Signals | Public Member Functions | Protected Slots | Protected Member Functions | Properties | List of all members
pqTextLocationWidget Class Reference
pqTextLocationWidget is a pqPropertyWidget that can be used to set the location of the a text representation relative to the viewport. More...
#include <pqTextLocationWidget.h>
Inheritance diagram for pqTextLocationWidget:
Collaboration diagram for pqTextLocationWidget:
Signals
void windowLocationChanged (QString &)
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqTextLocationWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqTextLocationWidget () override
QString windowLocation () const
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void radioButtonLocationClicked ()
void radioButtonPositionClicked ()
void updateUI ()
void setWindowLocation (QString &)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Properties
template<class T >
Definition at line 16 of file pqTextLocationWidget.h.
◆ pqTextLocationWidget()
pqTextLocationWidget::pqTextLocationWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqTextLocationWidget()
pqTextLocationWidget::~pqTextLocationWidget ( )
override
◆ windowLocation()
QString pqTextLocationWidget::windowLocation ( ) const
◆ windowLocationChanged
void pqTextLocationWidget::windowLocationChanged ( QString &  )
signal
◆ setWindowLocation()
void pqTextLocationWidget::setWindowLocation ( QString &  )
◆ radioButtonLocationClicked
void pqTextLocationWidget::radioButtonLocationClicked ( )
protectedslot
◆ radioButtonPositionClicked
void pqTextLocationWidget::radioButtonPositionClicked ( )
protectedslot
◆ updateUI
void pqTextLocationWidget::updateUI ( )
protectedslot
Property Documentation
◆ windowLocation
readwrite
Definition at line 19 of file pqTextLocationWidget.h.
