Public Member Functions | List of all members
pqDisplayPanelPropertyWidget Class Reference
#include <pqDisplayPanelPropertyWidget.h>
Inheritance diagram for pqDisplayPanelPropertyWidget:
Collaboration diagram for pqDisplayPanelPropertyWidget:
 pqDisplayPanelPropertyWidget (pqDisplayPanel *displayPanel, QWidget *parent=nullptr)
 ~pqDisplayPanelPropertyWidget () override
pqDisplayPanel * getDisplayPanel () const
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 12 of file pqDisplayPanelPropertyWidget.h.
◆ pqDisplayPanelPropertyWidget()
pqDisplayPanelPropertyWidget::pqDisplayPanelPropertyWidget ( pqDisplayPanel *  displayPanel,
QWidget *  parent = nullptr
explicit
◆ ~pqDisplayPanelPropertyWidget()
pqDisplayPanelPropertyWidget::~pqDisplayPanelPropertyWidget ( )
override
◆ getDisplayPanel()
pqDisplayPanel* pqDisplayPanelPropertyWidget::getDisplayPanel ( ) const
