vtkSIPythonSourceProxy Class Reference
vtkSISourceProxy for all VTKPythonAlgorithmBase-based algorithms. More...
#include <vtkSIPythonSourceProxy.h>
Inheritance diagram for vtkSIPythonSourceProxy:
Collaboration diagram for vtkSIPythonSourceProxy:
typedef vtkSISourceProxy Superclass
- Public Types inherited from vtkSISourceProxy
typedef vtkSIProxy Superclass
- Public Types inherited from vtkSIProxy
typedef vtkSIObject Superclass
- Public Types inherited from vtkSIObject
void Push (vtkSMMessage *) override
 Push a new state to the underneath implementation. More...
void Pull (vtkSMMessage *) override
 Pull the current state of the underneath implementation. More...
void RecreateVTKObjects () override
 Overridden to update the output ports. More...
void Initialize (vtkPVSessionCore *session) override
 Initializes the instance. More...
- Public Member Functions inherited from vtkSISourceProxy
virtual vtkAlgorithmOutput * GetOutputPort (int port)
 Returns the vtkAlgorithmOutput for an output port, if valid. More...
void UpdatePipelineInformation () override
 Triggers UpdateInformation() on vtkObject if possible. More...
virtual void UpdatePipeline (int port, double time, bool doTime)
 Triggers UpdatePipeline(). More...
virtual void SetupSelectionProxy (int port, vtkSIProxy *extractSelection)
 setups extract selection proxies. More...
virtual void SetDisablePipelineExecution (bool value)
 Allow to shut down pipeline execution. More...
- Public Member Functions inherited from vtkSIProxy
void AboutToDelete () override
 This method is called before the deletion of the SIObject. More...
vtkSIProperty * GetSIProperty (const char *name)
 Provides access to the property helper. More...
bool IsNullProxy ()
 Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More...
virtual bool ExtendDefinition (const char *xml)
 Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More...
vtkObjectBase * GetVTKObject ()
 Returns access to the VTKObject pointer, if any. More...
void SetVTKObject (vtkObjectBase *)
 Returns the VTKClassName. More...
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual void AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method)
 These methods are called to add/remove input connections by vtkSIInputProperty. More...
virtual void CleanInputs (const char *method)
- Public Member Functions inherited from vtkSIObject
vtkClientServerInterpreter * GetInterpreter ()
 Provides access to the Interpreter. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid) const
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkObject subclass given its global id. More...
virtual void SetGlobalID (vtkTypeUInt32)
 Get/Set the global id for this object. More...
static vtkSIPythonSourceProxy * New ()
static vtkSIPythonSourceProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSISourceProxy
static vtkSISourceProxy * New ()
static vtkSISourceProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProxy
static vtkSIProxy * New ()
static vtkSIProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIObject
static vtkSIObject * New ()
static vtkSIObject * SafeDownCast (vtkObject *o)
 vtkSIPythonSourceProxy ()
 ~vtkSIPythonSourceProxy () override
vtkObjectBase * NewVTKObject (const char *className) override
 Overridden to use the Python interpreter to instantiate Python classes. More...
void DeleteVTKObjects () override
 Overridden to release any Python objects created. More...
- Protected Member Functions inherited from vtkSISourceProxy
 vtkSISourceProxy ()
 ~vtkSISourceProxy () override
bool CreateVTKObjects () override
 Overridden to setup the output ports and pipelines for the output ports. More...
bool ReadXMLAttributes (vtkPVXMLElement *element) override
 Read xml-attributes. More...
void OnCreateVTKObjects () override
 Called after CreateVTKObjects(). More...
virtual bool CreateOutputPorts ()
 Create the output ports and add post filters for each output port. More...
virtual void SetExecutiveName (const char *)
void MarkStartEvent ()
 Callbacks to add start/end events to the timer log. More...
void MarkEndEvent ()
- Protected Member Functions inherited from vtkSIProxy
 vtkSIProxy ()
 ~vtkSIProxy () override
vtkSIProxy * GetSubSIProxy (const char *name)
 Returns the subproxy helper for the subproxy with the given name, if any. More...
vtkSIProxyDefinitionManager * GetProxyDefinitionManager ()
 Provides access to the vtkSIProxyDefinitionManager held by the session. More...
bool InitializeAndCreateVTKObjects (vtkSMMessage *message)
 Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More...
void AddSIProperty (const char *name, vtkSIProperty *)
 Adds a vtkSMProperty's server-implementation. More...
virtual void SetPostPush (const char *)
virtual void SetPostCreation (const char *)
virtual char * GetLogName ()
unsigned int GetNumberOfSubSIProxys ()
 API to iterate over subproxy helpers. More...
vtkSIProxy * GetSubSIProxy (unsigned int cc)
virtual bool ReadXMLProperty (vtkPVXMLElement *property_element)
 Parses the XML to create property/subproxy helpers. More...
virtual bool ReadXMLSubProxy (vtkPVXMLElement *subproxy_element)
- Protected Member Functions inherited from vtkSIObject
 vtkSIObject ()
 ~vtkSIObject () override
- Protected Attributes inherited from vtkSISourceProxy
char * ExecutiveName
bool DisablePipelineExecution
- Protected Attributes inherited from vtkSIProxy
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLSubProxyName
char * PostPush
char * PostCreation
int NumberOfInputPorts
vtkSmartPointer< vtkObjectBase > VTKObject
bool ObjectsCreated
- Protected Attributes inherited from vtkSIObject
vtkWeakPointer< vtkClientServerInterpreter > Interpreter
vtkWeakPointer< vtkPVSessionCore > SessionCore
vtkSMMessage * LastPushedMessage
vtkTypeUInt32 GlobalID
vtkSIPythonSourceProxy makes is possible to work with a VTKPythonAlgorithmBase-based Python class in ParaView. By handling the push/pull APIs to forward the calls to the Python object, we can make such Python algorithms behave like regular C++-based algorithm subclasses.
Definition at line 23 of file vtkSIPythonSourceProxy.h.
Definition at line 27 of file vtkSIPythonSourceProxy.h.
◆ vtkSIPythonSourceProxy()
vtkSIPythonSourceProxy::vtkSIPythonSourceProxy ( )
◆ ~vtkSIPythonSourceProxy()
vtkSIPythonSourceProxy::~vtkSIPythonSourceProxy ( )
static vtkSIPythonSourceProxy* vtkSIPythonSourceProxy::New ( )
virtual const char* vtkSIPythonSourceProxy::GetClassName ( )
Reimplemented from vtkSISourceProxy.
static int vtkSIPythonSourceProxy::IsTypeOf ( const char *  type)
virtual int vtkSIPythonSourceProxy::IsA ( const char *  type)
static vtkSIPythonSourceProxy* vtkSIPythonSourceProxy::SafeDownCast ( vtkObject *  o)
void vtkSIPythonSourceProxy::PrintSelf ( ostream &  os,
◆ Push()
void vtkSIPythonSourceProxy::Push ( vtkSMMessage *  msg)
Reimplemented from vtkSIProxy.
◆ Pull()
void vtkSIPythonSourceProxy::Pull ( vtkSMMessage *  msg)
◆ RecreateVTKObjects()
void vtkSIPythonSourceProxy::RecreateVTKObjects ( )
◆ Initialize()
void vtkSIPythonSourceProxy::Initialize ( vtkPVSessionCore *  session)
Session is the session to which this instance belongs to. During initialization, the SIObject basically obtains ivars for necessary components.
Reimplemented from vtkSIObject.
◆ NewVTKObject()
vtkObjectBase* vtkSIPythonSourceProxy::NewVTKObject ( const char *  className)
overrideprotectedvirtual
◆ DeleteVTKObjects()
void vtkSIPythonSourceProxy::DeleteVTKObjects ( )
