Signals | Public Member Functions | Protected Slots | Properties | List of all members
pqSelectionListPropertyWidget Class Reference
pqSelectionListPropertyWidget is a custom widget used to associate a label for each selectionNode from an input selection. More...
#include <pqSelectionListPropertyWidget.h>
Inheritance diagram for pqSelectionListPropertyWidget:
Collaboration diagram for pqSelectionListPropertyWidget:
Signals
void labelsChanged ()
 Signal for the labels proxy changed. More...
- Signals inherited from pqPropertyGroupWidget
void changeFinished ()
void changeAvailable ()
void restartRequired ()
 pqSelectionListPropertyWidget (vtkSMProxy *smproxy, vtkSMPropertyGroup *smgroup, QWidget *parentObject=nullptr)
 ~pqSelectionListPropertyWidget () override
QList< QVariant > labels () const
 Methods used to set/get the label values for the widget. More...
void setLabels (const QList< QVariant > &labels)
- Public Member Functions inherited from pqPropertyGroupWidget
 pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr)
vtkSMPropertyGroup * propertyGroup () const
void addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1)
void addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1)
void addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1)
void addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1)
char * panelVisibility () const override
 Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
void setPanelVisibility (const char *vis) override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void populateRowLabels (pqSMProxy appendSelection)
 Clone the active selection handled by the selection manager. More...
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It also use the pqSelectionInputWidget to know the number of labels we need to define, by copying the active selection.
Definition at line 25 of file pqSelectionListPropertyWidget.h.
◆ pqSelectionListPropertyWidget()
pqSelectionListPropertyWidget::pqSelectionListPropertyWidget ( vtkSMProxy *  smproxy,
QWidget *  parentObject = nullptr
◆ ~pqSelectionListPropertyWidget()
pqSelectionListPropertyWidget::~pqSelectionListPropertyWidget ( )
override
◆ labels()
QList<QVariant> pqSelectionListPropertyWidget::labels ( ) const
The number of labels required depend of the number of SelectionNode in the activeSelection provided by the pqSelectionInputWidget.
◆ setLabels()
void pqSelectionListPropertyWidget::setLabels ( const QList< QVariant > &  labels)
◆ labelsChanged
void pqSelectionListPropertyWidget::labelsChanged ( )
signal
◆ populateRowLabels
void pqSelectionListPropertyWidget::populateRowLabels ( pqSMProxy  appendSelection)
protectedslot
Property Documentation
◆ labels
readwrite
Definition at line 29 of file pqSelectionListPropertyWidget.h.
