vtkSMChartUseIndexForAxisDomain Class Reference
extends vtkSMBooleanDomain to pick a good default for properties such as "UseIndexForXAxis" on chart representations. More...
#include <vtkSMChartUseIndexForAxisDomain.h>
Inheritance diagram for vtkSMChartUseIndexForAxisDomain:
Collaboration diagram for vtkSMChartUseIndexForAxisDomain:
typedef vtkSMBooleanDomain Superclass
- Public Types inherited from vtkSMBooleanDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 Set the default values for the property. More...
void Update (vtkSMProperty *requestingProperty) override
 Overridden to fire DomainModified when the required property changes. More...
- Public Member Functions inherited from vtkSMBooleanDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the property is a vtkSMIntVectorProperty. More...
void SetAnimationValue (vtkSMProperty *property, int idx, double value) override
 Set the value of an element of a property from the animation editor. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMChartUseIndexForAxisDomain * New ()
static vtkSMChartUseIndexForAxisDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMBooleanDomain
static vtkSMBooleanDomain * New ()
static vtkSMBooleanDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMChartUseIndexForAxisDomain ()
 ~vtkSMChartUseIndexForAxisDomain () override
- Protected Member Functions inherited from vtkSMBooleanDomain
 vtkSMBooleanDomain ()
 ~vtkSMBooleanDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
virtual int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem)
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMChartUseIndexForAxisDomain extends vtkSMBooleanDomain to add logic to pick an appropriate default e.g. UseIndexForXAxis for bar and line charts needs to be set to 0 by default, if the XArrayName contains one of the known arrays such as "bin_extents", "arc_length", and set to 1 otherwise. This class encapsulates that logic.
Supported Required-Property functions:
Definition at line 26 of file vtkSMChartUseIndexForAxisDomain.h.
Definition at line 30 of file vtkSMChartUseIndexForAxisDomain.h.
◆ vtkSMChartUseIndexForAxisDomain()
vtkSMChartUseIndexForAxisDomain::vtkSMChartUseIndexForAxisDomain ( )
◆ ~vtkSMChartUseIndexForAxisDomain()
vtkSMChartUseIndexForAxisDomain::~vtkSMChartUseIndexForAxisDomain ( )
static vtkSMChartUseIndexForAxisDomain* vtkSMChartUseIndexForAxisDomain::New ( )
virtual const char* vtkSMChartUseIndexForAxisDomain::GetClassName ( )
Reimplemented from vtkSMBooleanDomain.
static int vtkSMChartUseIndexForAxisDomain::IsTypeOf ( const char *  type)
virtual int vtkSMChartUseIndexForAxisDomain::IsA ( const char *  type)
static vtkSMChartUseIndexForAxisDomain* vtkSMChartUseIndexForAxisDomain::SafeDownCast ( vtkObject *  o)
void vtkSMChartUseIndexForAxisDomain::PrintSelf ( ostream &  os,
◆ SetDefaultValues()
int vtkSMChartUseIndexForAxisDomain::SetDefaultValues ( vtkSMProperty *  ,
override
Overridden to handle the default value for "UseIndexForXAxis" property, if any. UseIndexForXAxis needs to be OFF by default, if the required property e.g. XArrayName property has one of the known types of arrays, otherwise it must be ON.
◆ Update()
void vtkSMChartUseIndexForAxisDomain::Update ( vtkSMProperty *  requestingProperty)
This ensures that SetDefaultValues() is called during proxy post-initialization after the required property has been reset to default.
