Public Member Functions | Static Public Member Functions | List of all members
pqIntVectorPropertyWidget Class Reference
#include <pqIntVectorPropertyWidget.h>
Inheritance diagram for pqIntVectorPropertyWidget:
Collaboration diagram for pqIntVectorPropertyWidget:
 pqIntVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqIntVectorPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
static pqPropertyWidget * createWidget (vtkSMIntVectorProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent)
 Creates known pqPropertyWidget subclasses for vtkSMIntVectorProperty property. More...
template<class T >
void changeAvailable ()
void changeFinished ()
void restartRequired ()
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 12 of file pqIntVectorPropertyWidget.h.
◆ pqIntVectorPropertyWidget()
pqIntVectorPropertyWidget::pqIntVectorPropertyWidget ( vtkSMProperty *  property,
vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqIntVectorPropertyWidget()
pqIntVectorPropertyWidget::~pqIntVectorPropertyWidget ( )
override
◆ createWidget()
static pqPropertyWidget* pqIntVectorPropertyWidget::createWidget ( vtkSMIntVectorProperty *  smproperty,
vtkSMProxy *  smproxy,
QWidget *  parent
