Signals | Public Member Functions | Protected Slots | Properties | List of all members
pqBackgroundEditorWidget Class Reference
#include <pqBackgroundEditorWidget.h>
Inheritance diagram for pqBackgroundEditorWidget:
Collaboration diagram for pqBackgroundEditorWidget:
Signals
void gradientBackgroundChanged ()
void imageBackgroundChanged ()
void skyboxBackgroundChanged ()
void environmentLightingChanged ()
- Signals inherited from pqPropertyGroupWidget
void changeFinished ()
void changeAvailable ()
void restartRequired ()
 pqBackgroundEditorWidget (vtkSMProxy *smproxy, vtkSMPropertyGroup *smgroup, QWidget *parentObject=nullptr, bool forEnvironment=false)
 ~pqBackgroundEditorWidget () override
bool gradientBackground () const
void setGradientBackground (bool gradientBackground)
bool imageBackground () const
void setImageBackground (bool imageBackground)
bool skyboxBackground () const
void setSkyboxBackground (bool skyboxBackground)
bool environmentLighting () const
void setEnvironmentLighting (bool envLighting)
- Public Member Functions inherited from pqPropertyGroupWidget
 pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr)
vtkSMPropertyGroup * propertyGroup () const
void addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1)
void addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1)
void addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1)
void addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1)
char * panelVisibility () const override
 Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
void setPanelVisibility (const char *vis) override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void currentIndexChangedBackgroundType (int type)
void clickedRestoreDefaultColor ()
void clickedRestoreDefaultColor2 ()
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 13 of file pqBackgroundEditorWidget.h.
◆ pqBackgroundEditorWidget()
pqBackgroundEditorWidget::pqBackgroundEditorWidget ( vtkSMProxy *  smproxy,
QWidget *  parentObject = nullptr,
bool  forEnvironment = false
◆ ~pqBackgroundEditorWidget()
pqBackgroundEditorWidget::~pqBackgroundEditorWidget ( )
override
◆ gradientBackground()
bool pqBackgroundEditorWidget::gradientBackground ( ) const
◆ setGradientBackground()
void pqBackgroundEditorWidget::setGradientBackground ( bool  gradientBackground)
◆ imageBackground()
bool pqBackgroundEditorWidget::imageBackground ( ) const
◆ setImageBackground()
void pqBackgroundEditorWidget::setImageBackground ( bool  imageBackground)
◆ skyboxBackground()
bool pqBackgroundEditorWidget::skyboxBackground ( ) const
◆ setSkyboxBackground()
void pqBackgroundEditorWidget::setSkyboxBackground ( bool  skyboxBackground)
◆ environmentLighting()
bool pqBackgroundEditorWidget::environmentLighting ( ) const
◆ setEnvironmentLighting()
void pqBackgroundEditorWidget::setEnvironmentLighting ( bool  envLighting)
◆ gradientBackgroundChanged
void pqBackgroundEditorWidget::gradientBackgroundChanged ( )
signal
◆ imageBackgroundChanged
void pqBackgroundEditorWidget::imageBackgroundChanged ( )
signal
◆ skyboxBackgroundChanged
void pqBackgroundEditorWidget::skyboxBackgroundChanged ( )
signal
◆ environmentLightingChanged
void pqBackgroundEditorWidget::environmentLightingChanged ( )
signal
◆ currentIndexChangedBackgroundType
void pqBackgroundEditorWidget::currentIndexChangedBackgroundType ( int  type)
protectedslot
◆ clickedRestoreDefaultColor
void pqBackgroundEditorWidget::clickedRestoreDefaultColor ( )
protectedslot
◆ clickedRestoreDefaultColor2
void pqBackgroundEditorWidget::clickedRestoreDefaultColor2 ( )
protectedslot
Property Documentation
readwrite
Definition at line 47 of file pqBackgroundEditorWidget.h.
◆ imageBackground
readwrite
Definition at line 48 of file pqBackgroundEditorWidget.h.
◆ skyboxBackground
readwrite
Definition at line 49 of file pqBackgroundEditorWidget.h.
readwrite
Definition at line 50 of file pqBackgroundEditorWidget.h.
