vtkPVRenderViewSettings Class Reference
singleton used to keep track of options for vtkPVRenderView. More...
#include <vtkPVRenderViewSettings.h>
Inheritance diagram for vtkPVRenderViewSettings:
Collaboration diagram for vtkPVRenderViewSettings:
enum  { DO_NOTHING = 0, OFFSET_FACES = 1, OFFSET_LINES_AND_VERTS = 2, ZSHIFT = 3 }
enum  { AUTOMATIC = 0, ALWAYS_2D = 1, ALWAYS_3D = 2 }
void SetResolveCoincidentTopology (int mode)
 vtkMapper settings. More...
void SetPolygonOffsetParameters (double factor, double units)
void SetLineOffsetParameters (double factor, double units)
void SetPointOffsetParameter (double units)
void SetZShift (double a)
virtual void SetOutlineThreshold (vtkIdType)
 Set the number of cells (in millions) when the representations show try to use outline by default. More...
virtual vtkIdType GetOutlineThreshold ()
virtual void SetTwoSidedLighting (bool)
 When rendering a volume, this option simulates light coming from both its direction and its opposite for all lights in the scene. More...
virtual bool GetTwoSidedLighting ()
virtual void SetDefaultInteractionMode (int)
 Set the default interaction mode. More...
virtual int GetDefaultInteractionMode ()
virtual void SetPointPickingRadius (int)
 Set the radius in pixels to include for finding the closet point when selecting a point on render view. More...
virtual int GetPointPickingRadius ()
virtual void SetDisableIceT (bool)
 EXPERIMENTAL: Add ability to disable IceT. More...
virtual bool GetDisableIceT ()
virtual void SetEnableFastPreselection (bool)
 Enable fast preselection. More...
virtual bool GetEnableFastPreselection ()
virtual void SetGrowSelectionRemoveSeed (bool)
 When enabled and growing selection, remove the initial selection seed. More...
virtual bool GetGrowSelectionRemoveSeed ()
virtual void SetGrowSelectionRemoveIntermediateLayers (bool)
 When enabled and growing selection, remove the intermediate layers. More...
virtual bool GetGrowSelectionRemoveIntermediateLayers ()
virtual void SetBackgroundColor (double, double, double)
 Used by vtkPVRenderView and other views to determine background color. More...
virtual void SetBackgroundColor (double[3])
virtual double * GetBackgroundColor ()
virtual void GetBackgroundColor (double &, double &, double &)
virtual void GetBackgroundColor (double[3])
virtual void SetBackground2Color (double, double, double)
virtual void SetBackground2Color (double[3])
virtual double * GetBackground2Color ()
virtual void GetBackground2Color (double &, double &, double &)
virtual void GetBackground2Color (double[3])
virtual void SetBackgroundColorMode (int)
virtual int GetBackgroundColorMode ()
virtual void SetZoomClosestOffsetRatio (double)
 OffsetRatio is used to add a zoom offset when using Reset Camera Closest and Zoom Closest To Data. More...
virtual double GetZoomClosestOffsetRatio ()
static vtkPVRenderViewSettings * New ()
static vtkPVRenderViewSettings * SafeDownCast (vtkObject *o)
static vtkPVRenderViewSettings * GetInstance ()
 Access the singleton. More...
 vtkPVRenderViewSettings ()
 ~vtkPVRenderViewSettings () override
int DefaultInteractionMode
vtkIdType OutlineThreshold
bool TwoSidedLighting = true
int PointPickingRadius
bool DisableIceT
bool EnableFastPreselection
bool GrowSelectionRemoveSeed = false
bool GrowSelectionRemoveIntermediateLayers = false
double BackgroundColor [3]
double Background2Color [3]
int BackgroundColorMode
double ZoomClosestOffsetRatio
vtkPVRenderViewSettings is a singleton used to keep track of selections for various configurable parameters used by vtkPVRenderView. All class to vtkPVRenderViewSettings::New() returns a reference to the singleton instance.
Definition at line 21 of file vtkPVRenderViewSettings.h.
Definition at line 25 of file vtkPVRenderViewSettings.h.
◆ anonymous enum
anonymous enum
Enumerator
DO_NOTHING
OFFSET_FACES
ZSHIFT
Definition at line 33 of file vtkPVRenderViewSettings.h.
◆ anonymous enum
anonymous enum
Enumerator
AUTOMATIC
ALWAYS_2D
ALWAYS_3D
Definition at line 70 of file vtkPVRenderViewSettings.h.
◆ vtkPVRenderViewSettings()
vtkPVRenderViewSettings::vtkPVRenderViewSettings ( )
◆ ~vtkPVRenderViewSettings()
vtkPVRenderViewSettings::~vtkPVRenderViewSettings ( )
static vtkPVRenderViewSettings* vtkPVRenderViewSettings::New ( )
virtual const char* vtkPVRenderViewSettings::GetClassName ( )
static int vtkPVRenderViewSettings::IsTypeOf ( const char *  type)
virtual int vtkPVRenderViewSettings::IsA ( const char *  type)
static vtkPVRenderViewSettings* vtkPVRenderViewSettings::SafeDownCast ( vtkObject *  o)
void vtkPVRenderViewSettings::PrintSelf ( ostream &  os,
◆ GetInstance()
static vtkPVRenderViewSettings* vtkPVRenderViewSettings::GetInstance ( )
◆ SetResolveCoincidentTopology()
void vtkPVRenderViewSettings::SetResolveCoincidentTopology ( int  mode)
vtkMapper settings.
◆ SetPolygonOffsetParameters()
void vtkPVRenderViewSettings::SetPolygonOffsetParameters ( double  factor,
double  units
vtkMapper settings.
◆ SetLineOffsetParameters()
void vtkPVRenderViewSettings::SetLineOffsetParameters ( double  factor,
double  units
vtkMapper settings.
◆ SetPointOffsetParameter()
void vtkPVRenderViewSettings::SetPointOffsetParameter ( double  units)
vtkMapper settings.
◆ SetZShift()
void vtkPVRenderViewSettings::SetZShift ( double  a)
vtkMapper settings.
◆ SetOutlineThreshold()
virtual void vtkPVRenderViewSettings::SetOutlineThreshold ( vtkIdType  )
◆ GetOutlineThreshold()
virtual vtkIdType vtkPVRenderViewSettings::GetOutlineThreshold ( )
◆ SetTwoSidedLighting()
virtual void vtkPVRenderViewSettings::SetTwoSidedLighting ( bool  )
It is enabled by default.
◆ GetTwoSidedLighting()
virtual bool vtkPVRenderViewSettings::GetTwoSidedLighting ( )
◆ SetDefaultInteractionMode()
virtual void vtkPVRenderViewSettings::SetDefaultInteractionMode ( int  )
◆ GetDefaultInteractionMode()
virtual int vtkPVRenderViewSettings::GetDefaultInteractionMode ( )
◆ SetPointPickingRadius()
virtual void vtkPVRenderViewSettings::SetPointPickingRadius ( int  )
This only after single point selections i.e. when selecting a regions this radius is not respected.
◆ GetPointPickingRadius()
virtual int vtkPVRenderViewSettings::GetPointPickingRadius ( )
◆ SetDisableIceT()
virtual void vtkPVRenderViewSettings::SetDisableIceT ( bool  )
◆ GetDisableIceT()
virtual bool vtkPVRenderViewSettings::GetDisableIceT ( )
◆ SetEnableFastPreselection()
virtual void vtkPVRenderViewSettings::SetEnableFastPreselection ( bool  )
When enabled, the preselection is computed using the visible geometry. This avoids a call to the extract selection filter each time the mouse moves, improving a lot the preselection highlight display, especially for big datasets.
◆ GetEnableFastPreselection()
virtual bool vtkPVRenderViewSettings::GetEnableFastPreselection ( )
◆ SetGrowSelectionRemoveSeed()
virtual void vtkPVRenderViewSettings::SetGrowSelectionRemoveSeed ( bool  )
Default is false.
◆ GetGrowSelectionRemoveSeed()
virtual bool vtkPVRenderViewSettings::GetGrowSelectionRemoveSeed ( )
Default is false.
◆ SetGrowSelectionRemoveIntermediateLayers()
virtual void vtkPVRenderViewSettings::SetGrowSelectionRemoveIntermediateLayers ( bool  )
Default is false.
◆ GetGrowSelectionRemoveIntermediateLayers()
virtual bool vtkPVRenderViewSettings::GetGrowSelectionRemoveIntermediateLayers ( )
Default is false.
◆ SetBackgroundColor() [1/2]
virtual void vtkPVRenderViewSettings::SetBackgroundColor ( double  ,
double  ,
double
◆ SetBackgroundColor() [2/2]
virtual void vtkPVRenderViewSettings::SetBackgroundColor ( double  [3])
◆ GetBackgroundColor() [1/3]
virtual double* vtkPVRenderViewSettings::GetBackgroundColor ( )
◆ GetBackgroundColor() [2/3]
virtual void vtkPVRenderViewSettings::GetBackgroundColor ( double &  ,
double &  ,
double &
◆ GetBackgroundColor() [3/3]
virtual void vtkPVRenderViewSettings::GetBackgroundColor ( double  [3])
◆ SetBackground2Color() [1/2]
virtual void vtkPVRenderViewSettings::SetBackground2Color ( double  ,
double  ,
double
◆ SetBackground2Color() [2/2]
virtual void vtkPVRenderViewSettings::SetBackground2Color ( double  [3])
◆ GetBackground2Color() [1/3]
virtual double* vtkPVRenderViewSettings::GetBackground2Color ( )
◆ GetBackground2Color() [2/3]
virtual void vtkPVRenderViewSettings::GetBackground2Color ( double &  ,
double &  ,
double &
◆ GetBackground2Color() [3/3]
virtual void vtkPVRenderViewSettings::GetBackground2Color ( double  [3])
◆ SetBackgroundColorMode()
virtual void vtkPVRenderViewSettings::SetBackgroundColorMode ( int  )
◆ GetBackgroundColorMode()
virtual int vtkPVRenderViewSettings::GetBackgroundColorMode ( )
◆ SetZoomClosestOffsetRatio()
virtual void vtkPVRenderViewSettings::SetZoomClosestOffsetRatio ( double  )
Default is 0.9.
◆ GetZoomClosestOffsetRatio()
virtual double vtkPVRenderViewSettings::GetZoomClosestOffsetRatio ( )
Default is 0.9.
◆ DefaultInteractionMode
int vtkPVRenderViewSettings::DefaultInteractionMode
Definition at line 158 of file vtkPVRenderViewSettings.h.
◆ OutlineThreshold
vtkIdType vtkPVRenderViewSettings::OutlineThreshold
Definition at line 159 of file vtkPVRenderViewSettings.h.
◆ TwoSidedLighting
bool vtkPVRenderViewSettings::TwoSidedLighting = true
Definition at line 160 of file vtkPVRenderViewSettings.h.
◆ PointPickingRadius
int vtkPVRenderViewSettings::PointPickingRadius
Definition at line 161 of file vtkPVRenderViewSettings.h.
◆ DisableIceT
bool vtkPVRenderViewSettings::DisableIceT
Definition at line 162 of file vtkPVRenderViewSettings.h.
◆ EnableFastPreselection
bool vtkPVRenderViewSettings::EnableFastPreselection
Definition at line 163 of file vtkPVRenderViewSettings.h.
◆ GrowSelectionRemoveSeed
bool vtkPVRenderViewSettings::GrowSelectionRemoveSeed = false
Definition at line 164 of file vtkPVRenderViewSettings.h.
◆ GrowSelectionRemoveIntermediateLayers
bool vtkPVRenderViewSettings::GrowSelectionRemoveIntermediateLayers = false
Definition at line 165 of file vtkPVRenderViewSettings.h.
◆ BackgroundColor
double vtkPVRenderViewSettings::BackgroundColor[3]
Definition at line 167 of file vtkPVRenderViewSettings.h.
◆ Background2Color
double vtkPVRenderViewSettings::Background2Color[3]
Definition at line 168 of file vtkPVRenderViewSettings.h.
◆ BackgroundColorMode
int vtkPVRenderViewSettings::BackgroundColorMode
Definition at line 169 of file vtkPVRenderViewSettings.h.
◆ ZoomClosestOffsetRatio
double vtkPVRenderViewSettings::ZoomClosestOffsetRatio
Definition at line 170 of file vtkPVRenderViewSettings.h.
