Public Member Functions | List of all members
pqServerResource Class Reference
pqServerResource encapsulates a resource in ParaView. More...
#include <pqServerResource.h>
 pqServerResource ()
 ~pqServerResource ()
pqServerResource & operator= (const pqServerResource &)
 pqServerResource (const QString &uri)
 Create an pqServerResource from a provided URI. More...
 pqServerResource (const QString &uri, const pqServerConfiguration &config)
 Create an pqServerResource from a provided URI and store related configuration If the configuration is named, the configuration name will be used as a serverName. More...
 pqServerResource (const pqServerResource &)
 Create a pqServerResource by copy. More...
const pqServerConfiguration & configuration () const
 Returns the pqServerConfiguration from which this resource was created, if any. More...
QString toURI () const
 Returns a compact string representation of the complete resource in URI format, see above. More...
QString serializeString () const
 Returns a compact string representation of the resource including extra data. More...
QString scheme () const
 Returns the resource scheme, builtin, cs, csrc, cdsrs or cdsrsrc. More...
void setScheme (const QString &)
 Sets the resource scheme. More...
bool isReverse () const
 Returns if the connection scheme is a reverse one. More...
QString host () const
 Returns the resource host, or empty string for builtin, cdsrs, and cdsrsrc schemes. More...
void setHost (const QString &)
 Sets the resource host. More...
int port () const
 Return the resource port, or -1 for builtin, cdsrs, and cdsrsrc schemes. More...
int port (int default_port) const
 Return the resource port, or default_port for builtin, cdsrs, and cdsrsrc schemes. More...
void setPort (int)
 Set the resource port. More...
QString dataServerHost () const
 Return the data server host, if any. More...
void setDataServerHost (const QString &)
 Set the data server host. More...
int dataServerPort () const
 Return the data server port, if any, or -1. More...
int dataServerPort (int default_port) const
 Return the data server port, if any, or default_port. More...
void setDataServerPort (int)
 Set the data server port. More...
QString renderServerHost () const
 Return the render server host, if any. More...
void setRenderServerHost (const QString &)
 Set the render server host. More...
int renderServerPort () const
 Return the render server port, if any, or -1. More...
int renderServerPort (int default_port) const
 Return the render server port, if any, or default_port. More...
void setRenderServerPort (int)
 Set the render server port. More...
QString path () const
 Return the path to the resource, if any. More...
void setPath (const QString &)
 Set the path to the resource. More...
QString serverName () const
 Return the server name of the resource, if any. More...
void setServerName (const QString &name)
 Set the server name of the resource. More...
void addData (const QString &key, const QString &value)
 Add a data on this resource, with a key/value logic. More...
QString data (const QString &key) const
 Get data from this resource, associated with the provided key, if any. More...
QString data (const QString &key, const QString &default_value) const
bool hasData (const QString &key) const
 Return true if this resource has data associated with the provided key, false otherwise. More...
pqServerResource schemeHostsPorts () const
 Returns a copy of this resource containing only server connection information - scheme, host, and port numbers. More...
pqServerResource schemeHosts () const
 Returns a copy of this resource containing a subset of server information - scheme and host (no port numbers) More...
pqServerResource hostPath () const
 Returns a copy of this resource containing only host and path information - scheme and port numbers are excluded. More...
pqServerResource pathServerName () const
 Returns a copy of this resource containing only path and server name information - scheme, host and port numbers are excluded. More...
pqServerResource sessionServer () const
 Deprecated method, just return a copy of this. More...
void setSessionServer (const pqServerResource &)
 Deprecated method, noop. More...
bool operator== (const pqServerResource &) const
 Operators comparing all elements of the resource. More...
bool operator!= (const pqServerResource &) const
bool operator< (const pqServerResource &) const
A resource can be anything, a data file, a list of data files, a state file, or a connection to a server. The resource specification is based on URL-like syntax:
* <scheme>://<scheme-specific-parameters>
To specify a data or state file, the following syntax is used:
* <connection-scheme>:[//<server-details>]/<path-to-data-file>[#serverName]:KEY:1
connection-scheme can be
server-details are of the form <serverhost-name>:<port> or <dataserver-hostname>:<dataserver-port>/<renderserver-hostname>:<render-server-port> as applicable. Port numbers are always optional.
The KEY should be PARAVIEW_DATA for data file and PARAVIEW_STATE for state file.
Examples:
* builtin:/home/user/foo.vtk
* cs://amber1:11112/C:\Users\User\foo.vtk
* cdsrsrc://amber2:11111/amber3:22222/home/user/foo.vtk#amberDRS
To specify a server-connection, without pointing to any data file(s), the following syntax may be used:
Examples:
* builtin:
* cs://amber1:11112
As with data-files, port numbers are always optional in when specifying server-details.
Server name is also optional but will be used if available.
Arbitrary data can be added to a resource. ParaView leverages this mechanism to identify statefiles, to save additional files in a file series when referring to a data file, or details about how to connect to the server when referring to a server-connection.
See also
pqServerResources, pqServer
Definition at line 73 of file pqServerResource.h.
◆ pqServerResource() [1/4]
pqServerResource::pqServerResource ( )
◆ ~pqServerResource()
pqServerResource::~pqServerResource ( )
◆ pqServerResource() [2/4]
pqServerResource::pqServerResource ( const QString &  uri)
◆ pqServerResource() [3/4]
pqServerResource::pqServerResource ( const QString &  uri,
◆ pqServerResource() [4/4]
pqServerResource::pqServerResource ( const pqServerResource &  )
◆ operator=()
pqServerResource& pqServerResource::operator= ( const pqServerResource &  )
◆ configuration()
const pqServerConfiguration& pqServerResource::configuration ( ) const
◆ toURI()
QString pqServerResource::toURI ( ) const
◆ serializeString()
QString pqServerResource::serializeString ( ) const
◆ scheme()
QString pqServerResource::scheme ( ) const
◆ setScheme()
void pqServerResource::setScheme ( const QString &  )
◆ isReverse()
bool pqServerResource::isReverse ( ) const
◆ host()
QString pqServerResource::host ( ) const
◆ setHost()
void pqServerResource::setHost ( const QString &  )
◆ port() [1/2]
int pqServerResource::port ( ) const
◆ port() [2/2]
int pqServerResource::port ( int  default_port) const
◆ setPort()
void pqServerResource::setPort ( int  )
◆ dataServerHost()
QString pqServerResource::dataServerHost ( ) const
◆ setDataServerHost()
void pqServerResource::setDataServerHost ( const QString &  )
◆ dataServerPort() [1/2]
int pqServerResource::dataServerPort ( ) const
◆ dataServerPort() [2/2]
int pqServerResource::dataServerPort ( int  default_port) const
◆ setDataServerPort()
void pqServerResource::setDataServerPort ( int  )
◆ renderServerHost()
QString pqServerResource::renderServerHost ( ) const
◆ setRenderServerHost()
void pqServerResource::setRenderServerHost ( const QString &  )
◆ renderServerPort() [1/2]
int pqServerResource::renderServerPort ( ) const
◆ renderServerPort() [2/2]
int pqServerResource::renderServerPort ( int  default_port) const
◆ setRenderServerPort()
void pqServerResource::setRenderServerPort ( int  )
◆ path()
QString pqServerResource::path ( ) const
◆ setPath()
void pqServerResource::setPath ( const QString &  )
◆ serverName()
QString pqServerResource::serverName ( ) const
◆ setServerName()
void pqServerResource::setServerName ( const QString &  name)
◆ addData()
void pqServerResource::addData ( const QString &  key,
const QString &  value
◆ data() [1/2]
QString pqServerResource::data ( const QString &  key) const
◆ data() [2/2]
QString pqServerResource::data ( const QString &  key,
const QString &  default_value
) const
If not, return default_value.
◆ hasData()
bool pqServerResource::hasData ( const QString &  key) const
◆ schemeHostsPorts()
pqServerResource pqServerResource::schemeHostsPorts ( ) const
◆ schemeHosts()
pqServerResource pqServerResource::schemeHosts ( ) const
◆ hostPath()
pqServerResource pqServerResource::hostPath ( ) const
◆ pathServerName()
pqServerResource pqServerResource::pathServerName ( ) const
◆ sessionServer()
pqServerResource pqServerResource::sessionServer ( ) const
inline
Definition at line 270 of file pqServerResource.h.
◆ setSessionServer()
void pqServerResource::setSessionServer ( const pqServerResource &  )
inline
Definition at line 276 of file pqServerResource.h.
◆ operator==()
bool pqServerResource::operator== ( const pqServerResource &  ) const
◆ operator!=()
bool pqServerResource::operator!= ( const pqServerResource &  ) const
◆ operator<()
bool pqServerResource::operator< ( const pqServerResource &  ) const
