Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | Friends | List of all members
pqRepresentation Class Reference
This is PQ representation for a single representation. More...
#include <pqRepresentation.h>
Inheritance diagram for pqRepresentation:
Collaboration diagram for pqRepresentation:
Public Slots
void renderView (bool force)
 Renders the view to which this representation has been added if any. More...
void renderViewEventually ()
 Simply calls renderView(false);. More...
Signals
void visibilityChanged (bool visible)
 Fired when the visibility property of the underlying display changes. More...
void updated ()
 Fired whenever Update() is called on the underlying display proxy. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
 pqRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=nullptr)
 ~pqRepresentation () override
virtual bool isVisible () const
 Returns if the status of the visbility property of this display. More...
virtual void setVisible (bool visible)
 Set the visibility. More...
pqView * getView () const
 Returns the view to which this representation has been added, if any. More...
vtkSMViewProxy * getViewProxy () const
 Returns the view proxy to which this representation has been added, if any. More...
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServer * getServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxy * getProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElement * getHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManager * proxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
Protected Slots
virtual void onVisibilityChanged ()
 called when the display visibility property changes. More...
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
 Called by pqView when this representation gets added to / removed from the view. More...
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void initialize ()
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnect * getConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
Friends
class pqView
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
- Static Public Member Functions inherited from pqProxy
static pqProxy * findProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static std::string rstToHtml (const char *rstStr)
 convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
static QString rstToHtml (const QString &rstStr)
This class provides API for the Qt layer to access representations.
Definition at line 19 of file pqRepresentation.h.
◆ pqRepresentation()
pqRepresentation::pqRepresentation ( const QString &  group,
const QString &  name,
vtkSMProxy *  repr,
pqServer *  server,
QObject *  parent = nullptr
◆ ~pqRepresentation()
pqRepresentation::~pqRepresentation ( )
override
◆ isVisible()
virtual bool pqRepresentation::isVisible ( ) const
Note that for a display to be visible in a view, it must be added to that view as well as visibility must be set to 1.
◆ setVisible()
virtual void pqRepresentation::setVisible ( bool  visible)
Set the visibility.
Note that this affects the visibility of the display in the view it has been added to, if any. This method does not call a re-render on the view, caller must call that explicitly.
◆ getView()
pqView* pqRepresentation::getView ( ) const
◆ getViewProxy()
vtkSMViewProxy* pqRepresentation::getViewProxy ( ) const
◆ renderView
void pqRepresentation::renderView ( bool  force)
slot
If force is true, then the render is triggered immediately, otherwise, it will be called on idle.
◆ renderViewEventually
void pqRepresentation::renderViewEventually ( )
inlineslot
Definition at line 71 of file pqRepresentation.h.
◆ visibilityChanged
void pqRepresentation::visibilityChanged ( bool  visible)
signal
It must be noted that this is fired on the property change, the property is not pushed yet, hence the visibility of the underlying VTK prop hasn't changed.
◆ updated
void pqRepresentation::updated ( )
signal
◆ onVisibilityChanged
virtual void pqRepresentation::onVisibilityChanged ( )
protectedvirtualslot
◆ setView()
virtual void pqRepresentation::setView ( pqView *  )
protectedvirtual
Reimplemented in pqPipelineRepresentation.
◆ pqView
friend class pqView
friend
Definition at line 93 of file pqRepresentation.h.
