Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqShaderReplacementsSelectorPropertyWidget Class Reference
Property widget for selecting the ShaderReplacements to apply to a geometry. More...
#include <pqShaderReplacementsSelectorPropertyWidget.h>
Inheritance diagram for pqShaderReplacementsSelectorPropertyWidget:
Collaboration diagram for pqShaderReplacementsSelectorPropertyWidget:
 pqShaderReplacementsSelectorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqShaderReplacementsSelectorPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void updateShaderReplacements ()
void textChangedAndEditingFinished ()
void onLoad ()
void onDelete ()
void onPresetChanged (int index)
bool loadShaderReplacements (const QString &filename)
void refreshView ()
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
To use this widget for a property add 'panel_widget="shader_replacements_selector"' to the property's XML.
Definition at line 19 of file pqShaderReplacementsSelectorPropertyWidget.h.
◆ pqShaderReplacementsSelectorPropertyWidget()
pqShaderReplacementsSelectorPropertyWidget::pqShaderReplacementsSelectorPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
◆ ~pqShaderReplacementsSelectorPropertyWidget()
pqShaderReplacementsSelectorPropertyWidget::~pqShaderReplacementsSelectorPropertyWidget ( )
override
◆ updateShaderReplacements
void pqShaderReplacementsSelectorPropertyWidget::updateShaderReplacements ( )
protectedslot
◆ textChangedAndEditingFinished
void pqShaderReplacementsSelectorPropertyWidget::textChangedAndEditingFinished ( )
protectedslot
◆ onLoad
void pqShaderReplacementsSelectorPropertyWidget::onLoad ( )
protectedslot
◆ onDelete
void pqShaderReplacementsSelectorPropertyWidget::onDelete ( )
protectedslot
◆ onPresetChanged
void pqShaderReplacementsSelectorPropertyWidget::onPresetChanged ( int  index)
protectedslot
◆ loadShaderReplacements()
bool pqShaderReplacementsSelectorPropertyWidget::loadShaderReplacements ( const QString &  filename)
◆ refreshView()
void pqShaderReplacementsSelectorPropertyWidget::refreshView ( )
