vtkPVHardwareSelector Class Reference
vtkHardwareSelector subclass with paraview specific logic to avoid recapturing buffers unless needed. More...
#include <vtkPVHardwareSelector.h>
Inheritance diagram for vtkPVHardwareSelector:
Collaboration diagram for vtkPVHardwareSelector:
typedef vtkOpenGLHardwareSelector Superclass
- Public Types inherited from vtkOpenGLHardwareSelector
typedef vtkHardwareSelector Superclass
- Public Types inherited from vtkHardwareSelector
enum  PassTypes
void SetView (vtkPVRenderView *view)
 Set the view that will be used to exchange messages between all processes involved. More...
virtual vtkSelection * Select (int region[4])
 Perform the selection over the specified region. More...
vtkSelection * PolygonSelect (int *polygonPoints, vtkIdType count)
 Same as Select() above, except this one use a polygon, instead of a rectangle region, and select elements inside the polygon. More...
virtual bool NeedToRenderForSelection ()
 Returns true when the next call to Select() will result in renders to capture the selection-buffers. More...
void InvalidateCachedSelection ()
 Called to invalidate the cache. More...
int AssignUniqueId (vtkProp *)
void BeginRenderProp (vtkRenderWindow *) override
 Set the local ProcessId. More...
virtual void BeginRenderProp ()
virtual void BeginRenderProp (vtkRenderWindow *)
- Public Member Functions inherited from vtkOpenGLHardwareSelector
vtkOpenGLHardwareSelector * NewInstance () const
virtual void EndRenderProp ()
virtual void RenderCompositeIndex (unsigned int index)
virtual void RenderAttributeId (vtkIdType attribid)
virtual void RenderProcessId (unsigned int processid)
- Public Member Functions inherited from vtkHardwareSelector
vtkHardwareSelector * NewInstance () const
vtkSelection * Select ()
int Render (vtkRenderer *renderer, vtkProp **propArray, int propArrayCount)
vtkProp * GetPropFromID (int id)
virtual void SetRenderer (vtkRenderer *)
virtual vtkRenderer * GetRenderer ()
virtual void SetArea (unsigned int, unsigned int, unsigned int, unsigned int)
virtual void SetArea (unsigned int[4])
virtual unsigned int * GetArea ()
virtual void GetArea (unsigned int &, unsigned int &, unsigned int &, unsigned int &)
virtual void GetArea (unsigned int[4])
virtual void SetFieldAssociation (int)
virtual void SetUseProcessIdFromData (bool)
virtual bool GetUseProcessIdFromData ()
virtual bool CaptureBuffers ()
PixelInformation GetPixelInformation (const unsigned int display_position[2])
PixelInformation GetPixelInformation (const unsigned int display_position[2], int maxDist)
PixelInformation GetPixelInformation (const unsigned int display_position[2], int maxDist, unsigned int selected_position[2])
void ClearBuffers ()
virtual void SetProcessID (int)
virtual int GetProcessID ()
virtual float * GetPropColorValue ()
virtual void GetPropColorValue (float &, float &, float &)
virtual void GetPropColorValue (float[3])
virtual void SetPropColorValue (float, float, float)
virtual void SetPropColorValue (float[3])
virtual int GetCurrentPass ()
virtual vtkSelection * GenerateSelection ()
virtual vtkSelection * GenerateSelection (unsigned int r[4])
virtual vtkSelection * GenerateSelection (unsigned int x1, unsigned int y1, unsigned int x2, unsigned int y2)
virtual vtkSelection * GeneratePolygonSelection (int *polygonPoints, vtkIdType count)
static vtkPVHardwareSelector * New ()
static vtkPVHardwareSelector * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkOpenGLHardwareSelector
static vtkOpenGLHardwareSelector * New ()
static vtkOpenGLHardwareSelector * SafeDownCast (vtkObjectBase *o)
- Static Public Member Functions inherited from vtkHardwareSelector
static vtkHardwareSelector * New ()
static vtkHardwareSelector * SafeDownCast (vtkObjectBase *o)
static void Convert (int id, float tcoord[3])
 vtkPVHardwareSelector ()
 ~vtkPVHardwareSelector () override
int GetPropID (int idx, vtkProp *prop) override
 Return a unique ID for the prop. More...
bool PassRequired (int pass) override
 Returns is the pass indicated is needed. More...
bool PrepareSelect ()
 Prepare for selection. More...
void SavePixelBuffer (int passNo) override
- Protected Member Functions inherited from vtkOpenGLHardwareSelector
 vtkOpenGLHardwareSelector ()
virtual ~vtkOpenGLHardwareSelector ()
virtual void EndRenderProp (vtkRenderWindow *)
- Protected Member Functions inherited from vtkHardwareSelector
 vtkHardwareSelector ()
 ~vtkHardwareSelector ()
int Convert (unsigned long offset, unsigned char *pb)
vtkIdType GetID (int low24, int mid24, int high16)
bool IsPropHit (int propid)
virtual void BeginSelection ()
virtual void EndSelection ()
void BuildPropHitList (unsigned char *rgbData)
int Convert (unsigned int pos[2], unsigned char *pb)
int Convert (int xx, int yy, unsigned char *pb)
virtual int GetPropID (int idx, vtkProp *vtkNotUsed(prop))
void ReleasePixBuffers ()
vtkTimeStamp CaptureTime
int UniqueId
- Protected Attributes inherited from vtkOpenGLHardwareSelector
vtkInternals * Internals
- Protected Attributes inherited from vtkHardwareSelector
unsigned char * PixBuffer [10]
int ProcessID
int CurrentPass
int InPropRender
int PropID
float PropColorValue [3]
vtkRenderer * Renderer
unsigned int Area [4]
int FieldAssociation
bool UseProcessIdFromData
vtkIdType MaxAttributeId
- Public Attributes inherited from vtkHardwareSelector
 PROCESS_PASS
 ACTOR_PASS
 COMPOSITE_INDEX_PASS
 ID_LOW24
 ID_MID24
 ID_HIGH16
 MAX_KNOWN_PASS
 MIN_KNOWN_PASS
vtkHardwareSelector is subclass of vtkHardwareSelector that adds logic to reuse the captured buffers as much as possible. Thus avoiding repeated selection-rendering of repeated selections or picking. This class does not know, however, when the cached buffers are invalid. External logic must explicitly calls InvalidateCachedSelection() to ensure that the cache is not reused.
Definition at line 24 of file vtkPVHardwareSelector.h.
Definition at line 28 of file vtkPVHardwareSelector.h.
◆ vtkPVHardwareSelector()
vtkPVHardwareSelector::vtkPVHardwareSelector ( )
◆ ~vtkPVHardwareSelector()
vtkPVHardwareSelector::~vtkPVHardwareSelector ( )
static vtkPVHardwareSelector* vtkPVHardwareSelector::New ( )
virtual const char* vtkPVHardwareSelector::GetClassName ( )
static int vtkPVHardwareSelector::IsTypeOf ( const char *  type)
virtual int vtkPVHardwareSelector::IsA ( const char *  type)
Reimplemented from vtkOpenGLHardwareSelector.
static vtkPVHardwareSelector* vtkPVHardwareSelector::SafeDownCast ( vtkObject *  o)
void vtkPVHardwareSelector::PrintSelf ( ostream &  os,
◆ SetView()
void vtkPVHardwareSelector::SetView ( vtkPVRenderView *  view)
Note this does not affect the reference count of the view.
◆ Select()
virtual vtkSelection* vtkPVHardwareSelector::Select ( int  region[4])
Avoid clearing of captured buffers.
◆ PolygonSelect()
vtkSelection* vtkPVHardwareSelector::PolygonSelect ( int *  polygonPoints,
vtkIdType  count
◆ NeedToRenderForSelection()
virtual bool vtkPVHardwareSelector::NeedToRenderForSelection ( )
◆ InvalidateCachedSelection()
void vtkPVHardwareSelector::InvalidateCachedSelection ( )
inline
Definition at line 58 of file vtkPVHardwareSelector.h.
◆ AssignUniqueId()
int vtkPVHardwareSelector::AssignUniqueId ( vtkProp *  )
◆ BeginRenderProp() [1/7]
void vtkPVHardwareSelector::BeginRenderProp ( vtkRenderWindow *  )
◆ GetPropID()
int vtkPVHardwareSelector::GetPropID ( int  idx,
vtkProp *  prop
◆ PassRequired()
bool vtkPVHardwareSelector::PassRequired ( int  pass)
overrideprotectedvirtual
Overridden to report that we always need the process-id pass. In future, we can be smart about it by only requiring it for sessions with more than 1 data-server.
Reimplemented from vtkHardwareSelector.
◆ PrepareSelect()
bool vtkPVHardwareSelector::PrepareSelect ( )
Return false if CaptureBuffers() is false
◆ SavePixelBuffer()
void vtkPVHardwareSelector::SavePixelBuffer ( int  passNo)
◆ BeginRenderProp() [2/7]
virtual void vtkOpenGLHardwareSelector::BeginRenderProp
◆ BeginRenderProp() [3/7]
◆ BeginRenderProp() [4/7]
◆ BeginRenderProp() [5/7]
◆ BeginRenderProp() [6/7]
◆ BeginRenderProp() [7/7]
◆ CaptureTime
vtkTimeStamp vtkPVHardwareSelector::CaptureTime
Definition at line 94 of file vtkPVHardwareSelector.h.
◆ UniqueId
int vtkPVHardwareSelector::UniqueId
Definition at line 95 of file vtkPVHardwareSelector.h.
