Signals | Public Member Functions | Protected Attributes | List of all members
pqBoolPropertyWidgetDecorator Class Reference
pqBoolPropertyWidgetDecorator is a base class for enable/disable or show/hide widgets based on the status of another property not directly controlled by the widget. More...
#include <pqBoolPropertyWidgetDecorator.h>
Inheritance diagram for pqBoolPropertyWidgetDecorator:
Collaboration diagram for pqBoolPropertyWidgetDecorator:
Signals
void boolPropertyChanged ()
- Signals inherited from pqPropertyWidgetDecorator
void visibilityChanged ()
 This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void enableStateChanged ()
 pqBoolPropertyWidgetDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent)
 ~pqBoolPropertyWidgetDecorator () override
bool isBoolProperty () const
- Public Member Functions inherited from pqPropertyWidgetDecorator
 pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Constructor. More...
 ~pqPropertyWidgetDecorator () override
pqPropertyWidget * parentWidget () const
 Returns the pqPropertyWidget parent. More...
virtual bool canShowWidget (bool show_advanced) const
 Override this method to override the visibility of the widget in the panel. More...
virtual bool enableWidget () const
 Override this method to override the enable state of the widget in the panel. More...
vtkWeakPointer< vtkSMProperty > Property
QString Function
int Index
unsigned long ObserverId
bool BoolProperty
QString Value
- Static Public Member Functions inherited from pqPropertyWidgetDecorator
static pqPropertyWidgetDecorator * create (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More...
- Protected Member Functions inherited from pqPropertyWidgetDecorator
vtkPVXMLElement * xml () const
Definition at line 16 of file pqBoolPropertyWidgetDecorator.h.
◆ pqBoolPropertyWidgetDecorator()
pqBoolPropertyWidgetDecorator::pqBoolPropertyWidgetDecorator ( vtkPVXMLElement *  config,
◆ ~pqBoolPropertyWidgetDecorator()
pqBoolPropertyWidgetDecorator::~pqBoolPropertyWidgetDecorator ( )
override
◆ isBoolProperty()
bool pqBoolPropertyWidgetDecorator::isBoolProperty ( ) const
inline
Definition at line 26 of file pqBoolPropertyWidgetDecorator.h.
◆ boolPropertyChanged
void pqBoolPropertyWidgetDecorator::boolPropertyChanged ( )
signal
◆ Property
vtkWeakPointer<vtkSMProperty> pqBoolPropertyWidgetDecorator::Property
Definition at line 32 of file pqBoolPropertyWidgetDecorator.h.
◆ Function
QString pqBoolPropertyWidgetDecorator::Function
Definition at line 33 of file pqBoolPropertyWidgetDecorator.h.
◆ Index
int pqBoolPropertyWidgetDecorator::Index
Definition at line 34 of file pqBoolPropertyWidgetDecorator.h.
◆ ObserverId
unsigned long pqBoolPropertyWidgetDecorator::ObserverId
Definition at line 35 of file pqBoolPropertyWidgetDecorator.h.
◆ BoolProperty
bool pqBoolPropertyWidgetDecorator::BoolProperty
Definition at line 36 of file pqBoolPropertyWidgetDecorator.h.
◆ Value
QString pqBoolPropertyWidgetDecorator::Value
Definition at line 37 of file pqBoolPropertyWidgetDecorator.h.
