vtkPVCatalystSessionCore Class Reference
#include <vtkPVCatalystSessionCore.h>
Inheritance diagram for vtkPVCatalystSessionCore:
Collaboration diagram for vtkPVCatalystSessionCore:
typedef vtkPVSessionCore Superclass
- Public Types inherited from vtkPVSessionCore
enum  MessageTypes {
  PUSH_STATE = 12, PULL_STATE = 13, EXECUTE_STREAM = 14, GATHER_INFORMATION = 15,
  REGISTER_SI = 16, UNREGISTER_SI = 17
bool GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid) override
 Gather information about an object referred by the globalid. More...
vtkTypeUInt32 RegisterDataInformation (vtkTypeUInt32 globalid, unsigned int port, vtkPVInformation *information)
 Update the data information for a given proxy with the given globalid. More...
void UpdateIdMap (vtkTypeUInt32 *idMapArray, int size)
void ResetIdMap ()
- Public Member Functions inherited from vtkPVSessionCore
virtual void PushState (vtkSMMessage *message)
 Push the state message. More...
virtual void PullState (vtkSMMessage *message)
 Pull the state message from the local SI object instances. More...
virtual void ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false)
 Execute a command on the given processes. More...
 Returns the response of the ExecuteStream() call from the location. More...
virtual void UnRegisterSIObject (vtkSMMessage *message)
 Notify that the given SIObject is not used anymore . More...
virtual void RegisterSIObject (vtkSMMessage *message)
 Notify that the given SIObject is used. More...
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Returns a vtkSIObject or subclass given its global id, if any otherwise return nullptr;. More...
vtkObject * GetRemoteObject (vtkTypeUInt32 globalid)
 Return a vtkObject given its global id if any otherwise return nullptr;. More...
void RegisterRemoteObject (vtkTypeUInt32 globalid, vtkObject *obj)
 Register a remote object. More...
void UnRegisterRemoteObject (vtkTypeUInt32 globalid)
 Unregister a remote object. More...
int GetNumberOfProcesses ()
 Returns the number of processes. More...
virtual vtkTypeUInt32 GetNextGlobalUniqueIdentifier ()
 Provides the next available identifier. More...
virtual vtkTypeUInt32 GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize)
 Return the first Id of the requested chunk. More...
void PushStateSatelliteCallback ()
void ExecuteStreamSatelliteCallback ()
void GatherInformationStatelliteCallback ()
void RegisterSIObjectSatelliteCallback ()
void UnRegisterSIObjectSatelliteCallback ()
virtual void GetAllRemoteObjects (vtkCollection *collection)
 Allow the user to fill a vtkCollection with all RemoteObjects This is useful when you want to hold a reference to them to prevent any deletion across several method call. More...
void GarbageCollectSIObject (int *clientIds, int nbClients)
 Delete SIObject that are held by clients that disappeared from the given list. More...
virtual vtkClientServerInterpreter * GetInterpreter ()
 Provides access to the interpreter. More...
virtual vtkSIProxyDefinitionManager * GetProxyDefinitionManager ()
 Provides access to the proxy definition manager. More...
void SetMPIMToNSocketConnection (vtkMPIMToNSocketConnection *)
 Get/Set the socket connection used to communicate between data=server and render-server processes. More...
virtual vtkMPIMToNSocketConnection * GetMPIMToNSocketConnection ()
static vtkPVCatalystSessionCore * New ()
static vtkPVCatalystSessionCore * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVSessionCore
static vtkPVSessionCore * New ()
static vtkPVSessionCore * SafeDownCast (vtkObject *o)
 vtkPVCatalystSessionCore ()
 ~vtkPVCatalystSessionCore () override
- Protected Member Functions inherited from vtkPVSessionCore
 vtkPVSessionCore ()
 ~vtkPVSessionCore () override
virtual void PushStateInternal (vtkSMMessage *)
 This will create a vtkSIObject and/or execute some update on the vtkObject that it own. More...
virtual void ExecuteStreamInternal (const vtkClientServerStream &stream, bool ignore_errors)
 This will execute localy the given vtkClientServerStream either by calling method on the vtkSIObject or its internal vtkObject. More...
bool GatherInformationInternal (vtkPVInformation *information, vtkTypeUInt32 globalid)
 This will gather information on the local vtkObjects through the local vtkSIObjects. More...
bool CollectInformation (vtkPVInformation *)
 Gather information across MPI satellites. More...
virtual void RegisterSIObjectInternal (vtkSMMessage *message)
 Increment reference count of a local vtkSIObject. More...
virtual void UnRegisterSIObjectInternal (vtkSMMessage *message)
 Decrement reference count of a local vtkSIObject. More...
void OnInterpreterError (vtkObject *, unsigned long, void *calldata)
 Callback for reporting interpreter errors. More...
- Protected Types inherited from vtkPVSessionCore
enum  { ROOT_SATELLITE_RMI_TAG = 887822, ROOT_SATELLITE_INFO_TAG = 887823 }
- Protected Attributes inherited from vtkPVSessionCore
vtkSIProxyDefinitionManager * ProxyDefinitionManager
vtkWeakPointer< vtkMultiProcessController > ParallelController
vtkClientServerInterpreter * Interpreter
vtkMPIMToNSocketConnection * MPIMToNSocketConnection
vtkPVCatalystSessionCore is used by vtkSMSession. vtkPVCatalystSessionCore handle catalyst based proxy which don't contains any real data and therefore are not allowed to execute the VTK pipeline.
Definition at line 22 of file vtkPVCatalystSessionCore.h.
Definition at line 26 of file vtkPVCatalystSessionCore.h.
◆ vtkPVCatalystSessionCore()
vtkPVCatalystSessionCore::vtkPVCatalystSessionCore ( )
◆ ~vtkPVCatalystSessionCore()
vtkPVCatalystSessionCore::~vtkPVCatalystSessionCore ( )
static vtkPVCatalystSessionCore* vtkPVCatalystSessionCore::New ( )
virtual const char* vtkPVCatalystSessionCore::GetClassName ( )
Reimplemented from vtkPVSessionCore.
static int vtkPVCatalystSessionCore::IsTypeOf ( const char *  type)
virtual int vtkPVCatalystSessionCore::IsA ( const char *  type)
static vtkPVCatalystSessionCore* vtkPVCatalystSessionCore::SafeDownCast ( vtkObject *  o)
void vtkPVCatalystSessionCore::PrintSelf ( ostream &  os,
◆ GatherInformation()
bool vtkPVCatalystSessionCore::GatherInformation ( vtkTypeUInt32  location,
vtkPVInformation *  information,
location identifies the processes to gather the information from.
◆ RegisterDataInformation()
vtkTypeUInt32 vtkPVCatalystSessionCore::RegisterDataInformation ( vtkTypeUInt32  globalid,
unsigned int  port,
This will allow the GatherInformation to work with "fake" VTK pipeline. Return the real corresponding proxy id
◆ UpdateIdMap()
void vtkPVCatalystSessionCore::UpdateIdMap ( vtkTypeUInt32 *  idMapArray,
int  size
◆ ResetIdMap()
void vtkPVCatalystSessionCore::ResetIdMap ( )
