vtkPVSynchronizedRenderer Class Reference
coordinates rendering between corresponding renderers across multiple processes More...
#include <vtkPVSynchronizedRenderer.h>
Inheritance diagram for vtkPVSynchronizedRenderer:
Collaboration diagram for vtkPVSynchronizedRenderer:
void Initialize (vtkPVSession *session)
 Must be called once to initialize the instance. More...
void SetOrderedCompositingHelper (vtkOrderedCompositingHelper *helper)
 Used to determine sorting order and use ordered compositing. More...
void SetRenderer (vtkRenderer *)
 Set the renderer that is being synchronized. More...
void SetUseDepthBuffer (bool)
 Activates or de-activated the use of Depth Buffer in an ImageProcessingPass. More...
void SetRenderEmptyImages (bool)
 Enable/Disable empty images optimization. More...
void SetNVPipeSupport (bool)
 Enable/Disable NVPipe. More...
virtual void SetDisableIceT (bool)
 Set this flag to true before calling Initialize() to disable using vtkIceTSynchronizedRenderers for parallel rendering. More...
virtual bool GetDisableIceT ()
virtual void SetEnabled (bool enabled)
 Enable/Disable parallel rendering. More...
virtual bool GetEnabled ()
virtual void EnabledOn ()
virtual void EnabledOff ()
void SetImageReductionFactor (int)
 Get/Set the image reduction factor. More...
virtual int GetImageReductionFactor ()
void SetDataReplicatedOnAllProcesses (bool)
 Set to true if data is replicated on all processes. More...
virtual bool GetDataReplicatedOnAllProcesses ()
virtual void DataReplicatedOnAllProcessesOn ()
virtual void DataReplicatedOnAllProcessesOff ()
void SetImageProcessingPass (vtkImageProcessingPass *)
 Get/Set an image processing pass to process the rendered images. More...
virtual vtkImageProcessingPass * GetImageProcessingPass ()
void SetRenderPass (vtkRenderPass *)
 Get/Set geometry rendering pass. More...
virtual vtkRenderPass * GetRenderPass ()
void ConfigureCompressor (const char *configuration)
 Passes the compressor configuration to the client-server synchronizer, if any. More...
void SetLossLessCompression (bool)
void SetEnableRayTracing (bool val)
 State flags to turn on specialized treatment for ray tracing. More...
virtual bool GetEnableRayTracing ()
void SetEnablePathTracing (bool val)
virtual bool GetEnablePathTracing ()
virtual vtkSynchronizedRenderers * GetParallelSynchronizer ()
 Not for the faint hearted. More...
virtual vtkSynchronizedRenderers * GetCSSynchronizer ()
virtual void SetUseFXAA (bool use)
 Enable/disable FXAA antialiasing. More...
virtual bool GetUseFXAA ()
virtual vtkFXAAOptions * GetFXAAOptions ()
 Set/Get FXAA options. More...
virtual void SetFXAAOptions (vtkFXAAOptions *)
static vtkPVSynchronizedRenderer * New ()
static vtkPVSynchronizedRenderer * SafeDownCast (vtkObject *o)
 vtkPVSynchronizedRenderer ()
 ~vtkPVSynchronizedRenderer () override
virtual void SetupPasses ()
 Sets up the render passes on the renderer. More...
vtkSynchronizedRenderers * CSSynchronizer
vtkSynchronizedRenderers * ParallelSynchronizer
vtkImageProcessingPass * ImageProcessingPass
vtkRenderPass * RenderPass
bool Enabled
bool DisableIceT
int ImageReductionFactor
vtkOpenGLRenderer * Renderer
bool UseDepthBuffer
bool RenderEmptyImages
bool DataReplicatedOnAllProcesses
bool EnableRayTracing
bool EnablePathTracing
bool UseFXAA = false
vtkFXAAOptions * FXAAOptions = nullptr
vtkPVSynchronizedRenderer coordinates rendering between renderers that are split across multiple ranks. It internally uses other vtkSynchronizedRenderers subclasses based on the operation mode to do the actual coordination such as vtkCaveSynchronizedRenderers, vtkIceTSynchronizedRenderers, vtkPVClientServerSynchronizedRenderers and vtkCompositedSynchronizedRenderers.
Definition at line 33 of file vtkPVSynchronizedRenderer.h.
Definition at line 37 of file vtkPVSynchronizedRenderer.h.
◆ vtkPVSynchronizedRenderer()
vtkPVSynchronizedRenderer::vtkPVSynchronizedRenderer ( )
◆ ~vtkPVSynchronizedRenderer()
vtkPVSynchronizedRenderer::~vtkPVSynchronizedRenderer ( )
static vtkPVSynchronizedRenderer* vtkPVSynchronizedRenderer::New ( )
virtual const char* vtkPVSynchronizedRenderer::GetClassName ( )
static int vtkPVSynchronizedRenderer::IsTypeOf ( const char *  type)
virtual int vtkPVSynchronizedRenderer::IsA ( const char *  type)
static vtkPVSynchronizedRenderer* vtkPVSynchronizedRenderer::SafeDownCast ( vtkObject *  o)
void vtkPVSynchronizedRenderer::PrintSelf ( ostream &  os,
◆ SetDisableIceT()
virtual void vtkPVSynchronizedRenderer::SetDisableIceT ( bool  )
Default value is setup using vtkPVRenderViewSettings::GetDisableIceT.
◆ GetDisableIceT()
virtual bool vtkPVSynchronizedRenderer::GetDisableIceT ( )
◆ Initialize()
void vtkPVSynchronizedRenderer::Initialize ( vtkPVSession *  session)
This will create appropriate internal vtkSynchronizedRenderers subclasses based on the process type and session provided.
◆ SetOrderedCompositingHelper()
void vtkPVSynchronizedRenderer::SetOrderedCompositingHelper ( vtkOrderedCompositingHelper *  helper)
Set to nullptr to not use ordered compositing and instead use depth-buffer based compositing, if applicable.
◆ SetRenderer()
void vtkPVSynchronizedRenderer::SetRenderer ( vtkRenderer *  )
◆ SetEnabled()
virtual void vtkPVSynchronizedRenderer::SetEnabled ( bool  enabled)
◆ GetEnabled()
virtual bool vtkPVSynchronizedRenderer::GetEnabled ( )
◆ EnabledOn()
virtual void vtkPVSynchronizedRenderer::EnabledOn ( )
◆ EnabledOff()
virtual void vtkPVSynchronizedRenderer::EnabledOff ( )
◆ SetImageReductionFactor()
void vtkPVSynchronizedRenderer::SetImageReductionFactor ( int  )
This needs to be set on all processes and must match up.
◆ GetImageReductionFactor()
virtual int vtkPVSynchronizedRenderer::GetImageReductionFactor ( )
◆ SetDataReplicatedOnAllProcesses()
void vtkPVSynchronizedRenderer::SetDataReplicatedOnAllProcesses ( bool  )
This will enable IceT to minimize communications since data is available on all process. Off by default.
◆ GetDataReplicatedOnAllProcesses()
virtual bool vtkPVSynchronizedRenderer::GetDataReplicatedOnAllProcesses ( )
◆ DataReplicatedOnAllProcessesOn()
virtual void vtkPVSynchronizedRenderer::DataReplicatedOnAllProcessesOn ( )
◆ DataReplicatedOnAllProcessesOff()
virtual void vtkPVSynchronizedRenderer::DataReplicatedOnAllProcessesOff ( )
◆ SetImageProcessingPass()
void vtkPVSynchronizedRenderer::SetImageProcessingPass ( vtkImageProcessingPass *  )
◆ GetImageProcessingPass()
virtual vtkImageProcessingPass* vtkPVSynchronizedRenderer::GetImageProcessingPass ( )
◆ SetRenderPass()
void vtkPVSynchronizedRenderer::SetRenderPass ( vtkRenderPass *  )
This pass is used to render the geometry. If none specified then default rendering pipeline is used. This is typically the render-pass pipeline after the CameraPass. The CameraPass is setup by ParaView specially since ParaView needs some customizations for multiviews/icet etc.
◆ GetRenderPass()
virtual vtkRenderPass* vtkPVSynchronizedRenderer::GetRenderPass ( )
◆ ConfigureCompressor()
void vtkPVSynchronizedRenderer::ConfigureCompressor ( const char *  configuration)
This affects the image compression used to relay images back to the client. See vtkPVClientServerSynchronizedRenderers::ConfigureCompressor() for details.
◆ SetLossLessCompression()
void vtkPVSynchronizedRenderer::SetLossLessCompression ( bool  )
◆ SetUseDepthBuffer()
void vtkPVSynchronizedRenderer::SetUseDepthBuffer ( bool  )
◆ SetRenderEmptyImages()
void vtkPVSynchronizedRenderer::SetRenderEmptyImages ( bool  )
◆ SetNVPipeSupport()
void vtkPVSynchronizedRenderer::SetNVPipeSupport ( bool  )
◆ SetEnableRayTracing()
void vtkPVSynchronizedRenderer::SetEnableRayTracing ( bool  val)
◆ GetEnableRayTracing()
virtual bool vtkPVSynchronizedRenderer::GetEnableRayTracing ( )
◆ SetEnablePathTracing()
void vtkPVSynchronizedRenderer::SetEnablePathTracing ( bool  val)
◆ GetEnablePathTracing()
virtual bool vtkPVSynchronizedRenderer::GetEnablePathTracing ( )
◆ GetParallelSynchronizer()
virtual vtkSynchronizedRenderers* vtkPVSynchronizedRenderer::GetParallelSynchronizer ( )
This internal vtkSynchronizedRenderers instances are exposed for advanced users that want to do advanced tricks with rendering. These will change without notice. Do not use them unless you know what you are doing. ParallelSynchronizer is the vtkSynchronizedRenderers used to synchronize rendering between processes in an MPI group – typically vtkIceTSynchronizedRenderers when available. CSSynchronizer is the client-server vtkSynchronizedRenderers used in client-server configurations.
◆ GetCSSynchronizer()
virtual vtkSynchronizedRenderers* vtkPVSynchronizedRenderer::GetCSSynchronizer ( )
◆ SetUseFXAA()
virtual void vtkPVSynchronizedRenderer::SetUseFXAA ( bool  use)
◆ GetUseFXAA()
virtual bool vtkPVSynchronizedRenderer::GetUseFXAA ( )
◆ GetFXAAOptions()
virtual vtkFXAAOptions* vtkPVSynchronizedRenderer::GetFXAAOptions ( )
◆ SetFXAAOptions()
virtual void vtkPVSynchronizedRenderer::SetFXAAOptions ( vtkFXAAOptions *  )
◆ SetupPasses()
virtual void vtkPVSynchronizedRenderer::SetupPasses ( )
protectedvirtual
This won't get called on processes where vtkIceTSynchronizedRenderers is used. In that case the passes are forwarded to the vtkIceTSynchronizedRenderers instance.
◆ CSSynchronizer
vtkSynchronizedRenderers* vtkPVSynchronizedRenderer::CSSynchronizer
Definition at line 198 of file vtkPVSynchronizedRenderer.h.
◆ ParallelSynchronizer
vtkSynchronizedRenderers* vtkPVSynchronizedRenderer::ParallelSynchronizer
Definition at line 199 of file vtkPVSynchronizedRenderer.h.
◆ ImageProcessingPass
vtkImageProcessingPass* vtkPVSynchronizedRenderer::ImageProcessingPass
Definition at line 200 of file vtkPVSynchronizedRenderer.h.
◆ RenderPass
vtkRenderPass* vtkPVSynchronizedRenderer::RenderPass
Definition at line 201 of file vtkPVSynchronizedRenderer.h.
◆ Enabled
bool vtkPVSynchronizedRenderer::Enabled
Definition at line 203 of file vtkPVSynchronizedRenderer.h.
◆ DisableIceT
bool vtkPVSynchronizedRenderer::DisableIceT
Definition at line 204 of file vtkPVSynchronizedRenderer.h.
◆ ImageReductionFactor
int vtkPVSynchronizedRenderer::ImageReductionFactor
Definition at line 205 of file vtkPVSynchronizedRenderer.h.
◆ Renderer
vtkOpenGLRenderer* vtkPVSynchronizedRenderer::Renderer
Definition at line 206 of file vtkPVSynchronizedRenderer.h.
◆ UseDepthBuffer
bool vtkPVSynchronizedRenderer::UseDepthBuffer
Definition at line 208 of file vtkPVSynchronizedRenderer.h.
◆ RenderEmptyImages
bool vtkPVSynchronizedRenderer::RenderEmptyImages
Definition at line 209 of file vtkPVSynchronizedRenderer.h.
bool vtkPVSynchronizedRenderer::DataReplicatedOnAllProcesses
Definition at line 210 of file vtkPVSynchronizedRenderer.h.
◆ EnableRayTracing
bool vtkPVSynchronizedRenderer::EnableRayTracing
Definition at line 212 of file vtkPVSynchronizedRenderer.h.
◆ EnablePathTracing
bool vtkPVSynchronizedRenderer::EnablePathTracing
Definition at line 213 of file vtkPVSynchronizedRenderer.h.
◆ UseFXAA
bool vtkPVSynchronizedRenderer::UseFXAA = false
Definition at line 215 of file vtkPVSynchronizedRenderer.h.
◆ FXAAOptions
vtkFXAAOptions* vtkPVSynchronizedRenderer::FXAAOptions = nullptr
Definition at line 216 of file vtkPVSynchronizedRenderer.h.
