vtkPVClientServerSynchronizedRenderers Class Reference
#include <vtkPVClientServerSynchronizedRenderers.h>
Inheritance diagram for vtkPVClientServerSynchronizedRenderers:
Collaboration diagram for vtkPVClientServerSynchronizedRenderers:
typedef vtkSynchronizedRenderers Superclass
- Public Types inherited from vtkSynchronizedRenderers
virtual void SetLossLessCompression (bool)
virtual bool GetLossLessCompression ()
virtual void SetNVPipeSupport (bool)
virtual bool GetNVPipeSupport ()
virtual void ConfigureCompressor (const char *stream)
 Set and configure a compressor from it's own configuration stream. More...
- Public Member Functions inherited from vtkSynchronizedRenderers
vtkSynchronizedRenderers * NewInstance () const
void CollectiveExpandForVisiblePropBounds (double bounds[6])
virtual void SetRenderer (vtkRenderer *)
virtual vtkRenderer * GetRenderer ()
virtual void SetParallelController (vtkMultiProcessController *)
virtual vtkMultiProcessController * GetParallelController ()
virtual void SetParallelRendering (bool)
virtual bool GetParallelRendering ()
virtual void ParallelRenderingOn ()
virtual void ParallelRenderingOff ()
virtual void SetImageReductionFactor (int)
virtual int GetImageReductionFactor ()
virtual void SetWriteBackImages (bool)
virtual bool GetWriteBackImages ()
virtual void WriteBackImagesOn ()
virtual void WriteBackImagesOff ()
virtual void SetRootProcessId (int)
virtual int GetRootProcessId ()
virtual void SetCaptureDelegate (vtkSynchronizedRenderers *)
virtual vtkSynchronizedRenderers * GetCaptureDelegate ()
virtual void SetAutomaticEventHandling (bool)
virtual bool GetAutomaticEventHandling ()
virtual void AutomaticEventHandlingOn ()
virtual void AutomaticEventHandlingOff ()
static vtkPVClientServerSynchronizedRenderers * New ()
static vtkPVClientServerSynchronizedRenderers * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSynchronizedRenderers
static vtkSynchronizedRenderers * New ()
static vtkSynchronizedRenderers * SafeDownCast (vtkObjectBase *o)
 vtkPVClientServerSynchronizedRenderers ()
 ~vtkPVClientServerSynchronizedRenderers () override
vtkUnsignedCharArray * Compress (vtkUnsignedCharArray *)
void Decompress (vtkUnsignedCharArray *input, vtkUnsignedCharArray *outputBuffer)
void MasterEndRender () override
void SlaveEndRender () override
void SetCompressor (vtkImageCompressor *comp)
 Set/Get the compressor object, it's setting can be manipulated directly. More...
virtual vtkImageCompressor * GetCompressor ()
- Protected Member Functions inherited from vtkSynchronizedRenderers
 vtkSynchronizedRenderers ()
 ~vtkSynchronizedRenderers ()
virtual void HandleStartRender ()
virtual void HandleEndRender ()
virtual void HandleAbortRender ()
virtual void MasterStartRender ()
virtual void SlaveStartRender ()
virtual vtkRawImage & CaptureRenderedImage ()
virtual void PushImageToScreen ()
vtkImageCompressor * Compressor
bool LossLessCompression
bool NVPipeSupport
- Protected Attributes inherited from vtkSynchronizedRenderers
vtkMultiProcessController * ParallelController
vtkOpenGLRenderer * Renderer
vtkSynchronizedRenderers * CaptureDelegate
vtkRawImage ReducedImage
vtkRawImage FullImage
bool ParallelRendering
int ImageReductionFactor
bool WriteBackImages
int RootProcessId
bool AutomaticEventHandling
- Public Attributes inherited from vtkSynchronizedRenderers
 SYNC_RENDERER_TAG
 RESET_CAMERA_TAG
 COMPUTE_BOUNDS_TAG
vtkPVClientServerSynchronizedRenderers is similar to vtkClientServerSynchronizedRenderers except that it optionally uses image compressors to compress the image before transmitting.
Definition at line 21 of file vtkPVClientServerSynchronizedRenderers.h.
Definition at line 26 of file vtkPVClientServerSynchronizedRenderers.h.
◆ vtkPVClientServerSynchronizedRenderers()
vtkPVClientServerSynchronizedRenderers::vtkPVClientServerSynchronizedRenderers ( )
◆ ~vtkPVClientServerSynchronizedRenderers()
vtkPVClientServerSynchronizedRenderers::~vtkPVClientServerSynchronizedRenderers ( )
static vtkPVClientServerSynchronizedRenderers* vtkPVClientServerSynchronizedRenderers::New ( )
virtual const char* vtkPVClientServerSynchronizedRenderers::GetClassName ( )
static int vtkPVClientServerSynchronizedRenderers::IsTypeOf ( const char *  type)
virtual int vtkPVClientServerSynchronizedRenderers::IsA ( const char *  type)
Reimplemented from vtkSynchronizedRenderers.
static vtkPVClientServerSynchronizedRenderers* vtkPVClientServerSynchronizedRenderers::SafeDownCast ( vtkObject *  o)
void vtkPVClientServerSynchronizedRenderers::PrintSelf ( ostream &  os,
◆ SetLossLessCompression()
virtual void vtkPVClientServerSynchronizedRenderers::SetLossLessCompression ( bool  )
◆ GetLossLessCompression()
virtual bool vtkPVClientServerSynchronizedRenderers::GetLossLessCompression ( )
◆ SetNVPipeSupport()
virtual void vtkPVClientServerSynchronizedRenderers::SetNVPipeSupport ( bool  )
◆ GetNVPipeSupport()
virtual bool vtkPVClientServerSynchronizedRenderers::GetNVPipeSupport ( )
◆ ConfigureCompressor()
virtual void vtkPVClientServerSynchronizedRenderers::ConfigureCompressor ( const char *  stream)
This is used by ParaView to configure the compressor from application wide user settings.
◆ SetCompressor()
void vtkPVClientServerSynchronizedRenderers::SetCompressor ( vtkImageCompressor *  comp)
◆ GetCompressor()
virtual vtkImageCompressor* vtkPVClientServerSynchronizedRenderers::GetCompressor ( )
protectedvirtual
◆ Compress()
vtkUnsignedCharArray* vtkPVClientServerSynchronizedRenderers::Compress ( vtkUnsignedCharArray *  )
◆ Decompress()
void vtkPVClientServerSynchronizedRenderers::Decompress ( vtkUnsignedCharArray *  input,
vtkUnsignedCharArray *  outputBuffer
◆ MasterEndRender()
void vtkPVClientServerSynchronizedRenderers::MasterEndRender ( )
overrideprotectedvirtual
◆ SlaveEndRender()
void vtkPVClientServerSynchronizedRenderers::SlaveEndRender ( )
◆ Compressor
vtkImageCompressor* vtkPVClientServerSynchronizedRenderers::Compressor
Definition at line 68 of file vtkPVClientServerSynchronizedRenderers.h.
◆ LossLessCompression
bool vtkPVClientServerSynchronizedRenderers::LossLessCompression
Definition at line 69 of file vtkPVClientServerSynchronizedRenderers.h.
◆ NVPipeSupport
bool vtkPVClientServerSynchronizedRenderers::NVPipeSupport
Definition at line 70 of file vtkPVClientServerSynchronizedRenderers.h.
