vtkPVSessionServer Class Reference
#include <vtkPVSessionServer.h>
Inheritance diagram for vtkPVSessionServer:
Collaboration diagram for vtkPVSessionServer:
enum  {
  PUSH = 12, PULL = 13, EXECUTE_STREAM = 14, GATHER_INFORMATION = 15,
  REGISTER_SI = 16, UNREGISTER_SI = 17, LAST_RESULT = 18, SERVER_NOTIFICATION_MESSAGE_RMI = 55624,
  CLIENT_SERVER_MESSAGE_RMI = 55625, CLOSE_SESSION = 55626, REPLY_GATHER_INFORMATION_TAG = 55627, REPLY_PULL = 55628,
  REPLY_LAST_RESULT = 55629, EXECUTE_STREAM_TAG = 55630
 Client-Server Communication tags. More...
typedef vtkPVSessionBase Superclass
- Public Types inherited from vtkPVSessionBase
enum  EventIds { RegisterRemoteObjectEvent = 1234, UnRegisterRemoteObjectEvent = 4321, ProcessingRemoteEnd = 2143, ConnectionLost = 6789 }
typedef vtkPVSession Superclass
enum  ServerFlags {
  NONE = 0, DATA_SERVER = 0x01, DATA_SERVER_ROOT = 0x02, RENDER_SERVER = 0x04,
  RENDER_SERVER_ROOT = 0x08, SERVERS = DATA_SERVER | RENDER_SERVER, CLIENT = 0x10, CLIENT_AND_SERVERS = DATA_SERVER | CLIENT | RENDER_SERVER
typedef vtkSession Superclass
- Public Types inherited from vtkSession
vtkMultiProcessController * GetController (ServerFlags processType) override
 Returns the active controller used to communicate with the process. More...
virtual bool Connect (const char *url)
 Connects a remote server. More...
bool Connect ()
 Overload that constructs the url using the command line parameters specified and then calls Connect(url). More...
bool GetIsAlive () override
 Returns true is this session is active/alive/valid. More...
void OnClientServerMessageRMI (void *message, int message_length)
void OnCloseSessionRMI ()
void NotifyAllClients (const vtkSMMessage *) override
 Sends the message to all clients. More...
void NotifyOtherClients (const vtkSMMessage *) override
 Sends the message to all but the active client-session. More...
virtual void MultipleConnectionOn ()
 Enable or Disable multi-connection support. More...
virtual void MultipleConnectionOff ()
virtual void SetMultipleConnection (bool)
virtual bool GetMultipleConnection ()
virtual void DisableFurtherConnectionsOn ()
 Enable or Disable further connections in multiple connection mode. More...
virtual void DisableFurtherConnectionsOff ()
virtual bool GetDisableFurtherConnections ()
void SetDisableFurtherConnections (bool disable)
void SetConnectID (int newConnectID)
 Set/Get the server connect-id. More...
int GetConnectID ()
- Public Member Functions inherited from vtkPVSessionBase
ServerFlags GetProcessRoles () override
 Returns a ServerFlags indicate the nature of the current processes. More...
vtkPVServerInformation * GetServerInformation () override
 vtkPVServerInformation is an information-object that provides information about the server processes. More...
vtkMPIMToNSocketConnection * GetMPIMToNSocketConnection () override
 This is socket connection, if any to communicate between the data-server and render-server nodes. More...
virtual void PushState (vtkSMMessage *msg)
 Push the state message. More...
virtual void PullState (vtkSMMessage *msg)
 Pull the state message. More...
virtual void ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false)
 Execute a command on the given processes. More...
 Returns the response of the ExecuteStream() call from the location. More...
virtual bool GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid)
 Gather information about an object referred by the globalid. More...
vtkSIProxyDefinitionManager * GetProxyDefinitionManager ()
 Get the ProxyDefinitionManager. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Returns a vtkSIObject or subclass given its global id, if any. More...
virtual void UnRegisterSIObject (vtkSMMessage *msg)
 Unregister server side object. More...
virtual void RegisterSIObject (vtkSMMessage *msg)
 Register server side object. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Return a vtkSMRemoteObject given its global id if any otherwise return nullptr;. More...
virtual void GetAllRemoteObjects (vtkCollection *collection)
 Allow the user to fill its vtkCollection with all RemoteObject This could be useful when you want to hold a reference to them to prevent any deletion across several method call. More...
virtual vtkTypeUInt32 GetNextGlobalUniqueIdentifier ()
 Provides the next available identifier. More...
virtual vtkTypeUInt32 GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize)
 Return the first Id of the requested chunk. More...
virtual bool IsProcessingRemoteNotification ()
 This property is used to discard ignore_synchronization proxy property when we load protobuf states. More...
virtual void UseSessionCoreOf (vtkPVSessionBase *other)
 Update internal session core in order to use the one used in another session. More...
virtual vtkPVSessionCore * GetSessionCore ()
 Provides access to the session core. More...
bool HasProcessRole (vtkTypeUInt32 flag)
 Convenience method that returns true if the current session is serving the indicated role on this process. More...
virtual bool IsMultiClients ()
 Allow anyone to know easily if the current session is involved in collaboration or not. More...
bool GetPendingProgress ()
 Returns true if the session is within a PrepareProgress() and CleanupPendingProgress() block. More...
virtual vtkPVProgressHandler * GetProgressHandler ()
 Provides access to the progress handler. More...
void PrepareProgress ()
 Should be called to begin/end receiving progresses on this session. More...
void CleanupPendingProgress ()
static vtkPVSessionServer * New ()
static vtkPVSessionServer * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVSessionBase
static vtkPVSessionBase * SafeDownCast (vtkObject *o)
static vtkPVSession * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSession
static vtkSession * SafeDownCast (vtkObject *o)
 vtkPVSessionServer ()
 ~vtkPVSessionServer () override
void GatherInformationInternal (vtkTypeUInt32 location, const char *classname, vtkTypeUInt32 globalid, vtkMultiProcessStream &)
 Called when client triggers GatherInformation(). More...
void SendLastResultToClient ()
 Sends the last result to client. More...
- Protected Member Functions inherited from vtkPVSessionBase
 vtkPVSessionBase ()
 vtkPVSessionBase (vtkPVSessionCore *coreToUse)
 ~vtkPVSessionBase () override
void RegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location, vtkObject *obj)
 Register a remote object. More...
void UnRegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location)
 Unregister a remote object. More...
vtkPVSessionCore * GetSessionCore () const
 Method used to migrate from one Session type to another by keeping the same vtkPVSessionCore. More...
void SetSessionCore (vtkPVSessionCore *)
void PrepareProgressInternal () override
void CleanupPendingProgressInternal () override
virtual bool StartProcessingRemoteNotification ()
 Methods used to monitor if we are currently processing a server notification Only vtkSMSessionClient use the flag to disable ignore_synchronization properties from being updated. More...
virtual void StopProcessingRemoteNotification (bool previousValue)
 vtkPVSession ()
 ~vtkPVSession () override
virtual bool OnWrongTagEvent (vtkObject *caller, unsigned long eventid, void *calldata)
 Callback when any vtkMultiProcessController subclass fires a WrongTagEvent. More...
- Protected Member Functions inherited from vtkSession
 vtkSession ()
 ~vtkSession () override
virtual void Activate ()
 Subclasses must call this to mark the session active. More...
virtual void DeActivate ()
 Subclasses must call this to mark the session inactive. More...
vtkMPIMToNSocketConnection * MPIMToNSocketConnection
bool MultipleConnection
bool DisableFurtherConnections
vtkInternals * Internal
- Protected Attributes inherited from vtkPVSessionBase
vtkPVSessionCore * SessionCore
bool ProcessingRemoteNotification
vtkPVProgressHandler * ProgressHandler
Friends
class vtkInternals
- Protected Types inherited from vtkPVSession
enum  { EXCEPTION_EVENT_TAG = 31416 }
vtkSMSessionServer is a session used on data and/or render servers. It's designed for a process that works with a separate client process that acts as the visualization driver.
See also
vtkSMSessionClient
Definition at line 22 of file vtkPVSessionServer.h.
Definition at line 26 of file vtkPVSessionServer.h.
◆ anonymous enum
anonymous enum
Enumerator
PUSH
PULL
EXECUTE_STREAM
GATHER_INFORMATION
REGISTER_SI
UNREGISTER_SI
LAST_RESULT
CLOSE_SESSION
REPLY_PULL
REPLY_LAST_RESULT
EXECUTE_STREAM_TAG
Definition at line 65 of file vtkPVSessionServer.h.
◆ vtkPVSessionServer()
vtkPVSessionServer::vtkPVSessionServer ( )
◆ ~vtkPVSessionServer()
vtkPVSessionServer::~vtkPVSessionServer ( )
static vtkPVSessionServer* vtkPVSessionServer::New ( )
virtual const char* vtkPVSessionServer::GetClassName ( )
Reimplemented from vtkPVSessionBase.
static int vtkPVSessionServer::IsTypeOf ( const char *  type)
virtual int vtkPVSessionServer::IsA ( const char *  type)
static vtkPVSessionServer* vtkPVSessionServer::SafeDownCast ( vtkObject *  o)
void vtkPVSessionServer::PrintSelf ( ostream &  os,
◆ GetController()
vtkMultiProcessController* vtkPVSessionServer::GetController ( ServerFlags  processType)
Value must be DATA_SERVER_ROOT or RENDER_SERVER_ROOT or CLIENT. But only the CLIENT do return something different than nullptr;
Reimplemented from vtkPVSession.
◆ Connect() [1/2]
virtual bool vtkPVSessionServer::Connect ( const char *  url)
URL can be of the following format: cs://<pvserver-host>:<pvserver-port> cdsrs://<pvdataserver-host>:<pvdataserver-port>/<pvrenderserver-host>:<pvrenderserver-port> In both cases the port is optional. When not provided default pvserver/pvdataserver port // is 11111, while default pvrenderserver port is 22221. For reverse connect i.e. the client waits for the server to connect back, simply add "rc" to the protocol e.g. csrc://<pvserver-host>:<pvserver-port> cdsrsrc://<pvdataserver-host>:<pvdataserver-port>/<pvrenderserver-host>:<pvrenderserver-port> In this case, the hostname is irrelevant and is ignored.
◆ Connect() [2/2]
bool vtkPVSessionServer::Connect ( )
◆ GetIsAlive()
bool vtkPVSessionServer::GetIsAlive ( )
Implements vtkSession.
◆ MultipleConnectionOn()
virtual void vtkPVSessionServer::MultipleConnectionOn ( )
The MultipleConnection is only used inside the DATA_SERVER to support several clients to connect to it. By default, collaboration is not allowed (this->MultipleConnection = false)
◆ MultipleConnectionOff()
virtual void vtkPVSessionServer::MultipleConnectionOff ( )
◆ SetMultipleConnection()
virtual void vtkPVSessionServer::SetMultipleConnection ( bool  )
◆ GetMultipleConnection()
virtual bool vtkPVSessionServer::GetMultipleConnection ( )
◆ DisableFurtherConnectionsOn()
virtual void vtkPVSessionServer::DisableFurtherConnectionsOn ( )
By default, further connections are enabled. (this->DisableFurtherConnections = false)
◆ DisableFurtherConnectionsOff()
virtual void vtkPVSessionServer::DisableFurtherConnectionsOff ( )
◆ GetDisableFurtherConnections()
virtual bool vtkPVSessionServer::GetDisableFurtherConnections ( )
◆ SetDisableFurtherConnections()
void vtkPVSessionServer::SetDisableFurtherConnections ( bool  disable)
◆ SetConnectID()
void vtkPVSessionServer::SetConnectID ( int  newConnectID)
Default is 0.
◆ GetConnectID()
int vtkPVSessionServer::GetConnectID ( )
Default is 0.
◆ OnClientServerMessageRMI()
void vtkPVSessionServer::OnClientServerMessageRMI ( void *  message,
int  message_length
◆ OnCloseSessionRMI()
void vtkPVSessionServer::OnCloseSessionRMI ( )
◆ NotifyAllClients()
void vtkPVSessionServer::NotifyAllClients ( const vtkSMMessage *  )
Implements vtkPVSessionBase.
◆ NotifyOtherClients()
void vtkPVSessionServer::NotifyOtherClients ( const vtkSMMessage *  )
◆ GatherInformationInternal()
void vtkPVSessionServer::GatherInformationInternal ( vtkTypeUInt32  location,
const char *  classname,
◆ SendLastResultToClient()
void vtkPVSessionServer::SendLastResultToClient ( )
◆ vtkInternals
friend class vtkInternals
friend
Definition at line 149 of file vtkPVSessionServer.h.
◆ MPIMToNSocketConnection
vtkMPIMToNSocketConnection* vtkPVSessionServer::MPIMToNSocketConnection
Definition at line 142 of file vtkPVSessionServer.h.
bool vtkPVSessionServer::MultipleConnection
Definition at line 144 of file vtkPVSessionServer.h.
bool vtkPVSessionServer::DisableFurtherConnections
Definition at line 145 of file vtkPVSessionServer.h.
◆ Internal
vtkInternals* vtkPVSessionServer::Internal
Definition at line 147 of file vtkPVSessionServer.h.
