparativeAnimationCueUndoElement * | New () |
| static vtkSMComparativeAnimationCueUndoElement * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMUndoElement | |
| static vtkSMUndoElement * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkUndoElement | |
| static vtkUndoElement * | SafeDownCast (vtkObject *o) |
| vtkSMComparativeAnimationCueUndoElement () | |
| ~vtkSMComparativeAnimationCueUndoElement () override | |
Protected Member Functions inherited from vtkSMUndoElement | |
| vtkSMUndoElement () | |
| ~vtkSMUndoElement () override | |
Protected Member Functions inherited from vtkUndoElement | |
| vtkUndoElement () | |
| ~vtkUndoElement () override | |
| virtual void | SetMergeable (bool) |
| Subclasses must set this flag to enable merging of consecutive elements in an UndoSet. More... | |
Protected Attributes | |
| vtkSmartPointer< vtkPVXMLElement > | BeforeState |
| vtkSmartPointer< vtkPVXMLElement > | AfterState |
| vtkTypeUInt32 | ComparativeAnimationCueID |
Protected Attributes inherited from vtkSMUndoElement | |
Protected Attributes inherited from vtkUndoElement | |
| bool | Mergeable |
| vtkCollection * | UndoSetWorkingContext |
Definition at line 19 of file vtkSMComparativeAnimationCueUndoElement.h.
Definition at line 23 of file vtkSMComparativeAnimationCueUndoElement.h.
Reimplemented from vtkSMUndoElement.
Implements vtkUndoElement.
| void vtkSMComparativeAnimationCueUndoElement::SetXMLStates | ( | vtkTypeUInt32 | id, |
| vtkPVXMLElement * | before, | ||
| vtkPVXMLElement * | after | ||
Definition at line 35 of file vtkSMComparativeAnimationCueUndoElement.h.
Definition at line 36 of file vtkSMComparativeAnimationCueUndoElement.h.
Definition at line 37 of file vtkSMComparativeAnimationCueUndoElement.h.
